BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F30 3 Series Coding DIY - Code Auto Start Stop, DVD, Folding Mirrors, Etc.
GetBMWParts
      08-12-2014, 03:40 PM   #7085
kkaae
Denmark
Drives: G26 2022 i4 eDrive40 Msport
could I also please have PM with a link to the latest version of the E-sys data files please.
TIA
      08-12-2014, 06:41 PM   #7086
shawnsheridan
General
shawnsheridan's Avatar
TIA
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      08-12-2014, 07:34 PM   #7087
Ganxxta
Germany
85
Drives: F32 4er Coupé
Hey guys, sorry that I didn't read the whole (huge) thread, but I just got my new F32 and 2 things bother me:
1. Rain sensor/Auto wipers are always off after engine restart
2. Auto/adaptive high beams (LED) are also always off after engine switch off
So I have to enable both of those every time I get in the car
Can this be coded to be always on or at least to stay at the latest settings?
Its a MY 2015 german edition F32.
      08-13-2014, 03:22 PM   #7088
kkaae
Denmark
Originally Posted by shawnsheridan View Post
PM sent.
      08-14-2014, 12:17 AM   #7089
KnightRider
Drives: 2014 BMW 335 GT
I just bought an ESYS cable and want to code 8S4 and 5AP for Variable Light Distribution / No-Dazzle High Beams on my 2014 335 GT. I have a link for E-SYS 3.24.3 Software & PSdZData 53.0. Is this current or should I be using a different version. From what I've read, I don't need to buy a token to change 8S4/5AP, is this correct?
      08-14-2014, 06:27 AM   #7090
shawnsheridan
General
This is most likely fine for your car, but impossible to know for sure without reading the car. You do not need Token solution to change VO and VO Code car.
      08-14-2014, 10:35 AM   #7091
KnightRider
Would you mind sending me the link to the latest files. As far as I can tell there is a newer version of PSdZData than the link I currently have.
Thanks!
      08-14-2014, 10:42 AM   #7092
shawnsheridan
General
Thanks!
There is. But updating PSdZData is done out of necessity, not benefit as there is none. Are you unable to read car with current 53.0 version?
      08-14-2014, 10:44 AM   #7093
KnightRider
Haven't downloaded 53.0 yet, I just didn't want to download a 7gb file if there was a chance that it wouldn't work.
      08-14-2014, 10:46 AM   #7094
shawnsheridan
General
PM sent.
      08-14-2014, 11:56 AM   #7095
KnightRider
PM sent.
Thank you
      08-15-2014, 12:12 PM   #7096
aweekes1
aweekes1's Avatar
Drives: F30 320xD Auto
Hi,
Can someone send me a link to the e-sys downloads, I haven't got anything running yet so need the whole lot I presume. I've just knocked up the cable and I'm itching to test it!
I've a 2013 model if that makes a difference!
Cheers,
Adam.
F30 - 320d X-Drive - Auto - Professional Media - 19" Wheels - Not much else!
      08-15-2014, 12:13 PM   #7097
shawnsheridan
General
Originally Posted by aweekes1 View Post
Hi,
Cheers,
Adam.
PM sent.
      08-16-2014, 07:00 AM   #7098
Spitfi-r
Drives: m235i
That CAFD is corrupted now. You need to inject new one in ECU:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
I used this to fix my corrupted Fem_ body CAFD also.
Thanks for all you do Shawn!
2014 m235i->present: EB, Black, Hex trim, Cold, Premium, Tech, MT, sunroof delete: June 2014 euro delivery.
2001 330ci: 2005->2014 sold and already missed.
1989 325is: 2010->present s52'd - track car
1991 318is: 2013->present taking up space
      08-16-2014, 07:01 AM   #7099
shawnsheridan
General
Originally Posted by Spitfi-r View Post
I used this to fix my corrupted Fem_ body CAFD.
      08-16-2014, 09:54 AM   #7100
Tcheslavie
Drives: F33
Originally Posted by SBasinger View Post
I recently got my car back from having it coded for the M Performance brakes, now I have a heated steering wheel indicator. I'm not sure if this is the new one, or if the new one is a persistent icon. Mine disappears after about 5 seconds.
Waiting for a recipe from Shawn. I've flashed KOMBI to 14-07-502, then changed FA to 0714 and coded kombi, but no result there. Should I have flashed it with 0714 FA or just CODE is enough?
      08-16-2014, 09:58 AM   #7101
shawnsheridan
General
What are you trying to solve?
      08-16-2014, 10:27 AM   #7102
Tcheslavie
Drives: F33
I'm trying to make kombi show indication of the wheel heating. I think I should use newer psdzdata then.
      08-16-2014, 12:48 PM   #7103
shawnsheridan
General
Hmmm, I have not seen this before. You have no indication now at all? Does someone have a persistent one, or is it always for 5 seconds upon activation?
      08-16-2014, 01:18 PM   #7104
Tcheslavie
Drives: F33
Nobody does before MY2015 My car from factory was 13-11-502. but it can be coded for sure. It should be 5 sec.
      08-16-2014, 01:22 PM   #7105
shawnsheridan
General
I need yours and SBasinger's KOMBI and FEM_BODY .ncd files to compare.
      08-16-2014, 05:05 PM   #7106
Moovrr
Drives: BMW M140i F21
Can anyone advise regarding coding of EBT to a HU_CHAMP2 on a June 2014 F20 for another member?
The car has a Combox, Bus Nav and basic Bluetooth, and CMB_Media module. I have psdzdata 52.5, should this be updated?
I have read either 6NK or 6NS should work, these were added to the VO, with and without 6NH, and read back from the FA but no changes were apparent on the iDrive.
I then googled the CHAMP2 unit and came across some info that suggested that I needed to be able to FDL code FEM_GW, but this has no CAFD to edit so I assume the VO changes aren't taking effect on this FEM_GW module, is this correct?
I tried to "Detect CAF for SWE" but got the error shown below, and ideas?
Also FDL coding on the BKOMBI and FEM_BODY worked fine but for BMW LIVE there were additional options in the HU_CICHB (CHAMP2) CAFD file for 3003 ONLINE BROWSER; default is "nur_bmw_online_aktiv", and there is also "nicht aktiv", "nur_bmw_internet_aktiv" and "beide_aktiv", is the last option the one for "Both Active" the right one?
3 series coding, 3 series f30, 3 series f30 coding, 3 series f30 forum, 3 series forum, 3-series forum, 5 series f10 coding, ass, ass disable, auto start stop, auto start stop disable, bmw 3 series coding, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw 5 series coding, bmw auto start stop disable, bmw auto start stop disabling, bmw coding, bmw coding directions, bmw coding diy, bmw coding instructions, bmw diy, bmw diy forum, bmw f10 coding, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 coding, bmw f30 forum, coding 3 series, coding f30, coding f30 3 series, disable ass, disable auto start stop, disable bmw auto start stop, disabling auto start stop, disabling bmw auto start stop, f10 5 series coding, f10 coding, f30 3 series, f30 3 series coding, f30 3 series forum, f30 3-series, f30 3-series forum, f30 coding, f30 forum, f30 forums
