BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Cars for sale/wanted/trade
European Auto Source (EAS)
      08-28-2023, 01:02 PM   #1
bmw_m3_kid
21
Drives: 2011 BMW M3, 2013 BMW 335i
2011 Space Gray E90 M3 DCT with 123k miles. RB done. Stock. Clean Title and 3 owners.
BIMMERPOST / Classifieds
Asking Price:
USD 27,000.00
Item Interest
Thanks for checking out the post and selling the car for $30,000 or best offer. My mantra is to be transparent. Located in SoCal (Huntington Beach, CA). I purchased the 2011 E90 M3 with 120,000 miles on March 2023 for $24,000. I'm the 3rd owner and currently has ~126,000 miles. The plan was to keep it long term and have a project car to work on. However, there is a change of plan and I want to go back to graduate school. I'm aiming to breakeven with the work done on the car. The car has never been on the track. Sadly, I want to do that one day but unfortunately not going to be able to.
On my own, I replaced the fuel injectors, valve cover gasket, timing cover gasket, replaced plastic vanos covers with aluminum, precat O2 sensors, and all 4 wheel sensors. Transmission fluid and filters have been replaced. The car drives great with no engine lights on! Quite rare for 12 years old car.
My rating out of 10:
Exterior: 6 - 7
Interior: 8.5
Mechanical: 9.5
Stay tune. Will add more information. In the meantime, here are some pictures!
*UPDATE Sept 4, 2023: Posted all maintenance records below. The tires are Michelin P4S and tires were changed in 2021. Tire depth in mm for the tires:
Driver Front:
Passenger Front:
Driver Rear:
Passenger Rear:
Brief description of exterior condition. I will provide pictures later and greater detail. 4 paint dents (two on each side), rear bump is in 70% good condition (3-4 dents on the rear bumper), requires a good car detailing to remove microscratches (car looks good at a distance though), and curb rashes on all 4 BMW 359m styled wheels.
The interior is better conditioned. All buttons, cup holders, and electronics work. Driver's front seat is a little worn due to the prior owner being a little round and heavy. Minor scratch on the leather rear arm rest and the driver's passenger headrest, Otherwise, everything looks clean and brand new.
Update Sept 29, 2023:
I'm going to be posting the interior pictures this weekend. In the meantime, I've changed out the brake vacuum sensor. It was making the car go into limp mode because of a vacuum leak. I took care of that and it runs great. I went on a mini road trip to San Diego. Amazing drive. I added additional photos of the engine that I forgot! The wear and tear looks great for ~123k miles car.
      09-04-2023, 05:11 PM   #2
bmw_m3_kid
21
Maintainence between Owner 2 and 3 (me) dated since 2012
Performed by BMW Encinitas
  • Sept 11, 2012 - 15,020 miles: oil change+filter, air filters, windshield wiper blades, and body shop for front bumper
  • Aug 27, 2013 - 28,175 miles: oil change+filter, rear differential service, spark plugs, wiper blades replaced
  • Apr 23, 2014 - 39,449 miles: Battery replaced+registered,
  • Jun 23, 2014 - 42,468 miles: Oil change+filter, brake fluid change, rear license plate plastic holder replaced, and air filters replaced
  • Nov 10, 2014 - 49,520 miles: Transmission pan+fluid changed (due to leak), washer pump strainer cleaned
  • Apr 22, 2015 - 57,450 miles: oil change+filter
  • May 6, 2016 - 71,873 miles: Oil change+filter, air filters change
  • Jun 7, 2016 - 72,484 miles: Brake fluid flush, spark plugs, differential fluid change
  • Dec 12, 2016 - 78,790 miles: Rear brake pads changed
  • Jul 6 ,2017 - 85,236 miles: Oil change+filter, battery cable replaced per recall
  • May 22, 2018 - 93,435 miles: Brake fluid flush, air filter change, and air bag recall
  • Jun 7, 2018 - 93,913 miles: Replaced brake pads and rotors,
  • Jul 19, 2018 - 96,292 miles: Replaced Idle valve control
Performed at Independent Motorcars in San Diego
  • Oct 19, 2018 - 99,162 miles: Oil change+filter
  • Nov 8, 2018 - 100,260 miles: Driver's front door lock actuator replaced
  • Jan 14, 2020 - 113, 075 miles: Oil change+filter, clean throttle bodies, and battery replaced+registered
  • Jan 11, 2021 - 118,751 miles: Oil change+filter, hood shock replaced, spark plugs, air filters replaced, transmission fluid replaced (filters were not replaced), differential fluid service, thermostat replaced, and coolant replaced
  • Feb 7,, 2023 - 119,756 miles: Oil change+filter and rear brake pads+rotors replaced
  • Feb 13, 2023 - 119,820 miles: Battery replaced and registered
  • Mar 10, 2023 - 120,000 miles: Passenger's front wheel sensor replaced
Performed by MRF Performance
  • Mar 13, 2023 - 120,127 miles: Clevite/Mahle MRF specification rod bearing set, oil pan gasket, oil change+filter, engine mounts, wheel alignment, coolant flush, power steering flush, undercar OEM BMW replaced, BMW main accessory/AC belts replaced, BMW Idler pulley replaced, and EURO front bumper with xPel Ultimate clear film
DIY Projects
  • Jul 8, 2023 - 121,103 miles: Rear wheel sensors replaced
  • Aug 19, 2023 - 121,895 miles: Engine valve cover gasket, 8 fuel injectors replaced, timing cover gasket replaced, plastic vanos covers replaced with aluminum billets, and driver+passenger precat oxygen sensors replaced
  • Aug 26, 2023 - 122,156 miles: Transmission fluid and filters service
  • Sept 29, 2023 - 123,346 miles: BMW OEM Brake Vacuum sensor replaced
  • Nov 4, 2023 - 124,352 miles: Replaced cabin air filters
  • Mar 28, 2024 - 126,678 miles: Oil and filter service. Replaced O2 sensor bank 1 sensor 1
      09-04-2023, 05:46 PM   #3
bmw_m3_kid
21
Exterior and Interior Condition
Update Oct 2, 2023: Here are some photos that I took earlier in the week. I'll take many more in detail and add more information. I want to note that the car had some dents that could be repaired with paintless dent repair.
      09-04-2023, 05:55 PM   #4
bmw_m3_kid
21
Cold start up
Warming up
      09-05-2023, 07:07 AM   #5
bese60
Drives: 2021 M340i
Left the M3 group so early?????
      09-06-2023, 09:57 AM   #6
bmw_m3_kid
21
I have two cars (2013 F30 335i and 2011 E90 M3 both ~120k miles) and lean towards selling both cars. I've owned the 335i for 7 years when it was 40k miles. I would love to keep the E90 because it is solid mechanically and brings way more smiles. I didn't think that I would own an E9X M3 in my life. I've accomplished it! Now, I kind of want to move on and continue with schooling. Think of this way! You'll be investing in my education.
      09-18-2023, 11:19 AM   #7
Ayushm
Drives: 2011 328i
Interested. Sent a PM not sure if it went through since I have a new-ish account. If not let me know how to contact you.
      09-20-2023, 01:15 PM   #8
v8-4me
Drives: E39 M5, B7 RS 4
Interior pics?
      09-29-2023, 03:34 PM   #9
bmw_m3_kid
21
Originally Posted by v8-4me View Post
Interior pics?
Working on it! I posted a few pictures.
      10-10-2023, 06:08 PM   #10
bmw_m3_kid
21
bump
      10-10-2023, 11:20 PM   #11
v8-4me
Thank you. It looks good. Appreciate the detail.
      10-11-2023, 06:34 AM   #12
bmw_m3_kid
21
Thank you, I appreciate your compliment. I tried.
      10-26-2023, 11:43 AM   #13
bmw_m3_kid
21
bump
      01-31-2024, 12:11 PM   #14
bmw_m3_kid
21
bump
      03-28-2024, 12:42 PM   #15
bmw_m3_kid
21
bump. Did an oil change and changed out O2 sensor bank 1 sensor 1. Lowered price as it is getting closer to starting grad school.
      04-26-2024, 12:43 PM   #16
bmw_m3_kid
21
Bump. Lowered
m3post
