BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
European Auto Source (EAS)
      04-09-2024, 12:09 AM   #1
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
Infamous Post Liquimoly Oil Change Tick
As the title suggests I recently performed my second oil change since owning the car. The first oil change was done at EAS when the rod bearings were replaced, and they used Castrol. The second oil change was performed by myself, switching from Castrol to Liquimoly. (10W60 if it wasn't already assumed). After completing the oil change and inspecting the filter I noticed a small amount of metal bits (shavings? - not sure how to classify them) in between some of the filter fins. I'm not overly concerned, but am also wondering what it could possibly be. Possibly related possibly not, and to bring this post back to the main topic I noticed an intermittent ticking sound after driving my car roughly 50 miles this weekend on a spirited canyon drive. The car has now only done about 100 miles or so after the oil change, and I am hearing that same sound that others have described in many threads.. usually after performing an oil change and more specifically changing to or using Liquimoly. Just like others have experienced, the sound is intermittent with no true rhythm, and it is best heard near or behind the driver's front wheel. Tomorrow I will post pictures of my filter from the last oil change, and if anyone can chime in on the ticking noise I'd love to hear some opinions.
https://www.m3post.com/forums/showthread.php?t=1167323
Went through this whole thread last night if anyone wants to see some other examples/discussions.
Also, I want to be clear I am in no way shape or form trying to bring down Liquimoly, I love their products and the engine seems to run better than ever after the change, I'm simply curious and a little concerned as to what may or may not be happening to my engine.
      04-09-2024, 11:44 AM   #2
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
if you're concerned, do another oil change to make sure you flushed out any other metal shavings.
^ probably best to do that.
LiquidMoly isn't that great and compared to other equivalent oil.. it introduces the most engine noise lol
also factor in the colder than usual climate here in SoCal right now..
personal experience. no valve tick on these oils I've tried below:
Redline
Motul 300V
Amsoil
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
      04-09-2024, 11:48 AM   #3
E92Bean
E92Bean's Avatar
87
Drives: '13 E92 M3 ZCP
Unfortunately the shop that did my bearings used liquimoly. I’ve used motul 8100 10w60 for my past 2 changes and it’s nice and quiet.
      04-09-2024, 02:27 PM   #4
e92dud
62
Drives: e92 m3
Also, I want to be clear I am in no way shape or form trying to bring down Liquimoly, I love their products and the engine seems to run [...]
Were your previous bearings worn? Supposedly worn bearings can have pieces come out of things like the oil cooler later on, which could explain metal in your filter. I had zero metal in my filter after my bearings were changed, but my previous bearings also had very little wear.
      04-09-2024, 04:33 PM   #5
omgzirra_exe
you probably caught your RB job just in time tbh, if you still have shavings in your engine.. best to just flush it out completely with generic oil from autozone/advanceauto parts w.e.
could be excess still in the oil cooler.
then let it idle for a bit and then change your oil with your preferred brand.
#fakeGTS
      04-09-2024, 04:52 PM   #6
a5m
Drives: 2011 BMW E90 M3
I don't get the hype for Liquimoly in the BMW world. It gets laughed at on BITOG. The shop that did my bearings wanted to use it. Had em switch to Redline 5W50 instead. Especially for Chicago winters, also since I did them during the coldest part of this winter lol.
If you're concerned about shavings I'd dump and replace with Castrol or Redline/Motul. Not worth taking the chance.
      04-09-2024, 09:00 PM   #7
GinTonic
126
Drives: E92 M3
Ditch that junk ass liquimoly. I used that garbage in my motorcycle years ago and hated the shifting feel. Needless to say, I drained the oil after 500 miles and switched to Motul 300V/ 7100, & Redline.
Last year I did 3 or 4 oil changes using liquimoly and would consistently burn through 2 quarts of oil during a 5000 mile period. Now using Motul 8100, and have to top up a quart of oil after 3.5K-4K miles.
      04-09-2024, 09:51 PM   #8
MikeHawk7
MikeHawk7's Avatar
Drives: 2013 M3: E92, ZCP, DCT
2003 BMW 530i  [0.00]
2013 BMW M3  [0.00]
2016 BMW i3 REx  [0.00]
Throwing my 2 cents in: currently using, and like, Redline 10W60. No problems so far.
-Mike M.
2013 M3
[E92, Alpine White, ZCP, DCT]
2016 i3 REx
[Tera World, Capparis White]
      04-09-2024, 11:20 PM   #9
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
Redline
Motul 300V
Amsoil
Excellent advice, purchased the Motul 8100 kit from FCP today. I will be changing the oil again this weekend. Went with the 8100 because I wanted to stick with the 10W60 although the 300V is looking enticing. Thank you for your reply!
      04-09-2024, 11:22 PM   #10
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
@E92Bean I purchased the Motul 8100 today and it should be here before the weekend. Looking forward to changing the oil with the Motul kit. I greatly appreciate your reply!
      04-09-2024, 11:25 PM   #11
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
I'm going to post some pictures here at the bottom of the thread. This has motivated me to actually take a look at my bearings... I never really did I just assumed everything was okay. I don't think they're necessarily horrible as I've seen worse but I can see small amounts of copper starting to show. Overall I'd say pretty good for 140,000?
      04-09-2024, 11:26 PM   #12
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
Coming to find this out as everyone seems to have the same opinion. Ordered the Motul 8100 today and looking forward to making the switch this weekend. Might try Redline next change depending on how the car likes the Motul
      04-09-2024, 11:28 PM   #13
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
You sent this after I had ordered the Motul 8100 so this gives me some peace of mind. I'll let you know what I think, very much looking forward to changing the oil.
      04-09-2024, 11:29 PM   #14
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
You're the second person who's recommended Redline. I might give it a go next time around, I purchased the Motul 8100 today.
      04-09-2024, 11:33 PM   #15
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
After the rod bearings were replaced I never really took a good look at the old ones. At the time I basically just pulled one out and said ehh not too bad. But tonight I inspected each one pretty thoroughly and my opinion is for 140K they're not too bad as I've definitely seen worse, but in certain spots I can start to see slivers of copper and I'm definitely glad I had the originals replaced.
      04-09-2024, 11:36 PM   #16
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
I also took a better look inside the filter. The left bigger chunk seems to be valve cover coating to me. I'm not overly concerned about that however there are multiple examples within the filter fins that look very similar to the metal piece on the right. The oil filter is not filled with these flakes but it's definitely more than I'm comfortable with.
      04-10-2024, 12:12 AM   #17
E92Bean
E92Bean's Avatar
87
Nice, FCP kit is solid. I know many people experiment, but I don’t see myself trying any other oils.
      04-10-2024, 12:34 AM   #18
omgzirra_exe
you can even go as far as disconnecting your oil cooler and drain it if you have the weekend to your self.
#fakeGTS
      04-10-2024, 12:38 AM   #19
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
Consuming that much oil sounds like an issue to fix.
      04-10-2024, 12:52 AM   #20
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
The hype is that it's almost $50 cheaper than the next cheapest option per oil change. It's a good oil for the price, but no one is saying it's the best thing ever.
My oil change interval is every other track weekend or about 2500 miles and differential fluid every other year. With these low change intervals, I've had no issues or indications of oil consumption with LM's 10W60 or their differential fluid.
m3post
