BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > UK
European Auto Source (EAS)
      01-09-2016, 02:29 PM   #1
nfisher1991
2014 M135i Retired
nfisher1991's Avatar
Scotland
Drives: 2012 Le Mans Blue M3 DCT
2012 BMW M3  [0.00]
Grinding/Rubbing noise when turning slowly
Just recently bought a 2012 Le mans Blue m3,
Im hearing a noise when turning at slow speeds it sounds like its coming from the Diff or underneath the rear seats. Sound like a grinding or rubbing noise.
Any help would be appreciated?
Cheers Neil
      01-09-2016, 02:46 PM   #2
vsix
vsix's Avatar
602
Drives: M3 E92 sold, M4 F82
Load a vid up, it's much easier to help that way.
      01-09-2016, 04:52 PM   #3
nfisher1991
2014 M135i Retired
Scotland
2012 BMW M3  [0.00]
Im at work for 2 weeks, will post a video when im home.
      01-10-2016, 09:49 AM   #4
DavS1
DavS1's Avatar
Scotland
53
Drives: Emfree
2011 BMW M3  [0.00]
it's the rear diff locking on tight turns, it causes a rumbling sort of noise.
There is a "fix" for it from BMW. It's bassically rear diff oil with an "FM Booster (Friction Modifier). Anyway it's called SAF-XJ+FM Booster.
Add that, then find a nice big empty space and do 9x tight turns left, and 9x tight turns right to circulate the fluid through it.
I had the same issue, took it in for a service and got the diff oil changed, decided to try it on the standard oil for an M3 and it's improved it but it still does it on occasion.
HTH.
http://www.e90post.com/forums/signaturepics/sigpic97427_1.gif
Monte Carlo Blue M3 Comp
      01-10-2016, 02:41 PM   #5
nfisher1991
2014 M135i Retired
Scotland
2012 BMW M3  [0.00]
Cheers DavS1, thats the exact noise.
Its booked in for a service in a couple of weeks so will get it done then.
Neil
      01-10-2016, 03:22 PM   #6
Shazz
34
Drives: E92 M3
It will take a few hundred miles after the service for the noise to go away completely.
      01-10-2016, 04:42 PM   #7
Ian122
Ian122's Avatar
Drives: N/A
Just to add the noise isn't actually an issue. But if it annoys you then get the friction modifier.
      01-19-2016, 03:23 PM   #8
DavS1
DavS1's Avatar
Scotland
53
Drives: Emfree
2011 BMW M3  [0.00]
Seems to be a few Scottish members on here, we should get a meet going
      02-14-2016, 08:58 PM   #9
leopard print
Drives: Really well for an Asian.
Hi Neil.
Did you take your car in for service and was the problem fixed? My car started making a similar grinding/rubbing noise only on right turns under 20 mph. I'm sure it's not rubbing from the wheels (but sounds identical) because there is no noise at higher speeds or when I hit bumps.
      02-14-2016, 10:07 PM   #10
nfisher1991
2014 M135i Retired
Scotland
2012 BMW M3  [0.00]
I took the car in for a visual inspection and they took it out for a drive. They reported that they couldnt hear any noise and told me to monitor it. If it continues ive to take it back and they will look in to it again.
Cheers
      02-15-2016, 03:05 AM   #11
Shazz
34
Drives: E92 M3
You should try the car park tight figure 8s manoeuvre first.
      02-15-2016, 11:15 AM   #12
leopard print
Cheers
Thanks.
      04-07-2016, 10:09 PM   #13
m3toboot
Australia
24
Drives: ///3
Once the oil is changed a few slow figure 8 turns are also recommended from memory.
      09-07-2020, 11:34 AM   #14
HemiSam
Drives: BMW M3
I have the same issue that just crept up with my 2012 M3. I haven't been driving it all that much of late due to weather and thought it might be for that reason. 74k miles so it may just be that as well.
Good recommendations here...thanks.
HS
m3post
