02-27-2023, 02:36 PM | #1 |
72
Rep 258
Large Part Out - 30043
I am doing a part out on my 2017 M3. Build of this car was performed from 12/21 through 4/22. All performance mods were done 04/22. The car has had roughly 2,000 miles put on it between 04/22 and when I sold the car. The car dynoed at 715HP/588TQ with a very conservative tune.
Performance • Pure stage 2+ turbos - $4000 • MHD ethanol sensor - $350 • ARM silicone charge pipes - $150 • Pure inlets - $100 • Max PSI J-Pipe - $100 • Spec Stg. 2 clutch - SOLD • BMS oil catch can - SOLD • Akrapovic midpipe and rear section w/ Titanium tips - $4000 Suspension/Brakes/Wheels • MCS 2-way non-remote coilovers w/ Ground control camber plates - SOLD Manual Transmission • Rogue SSK with trans mounts (new) - SOLD • Ultimate Clutch Pedal (new) - SOLD Suspension • Fall Line Rear lower tension arm set and bearing (new) $500 • Fall Line Rear fixed toe arms and bearing (new) $500 • Turner thrust arms - SOLD • Turner diff bracket and bushings (new) $400 Exterior • PSM CF side skirts - $750 • IND mineral white rear painted reflectors - $75 Interior • M Performance Alcantara shift boot and knob - $250 • M Performance cf e-brake handle - $200 • Autotechnik cf seatback covers - SOLD • Weathertech mats – front/rear/trunk - $150 Electronics Bimmertech front and rear camera SOLD Escort Max 360 Radar with blend mount $400
2014 F82 (sold)
2016 F15 (sold) 2016 F80 ZCP (sold) 2018 M2 6MT (sold0 2017 F80 6MT Last edited by 1sickm2; 03-10-2023 at 08:13 AM.. |
03-02-2023, 08:28 AM | #2 |
Rep 661
Interested in the SSK shipped to 02472.
Winter: 13 PGM 3.5 E70|MHD
Summer: 15 6MT BSM F80|MHD|KW|SM-10 Gone: 09 AWD 6MT AW E90|FBO|MHD|XHP|KW|ARC-8 IG: 475_f80 |
03-02-2023, 09:14 AM | #3 |
Rep 495
Turner thrust arms - did you buy the monoballs preinstalled into new arms or did you press the monoballs into your original arms?
Instagram: @f80ghost
03-08-2023, 07:20 AM | #5 |
Rep 661
Doesn't look like OP is updating this thread. Saw the SSK marked as sold on another thread.
03-08-2023, 07:35 AM | #6 |
72
Rep 258
Sorry everyone my notifications for bimmerpost have been jacked up. List updated.
2014 F82 (sold)
2016 F15 (sold) 2016 F80 ZCP (sold) 2018 M2 6MT (sold0 2017 F80 6MT |
05-06-2023, 03:02 PM | #7 |
172
Rep 283
Drives: Multiple M Cars
Sent pm
Current Garage
2011 E92 M3 // ESS G1+ (PSI Built) 2020 F82 M4 // FBO (PSI Built) 2022 Model X // Plaid 2020 Porsche Taycan // 4S Performance |
02-13-2024, 03:57 AM | #9 |
Rep 75
PM’d regarding turner kit
02-17-2024, 07:12 AM | #10 |
Rep 11
Drives: BMW M3
Weather tech mats still available? Please PM of so. Cheers
