2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics ID6 third page disappearing when not using it
      02-16-2024, 07:41 PM   #1
TWZK
Drives: F22 220D, F20 135i
Hi,
I retrofitted an NBT EVO in my F22 long time ago, i always had this problem but now it bothers me a lot
When i'm on the home page and not using it for 5-10sec, i have the third page disappear but when i just move the controller, the page comes back instantly
I changed the organisation of the menu, any page that i put in the third row do that
Tried everything in the FDL coding
Little problem but if someone has an idea, it would be great
Thanks !
      02-17-2024, 11:03 AM   #2
llebnave
llebnave's Avatar
Drives: 2017 M240i, 2007 335xi
Just to clarify your question, are you referring to the tile on the edge of the screen after you scroll from one page to another? If so, that is the normal behavior. It disappears after a few seconds to leave a cleaner layout and returns when you next interact with it.
Edit: Or do you mean the third full tile is disappearing? Did you upgrade from the smaller 6.6” screen when you did your retrofit? Maybe it is behaving that way because it thinks it still only has the smaller screen area to display? There should be a setting to indicate the screen size and resolution if you haven’t already done so, I will see if I can locate that later.
      02-17-2024, 09:35 PM   #3
TWZK
The third full tile is disappearing, yeah i had an 6.6 entrynav, everything else is working perfectly (i just don't have the split screen option, searched for the code but didn't find anything)
Even when i move it to the next tile, the third disappear
Edit : sorry for the rotation of the images, don't know why it's rotated like that
      02-24-2024, 05:33 PM   #4
TWZK
No one has an idea ?
      02-26-2024, 06:17 AM   #5
llebnave
llebnave's Avatar
I haven’t had a chance to check what the values are for my car which came with the 8.8” screen, but take a look at the coding for these parameters for your headunit and see if they look correct. When I have a chance I’ll post mine for comparison.
      02-29-2024, 07:19 PM   #6
TWZK
DISPLAY_VARIANTE was the problem, i coded it to breites_display and now it's worked perfectly, thank you very much !
I don't understand how i haven't checked that...
2addicts
