MHD Logs. Timing Correction & Boost Target
07-23-2015, 05:12 PM | #1 |
39
Rep 133
MHD Stage1 93 map. Bone stock car, no other mods. Running on 93 / 98-99 RON Fuel
Posted this in the MHD forum but after a bit of reading up on timing correction and target boost I wondered if someone might be able to shed some light... Did first ever logs tonight, wasn't really sure what to do but got some decent 3rd gear pulls on a straight road followed by a few 2nd-4th WOT's. Logs: 3rd Gear WOT http://datazap.me/u/alex-qts/3rd-gea...og=0&data=4-22 (2 log files selectable) 2nd-4th Gear WOT http://datazap.me/u/alex-qts/2nd-4th...og=0&data=4-22 (3 log files selectable) I can see that I have some post shift timing corrections on the 2-4th gear runs but reading that it can be quite common. (nothing below -3 and not all cylinders at once) More worrying is the buildup of boost on the 3rd gear WOT, the boost starts to climb but actually drops by ~2psi then back up again. Is that the sign of a boost leak or something else. The boost curve generally looks flat and messy in the lower RPM's. Car was surprisingly slow in the lower RPM's but hauls when it gets going. Target boost is also wayy off until around 2200RPM. I would appreciate any input as the whole logging / understanding logs is very new to me. |
07-23-2015, 05:35 PM | #2 |
533
Rep 2,872
First off, how old are the spark plugs? If they're more than 25k miles old, swap them with new.
Next, have you confirmed there's no vacuum leaks by replacing/checking all of the vacuum lines? Last, bone stock with a tune like MHD has to offer, you should really upgrade your charge pipe before it breaks. |
07-23-2015, 05:40 PM | #3 | |
39
Rep 133
Vacuum lines I have not checked or replaced but will get on that also. Will look into charge pipes, is this the famous pipe that will go bang at some stage if it is not changed?! cheers |
07-23-2015, 05:41 PM | #4 |
Rep 1,536
In the first two logs you are getting throttle closures the same rpm each time. If you look at the boost target against actual boost you can see that the boost is going over target consistently at certain points (2300/3000/4000 rpm) across both 3rd gear logs which causes the ECU to close the throttle to stop it going any higher.
If it were my map I would reduce the D factor multiplier at each of those RPM breakpoints but since you are using an OTS map you will have to take it up with MHD or Wedge himself. EDIT: Second set of logs has timing lots of timing corrections but less throttle closures, boost control seems a little more stable above 4k RPM. |
07-23-2015, 05:52 PM | #5 | |
39
Rep 133
Both runs on the same map, on a slightly different road though. Did not notice the throttle closure, again I think I am going to have to read much more and contact MHD / Wedge. EDIT: The traction control was off with one press, so not fully off. Could that be related to the throttle closures. No flashing lights on any of the runs. Last edited by alex-qts; 07-23-2015 at 06:01 PM.. |
07-23-2015, 07:37 PM | #6 | |
533
Rep 2,872
Insufficient vacuum can cause the lag you're experience, it could also be the boost solenoids. See here: http://www.n54tech.com/forums/showthread.php?t=13114 Replace the plugs with Bosch OEM, or NGK 5992 (MUST BE GAPPED!!). |
07-24-2015, 05:10 PM | #7 |
Boost
1354
Rep 3,693
Drives: 135i M-Sport
make sure your car is running in tip top shape STOCK before doing any sort of performance modding...
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
07-24-2015, 10:42 PM | #8 | |
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
07-24-2015, 11:38 PM | #9 | ||
Boost
1354
Rep 3,693
07-25-2015, 02:22 AM | #10 | |
39
Rep 133
Very happy with both the maps and MHD Will be replacing plugs, charge pipe, DV's and fitting a dual cone intake soon. |
03-15-2024, 11:35 AM | #11 | |
Rep 4
Have you ever figured it out? I'm having identical symptoms. Thanks.
03-15-2024, 11:51 AM | #12 | |
Rep 972
Reviving a thread from 2015 is not going to help you much. The tunes are different etc.
Instagram : @Bimmer_bro
03-19-2024, 03:49 PM | #13 |
Rep 4
Here's the log
https://datazap.me/u/daverave/log-17...7-8-9-21-22-23 Check cylinder timing - massive corrections on every cylinder under load. I'm running MHD version 3.20 I8A0S v10.0 stg 1 95_102, no mods, 160 000 km on clock. I had a previous v7 map and there was a same issue. The car became jerky under throttle. I've noticed it gets worse when going uphill. It's better when car is cold, but gets worse when fully warmed. I can avoid that with very light pressure on gas pedal up to 2k RPM. The strange thing is that sometimes I get clean pull without any issues (like 2,3,4 on full throttle) but 90% of time the car behaves badly. The only code I'm getting sometimes is 2AAF Fuel pump, plausibility. But nothing else!? Car is running bad even on the stock map. I've changed spark plugs to 1-step colder and ignition coils without any effect. Any ideas? Thanks. |
03-21-2024, 04:28 PM | #14 | |
Rep 972
Make sure you are also logging boost psi, boost Target psi, wgdc, Air intake temp is also important. (I want to see your intake temps) 3rd gear pull only with tc off-2500 rpm to redline.
03-21-2024, 04:46 PM | #15 | |
Rep 1,539
not related, but are you the same person ? : https://www.bimmerpro.ca/index.html |
03-21-2024, 04:47 PM | #16 | |
Rep 972
oVeRdOsE.2716.00 |
03-21-2024, 07:13 PM | #17 | |
24
Rep 162
TiAgAu150.00 |
03-24-2024, 09:49 AM | #18 |
Rep 4
Europe here - 95 octane is pretty common here. Map is ok. I was driving with the same map before these problems.
Anyway here's better log https://datazap.me/u/daverave/log-17...&data=3-4-5-18 After I hit the gas pedal the STFT goes deep into negative values ending with 25% trim and having massive cyl corrctions on every cylinder ... What I've found on the internet so far: - could be boost leak - less air causes too rich mixture so ECU corrects amount of fuel > STFT goes wild - somebody with similar symptoms had failed O2 pre cat sensors No codes thrown (very rarely: 2AAF Fuel pump, plausibility). It's worse when fully warm. What I've done so far in a meantime: - MAF cleaned - throttle body cleaned and reseated - VANOS solenoids cleaned and switched - new spark plugs & ignition coils Next possible steps: - boost leak test? - boost solenoids leak test/replacement - LPFP replacement - O2 pre cat sensors replacement? Thanks for your ideas! |
