KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
06-15-2020, 04:17 PM | #683 |
Rep 88
Will I rub on 2011 stock Zcp wheels and stock competition ride height.
Spacers : 10mm front and rear Tires 265/35/19 F 285/30/19 R Michelin ps4s Last edited by Tosirius; 06-16-2020 at 12:19 AM.. |
06-20-2020, 12:34 AM | #684 |
Rep 30
E93 (non-edc) stock
Will this rub or will I have issue with the fenders? Front: 19x9 ET20 running 255/35 PSS Rear: 19x10.5 ET25 running 275/35 PSS |
07-09-2020, 04:59 PM | #685 | |
9
Rep 61
07-12-2020, 07:33 AM | #686 |
BMWCCA Member
126
Rep 98
Drives: 1997 M3 Sedan
I did my first track day on a set of Forgeline GTD-1s, 18x10 +27mm square set with 12mm spacers in the rear. 285/35/18 Hankook RS4s all the way around.
It rubbed slightly in the front but nothing too crazy. Running stock suspension and brakes (DS2500 pads, great hybrid pad, wears very quickly on track though).
[E36]1997 BMW M3 Sedan, 5 Speed
[E92]2011 BMW M3 Coupe, DCT |
07-22-2020, 10:51 AM | #687 | |
276
Rep 224
Drives: 2013 e92 M3 ZCP
Tires: Pilot Sport 4S F - 255/35 19 with 15 mm MS spacer R - 275/35 19 no spacer (removed 12mm MS spacer) Will try 10mm spacer in the rear and move 12mm spacer to the front. No rubbing yet in the front with 15mm spacer but will see after it settles. Last edited by Crazy8.M3; 07-24-2020 at 10:46 AM.. |
JBird..165.50 |
08-07-2020, 01:21 PM | #688 |
Rep 4
Hi everyone.
I have been searching quite a bit. I own a e92 m3 with stock suspension ( non edc ). I just ordered 18 inch apex arc 8‘s. 9.5 et22 F and 10.5 et 27. I would love to fit 275/35/18F and 295/35/18R. Will this be plug and play or will it rub? The tires I am planning on running are continental extreme contract sports. I get a huge discount through a friend on the tire. Any advice I would greatly appreciate. |
08-13-2020, 01:04 PM | #689 | |
18
Rep 93
08-29-2020, 09:57 PM | #690 |
Rep 562
I'm running Ohlins coilovers and thinking about a square set of 19in BBS LM-Rs
19x9.5 ET 25 What would be a good tire size? 275/30 all around? Would I need spacers up front? TIA
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
08-30-2020, 02:41 AM | #691 |
1565
Rep 2,870
08-30-2020, 10:27 AM | #692 |
Rep 562
Square set of GTS wheels 18x11 ET 30 Will these fit w/o fender rolling? What tire size?
I'm on OHLINS coilovers
09-04-2020, 12:02 AM | #693 |
Rep 53
Hey I'd appreciate some input.
E90 M3 OEM Style 220m F 19x8.5 OEM Style 220m R 19x9 KW V3 Coilovers (lowest recommended kw setting) 12-12.5mm Rear and 10mm Front? Thanks in advance. |
09-04-2020, 12:18 PM | #694 | |
144
Rep 148
Rears are 9.5, however. Front has a lot more space than the rear.
Mods: Akrapovic Evolution System / AlpineMSS Stage 2 Tune / MCS 2WNR / RTD V4 Carbon SSK + DSSR
09-04-2020, 12:49 PM | #695 | ||
Rep 53
Think I could go 15mm rear and 12.5mm front? Thanks again, Spliffin
Space on Fox E90 M3 / KW V3 / OEM++
09-04-2020, 01:27 PM | #696 | |||
Rep 942
15 front 12 rear will look better. Tons of guys running that exact setup.
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
09-04-2020, 01:27 PM | #697 | ||||
Rep 53
09-05-2020, 06:36 PM | #698 | |
144
Rep 148
I had 265/35 AD08R and rubbed like crazy with a 15mm spacer in the rear, it got better with 12mm. I now have the 265/30 AD08R on -2.2 of camber and have 0 issues.
11-25-2020, 09:27 PM | #699 |
Rep 47
E92 M3 '10
currently have major rubbing on front tires against the back wheel liner. I have a set of BBS CI-R wheels (after checking BBS spec sheet of actual wheel type, it is listed for F8X...) but: would it be 'fixable' so I minimize rubbing with correct alignment and spacers is my question? running KW HAS at very close to ZCP ride height. F: 19x9.5 ET40 running 265/35 and 18mm spacer R: 19x10.5 ET35 w/ 285/35 and 15 mm spacer (seems fine, it's tight but don't expect much rubbing. Could really use any help/ advice! My initial next step would be to get smaller tires (245 seems small-ish for the wheel though). TIA! |
12-08-2020, 07:22 PM | #700 |
Rep 675
2011 ZCP coupe
Dinan Stage 2 suspension ZCP wheels with stock Contis considering PS4S 255/35 + 275/35 (unless someone says "NO! You want this!" and posts up a good reason for "this") spacers: Should I? Opinions welcomed on the tires and spacers
Dinan Stg II Suspension • Remus Race • Gintani CF lip / CF quarter fins • Vorsteiner Type II CF Diffuser • BMW Performance CF Spoiler / black fender gills / black kidney grilles / CF mirror cover • Speed Element GTS CF side skirts • M3 GTS door sills • Lux Angel Eyes • body color reflectors • Alex@Alpine Stg I tune • AA filter
12-08-2020, 10:50 PM | #701 |
Rep 413
I run these specs with 4s without the stage 2 suspension. But I don't see why be issue so much room. Unless u dropped it more than inch up front and like than .5 rears...
12-09-2020, 09:22 AM | #702 |
Rep 675
The Dinan drop is half an inch over the base M3. Since the ZCP is already 10mm lower, the Dinan coils only drop it another 2.7mm past ZCP static height.
12-09-2020, 01:40 PM | #703 | |
Rep 413
Rears like .7 roughly gap. I can measure exactly later but the wheel itself should be fine in those specs on a very slight drop. Michelin are more rounded. If you went any wider on fronts or rears that different story. But again just my 2 cents compared what I have. So I cannot guarantee. Just trying be helpful with 4s on zcp I think if you go back in thread some still do spacers I cannot recall ... on these specs |
