      06-21-2011, 02:15 PM   #89
PrMaX
PrMaX's Avatar
Poland
14
Drives: 2009 E90 M-packet
Originally Posted by Drawn05 View Post
This is a bit weird as there is no pin 6 on my xenon headlamp connection but there is one on the car/frm side
Pin 6 is only present in AHL bi-xenon headlights.
Maybe you have bi-xenon without AHL feature...
E90 LCI M-pakiet 320d '09 iDrive CiC
      06-21-2011, 05:14 PM   #90
Drawn05
Australia
67
Drives: Yes
You are right that pin 6 could be for AHL, as the instructions that I drew that diagram from are for the AHL retrofit kit.
But I am unsure if the e90 wiring is the exactly the same for the e82, as what you have is the same as what I currently have and it doesnt work for me.
I can code the VO to have the $522 and get the xenon low beams to work without flickering but lose the AEs and high beams, even though they are activ in the frm script.
I need to get a photo or a diagram of the non-ahl e82 xenon socket wiring.
EDIT: I am such an idiot!!
I have been misreading the instructions. It actually requires the new wiring harness 'IN ADDITION' to the current one, not to replace it outright. So Pins 1, 9,10 and 11 are replaced with the new wiring but the original 3, 4, 6 and 12 remain with pin 5 (the high beam shutter) being a new addition (but unlike the e90, cant just be tapped from another pin).
So the DRLs dont work because the pin in the FRM is not there, as when the $522 is coded it requires the FRM to have a different pin from the one that is currently there with the halogens(so its connected at the headlights but not at the FRM, if that makes sense -same with the High beam {which as it isnt a bulb it doesnt give a error code}). It all makes sense now!!! It requires a new pin 1 becuase the halogen bulb is a tiny 5w while the DRL are 35w.
Might just bite the bullet and buy a the harness from a local dealer today rather than wait the 2 weeks for it to come from Germany.
      06-22-2011, 02:44 AM   #91
PrMaX
PrMaX's Avatar
Poland
14
You need this harness: 61 12 0443 691 which is a part of retrofit kit: 63 13 0 443 694.
You can buy it seperatly.
Good luck
      06-22-2011, 09:22 AM   #92
carlosalbertogui
17
Drives: bmw E91 facelifted by me
help please
i have a bmw e91 2007 halogen i have made the LCI xenon retrofit non AHL
i would like to know 1 --------AE's-------- 41 and the shutter pin5 also connect to pin 41 but in the other frm plug right X14261 or X14260 ???
help much apreciated
Good luck
Left headlight FRM Module
2 --- GND for xenon ---
3 --------XENON--------6
4 ---------GND---------
5 ---shutter on/off--- 41
6 ----H3 Cornering---- 6
7 --3LEDs side marker- 50
9 ---AHL function --- 9
10 ---AHL function --- 25
11 ------- GND -------
12 ----- Blinker -----
Right headlight FRM Module
1 ---------AE's------- 14
2 ----GND for xenon---
3 -------XENON-------- 38
4 --------GND---------
6 ----H3 Cornering---- 4
7 --3LEDs side marker- 8
9 ---AHL function --- 42
10 ---AHL function --- 10
12 ----- Blinker -----[/QUOTE]
      06-22-2011, 11:09 AM   #93
PrMaX
PrMaX's Avatar
Poland
14
All diagrams are valid for E8x LCI, E9x LCI cars only
X13420 1 --------AE's-------- 41 X14261
X13420 5 ---shutter on/off--- 41 X14260
X13421 1 ---------AE's------- 14 X14260
X13421 5 ---shutter on/off--- 41 X14260
If you have any questions feel free to ask.
Greetings from Poland
      06-23-2011, 10:38 AM   #94
carlosalbertogui
17
bmw E90 retrofit Lci xenon Conversion, headlights xenon LCI 2008
hi all
cable Conversion, headlights xenon LCI 2008
can anyone tell me the wiring diagram and where to connect this cable
this cable is sold at bmw and it is for xenon lci headlights retrofit
bmw part number is Wiring head light 61122149448
http://www.realoem.com/bmw/showparts...07&hg=63&fg=95
help much appreciated
best regards
      06-24-2011, 06:53 PM   #95
Jonny Tea
Jonny Tea's Avatar
Drives: 123d M Sport Coupe in White
Hi guys, Im doing the same thing on mine. Purchased a usedo/s xenon headlamp Ģ60 (with ballasts). when I plug it in im getting high beam error. indicator, side lamp(halos) and auto leveler work fine. The only problem im getting is the high beams. there bi-xenon so have the shutter that you have mentioned.
I was wondering how I get the high beams to work.
Can I not change the pin from the car side socket that is for halogen high beam to the pin that is for the shutter?
hopefully then it wont need coding.
Can anyone breifly explain how I remove the pins from the car side plug aswell?
Jonny Tea
      06-24-2011, 06:53 PM   #96
Jonny Tea
Jonny Tea's Avatar
email me at jon.thaxter@gmail.com if it helps
Thank you!!!!!!!!!!!!!!!!!!!!
(p.s. I Love you if you can help!)
      06-24-2011, 08:01 PM   #97
Drawn05
Australia
67
Drives: Yes
Jonny Tea
So if I understand correctly, You have halogens as your stock headlamps and you have replaced them with OEM xenon projector Headlamps.
If so, this will not work without correct wiring and coding.
Have you tried turning the engine on with the low/dipped beams on yet? The low beams/dipped beams will flicker and you will not be able to drive your car at night.
NBGV18.00
      06-25-2011, 05:21 AM   #98
aacabriolet
aacabriolet's Avatar
118
Drives: '14 435i Coupe
@Drawn05 - will take the pics of that harness for you later when I'm with my car. It's not with me at the moment.
Btw, just a pic for anyone who cares
      06-27-2011, 10:43 AM   #99
carlosalbertogui
17
ohhhhhh
any help
the cable has
two pins X13420 left
color of the cables
color blue / black and the other grey/yellow
two pins X13421 right
color of the cables
color green / black and the other grey/violet
in the other end all the four cables to connect to footwell module
dont now where
anyone
hi all
best regards
      06-27-2011, 10:49 AM   #100
aacabriolet
118
@carlos - http://www.1addicts.com/forums/attac...7&d=1306919026
      06-27-2011, 11:32 AM   #101
Jonny Tea
Jonny Tea's Avatar
Ive got halogen lights at the moment. Plugged in a oem xenon without a ballast and only the halos and indicators worked correctly. Plugged a ballast in and bulbs and the headlight seems to work fine, I just done have high beams which is abit of a killer. It even does the auto leveler correctly at start up.
Does anyone know my best bet? How to go around doing it? Im not technically minded in terms of cutting wires etc. Is there not say a plug adaptor that you could plug inbetween? can BMW re-program it cheaply?
THANK YOU!!!!!!!!!
      06-27-2011, 11:33 AM   #102
Jonny Tea
Jonny Tea's Avatar
really nice, where'd you get the LCI xenons from?
      06-27-2011, 11:57 AM   #103
aacabriolet
118
Thanks. For high beams tap the xenon shutter (pin 5) to old high beam wire (old wire 6).
Or you'd have to take out pin 6 from harness and put it in pin 5.
That's what I reckon anyways.
      06-28-2011, 06:19 AM   #104
carlosalbertogui
17
this is for bmw 1 series LCI
hi
mine is a 3 series
dont know if its done the same way
best reagrs and thanks
Originally Posted by aacabriolet View Post
      06-28-2011, 07:38 AM   #105
aacabriolet
118
hi
mine is a 3 series
http://www.e90post.com/forums/showth...hlight=hid+DIY
      06-28-2011, 08:13 AM   #106
carlosalbertogui
17
thanks anyway
hi
this doesnt work because my headlights are LCI
at the moment all works except high beam and DRL (only works rear lights).
DRL works but (only works rear lights). headlights no light att all even angel eyes that should stay not dont light.
bescause of this iam almost 100% sure the instruction you gave me are ok but.
the 3 led on the headlight dont work either its pin 7 (headlight)
i think i have to take the cable from pin 1 headlight and put it on pin 7 (headlight)
i have to put a new wire from pin 1 headlight to frm dont now in what pins i have to put on frm.
i want to know where in frm i connect pin 1 from headlights
do you know if bmw e90 lci as more then one wire connected to the same pin on frm ???
the xenon instructions you gave me in .pdf make all sense but dont know for sure if bmw 1 series E87 LCI is equal to bmw 3 series E90/E91 LCI
i bet it is but want to have 100% sure. dont want to ruin anything.
best regards
      06-28-2011, 08:25 AM   #107
Jonny Tea
Jonny Tea's Avatar
This may sound stupid but how do I remove the pins?
The way the xenon headlight is, its almost as if you cannot get to the socket as its mounted low down on it and cannot access the back of it.
Preferably Im trying to get the light so its reversible if i need to and errorless.
Does anyone know of an adaptor that would fit in between the plug and socket and direct all the correct connections?
      06-28-2011, 08:47 AM   #108
carlosalbertogui
17
this way
hi
its very easy
you have to removed the plug from headlight first
remove the plug from headlight
you have to squeeze left right and push and it will come out
then with a screwdriver you open a little plastic then insert a need on the other end upper hole wire you want to take off.
where you see the big toe there is the little plastic you have to open
on the other side off the wires (front of the plug) there is the little hole above every pin you put a needle on it and pull the wire it will come out
      06-29-2011, 11:31 AM   #109
carlosalbertogui
17
hi all
i dont have the auto leveling function i didnt buy it
can i remove the pin 8 from headlight car plug without problems ???
i will connet the wire to pin 5
i want to use that wire for shutter this wire is connect to pin 50 and 51 on frm and i will
conect it to pin 41 toghether
can this be done without any problem
i dont have the self leveling connected so i think pin 8 9 10 and 11 arenīt doing nothing...
what do you think about this
      06-29-2011, 11:37 AM   #110
aacabriolet
118
hi all
This is not really the right board for E9x talk, but this may help you with your problem..
Regards, ...
