04-03-2022, 07:46 PM | #45 | ||
Rep 5,190
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
sly1types431.50 |
04-05-2022, 01:14 PM | #46 | |
Rep 844
Did you say you heard knocking sound?
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
04-05-2022, 01:51 PM | #47 | |||
Rep 939
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
TopJimmy5516.50 |
04-05-2022, 01:55 PM | #48 | ||
Rep 939
Plan is to have them pull the pan and see what the bearings and rods look like and go from there. I have all the colors of the OE rod bearings ordered. I don't want to risk driving it around and ruining the crank or block. This car is will be hitting the track for 20-30 sessions and i don't want to risk it.
04-07-2022, 04:09 PM | #50 |
Rep 939
Nope, looked great when it was draining. This is all metal that didn't make it through the filter…so the filter was doing it's job
04-08-2022, 01:49 PM | #52 |
Rep 844
I've seen and heard it looks normal.
If you were messing things up you would have started knocking already. the moment you get metal to metal contact it's done. You will hear it. If you do take things apart. Make sure those rod bolts are not one time use stretch to yield... I've seen people take bearings out and they look fine but, people start fear mongering look how scuffed etc etc.Uhhhm, Its a bearing.... They all look like that. It's fine. As long as there is no copper flake you're good. Or simply drag your nail across the bearing if it doesn't catch your good. GL. But, think you'll be fine with the oil change. Cheers!
04-08-2022, 04:15 PM | #53 |
Rep 939
Maybe this is "normal" as the engine gets older. This is what blackstone said. I took a baby spoon and shoveled like 10 scoops the metal oil in the sample jar.
Not sure what my plan is now
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ Last edited by sly1types; 04-08-2022 at 04:38 PM.. |
04-08-2022, 05:54 PM | #54 | |
Rep 405
(Not that I have any idea what’s going on in your engine of course) |
04-18-2022, 08:55 PM | #55 |
Rep 939
So here is what the bearings look like and here is my oil history.
04-18-2022, 09:09 PM | #56 |
Rep 405
That discoloration looks like the same stuff we E9x folks observed that turned out to be superficial – i.e. not "the last layer before they spin."
If you / your boy still has those bearings, try sanding down the discolored parts. I bet the discoloration will go away before you hit copper. |
04-19-2022, 12:43 PM | #57 |
Rep 1,007
TractionControlDelete4602.50 |
05-19-2022, 09:44 AM | #58 |
Rep 764
great thread with a lot of good posters here. I'm on my 3 S55 motor (1 m3 and 2 M2 comps) never thought much into this but having now had a few new high performance cars and taking apart their filters from the first oil changes to see a lot of metal shaving in the filter pleats,, its a little scary. But we all understand this is normal but there shouldn't be any more after the 2nd or 3rd oil change..... Which leads me to my newest 2020 M2 Comp that had 11k miles and 2 pervious oil changes before my 3rd. Today we opened up the filter and seen a small metal flakes in the pleats, and they are magnetic. One would think there wouldn't be any metal flakes at 12k miles and 3 oil changes so I'm a bit concerned. Going to purchase another oil filter and see what it looks like after 500 miles.
07-05-2022, 04:10 PM | #59 |
Rep 5
please advise rod bearing bolt torque, was trying to find out bolt torque value but but w/o successful result. I will do rod bearing inspection and if bearing are good will put them back with same bolts. please advise if you know required tension.
07-05-2022, 04:23 PM | #60 | |
Rep 6,733
Do it right or don’t do it at all. You can find torque + angle through ISTA IIRC |
07-05-2022, 06:37 PM | #61 |
Rep 10,723
Drives: M4 CS. Former G82, x2 F82, F80
Shows you how reliable the S55 is when we need to start bringing up rod bearings in a quest for something to worry about.
This ain't the S54 (even the issues with that motor are vastly overstated). Relax. |
spidy512502.00 Drifter2090913.50 |
07-05-2022, 10:32 PM | #62 |
Rep 6,733
07-06-2022, 02:00 AM | #63 | |
Rep 5
many thanks for reply. will try to describe reason, the car has 12k miles, I owner, so car engine was tested on auction if it runs or not and due to car was w/o thermostat during start all oil was thrown out, as I assume engine was running few seconds but enough for doubts, after purchase when I drain remaining oil there was about 2 ltr of old oil.... after oil and filter replacement car was running 50 km or less. I open engine cover due to valvetronic motor has fault. we found that intake camshaft needs replacement, however oil filter is clean w/o any metal particles. that's why I want to know condition of rod bearings. |
07-06-2022, 02:25 AM | #64 | |
Rep 405
07-06-2022, 02:46 PM | #65 | |
Rep 6,733
07-06-2022, 03:05 PM | #66 | |
Rep 3,548
TopJimmy5516.50 imperfectluck429.50 |
