11-28-2016, 11:30 AM | #89 | |
67
Rep 179
1 x Genuine BMW Connecting Support - 33312284647 6 x Genuine BMW Star-Socket Screw - 07119907189 1 x Genuine BMW Tension Strut – 33316797444 1 x Genuine BMW Push Rod Left – 33326793651 1 x Genuine BMW Push Rod Right – 33326793652 2 x Genuine BMW Torx Bolt – 33306861221 Total is $188.36 from getbwmparts.com. BeePee you have both F80 plate and V-brace - how much harsher is the ride on bumpy roads? |
kevinjt151.50 |
11-28-2016, 12:35 PM | #90 | |
Rep 4,518
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
kevinjt151.50 |
11-29-2016, 07:37 AM | #91 | |
152
Rep 352
01-08-2017, 10:01 PM | #92 |
Rep 499
We have someone in comment 68 saying the F32 brace creates more harshness and someone in comment 90 saying less harshness.
Has anyone else installed the F32 brace in their F30 and would like to chime in on their experience? |
motorwerkeman160.00 |
01-09-2017, 01:06 AM | #93 |
Rep 1,291
I have, and to be honest doesn't make a significant difference for me;
But my feedback is affected by two considerations: 1: i have the f80 plate on top of that, and i had the f80 plate only before that. 2: having stiffer anti roll bars installed, more subtle effects from braces are probably less noticeable. |
01-17-2017, 09:35 AM | #94 |
253
Rep 203
Anyone try one of these reinforcement plates on an F36 gran coupe with x-drive? Any noticeable difference?
Does this help at all with steering feel or moreso with body roll? |
01-17-2017, 06:27 PM | #95 |
2006 TIME Person Of The Year
9720
Rep 6,445
No X-Drive here but I do have chassis reinforcements installed. The benefits are for the most part, neither of what you mention. The main benefit is stability during cornering. A great example would be a hitting bumps during sustained cornering. The stiffer chassis will enable the car to hold its line better in these situations.
01-18-2017, 10:48 AM | #96 | |
253
Rep 203
01-28-2017, 11:00 AM | #98 | |
16
Rep 57
01-28-2017, 04:06 PM | #99 |
Rep 3,540
Smee505.00 mixmastermike55.00 |
10-03-2018, 06:11 PM | #100 | |
Rep 5,457
Drives: F30
10-04-2018, 06:32 AM | #101 |
No 55mph
1622
Rep 8,476
I wouldn't even bother with the CPM plate as the OEM plate is $20 max (I paid $15 for mine) - OEM plate is more than adequate...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-04-2018, 06:41 AM | #102 | |
Rep 5,457
Drives: F30
Can someone confirm 33312284647 is the correct part number? |
10-19-2018, 10:57 PM | #103 | |
Rep 5,457
Drives: F30
Any chance you have the part number? |
10-25-2018, 10:39 AM | #104 |
16
Rep 132
questions on rear brace for 2014 335Xi
I have a stock suspension 335Xi (with Dinan engine mods) and don't know if the rear stiffener would by itself substantially benefit my car. Does it require a new exhaust hanger? And what/where is the V brace? Is V brace stock on my car? Also, some of you have OEM part numbers. Does BMW sell this rear plate as an option? Some pictures for a 335 Xi might help me.
I plan at some point to buy Dinan shockware which modifies the OEM shock settings to stiffer in both comfort and sport modes. I might also get Dinan springs and bump stops. And the Run Flats will go away! But I only drive street. No racing. Thanks for thoughts. |
06-27-2022, 02:31 AM | #105 |
Rep 955
Old topic revival time! I am about a week or two out from DIYing this. Slight novice here, but I'm not stupid and this looks like a very easy install.
a) Can this be done on ramps? When the car is sitting on its wheels do the push rods (left / right) bare any weight? b) Anyone know the torque for the bolts that go through the push rod and the large bushing? Thanks! |
06-27-2022, 12:22 PM | #106 | |
Rep 3,540
06-27-2022, 04:58 PM | #107 | |
Rep 955
thanks for reaching out.
im talking about the v brace mainly. my 2012 prod 335 didnt come with the v brace in there at all. so i need to replace the two carriers that sit on top of the 2 front rear axel bushings as well. i figured the plate is an easy install on ramps, but i am talking about releasing the bushing bolts while the car is on its wheels. one at a time, but still... torque spec i found... bmw lists the bolt that goes through the rear axel bushings at 108 nm. at least for my vin. ps : by carrier i mean : https://static.schmiedmann.dk/Produc...367598_big.jpg Quote:
07-01-2022, 02:25 PM | #108 | |
55
Rep 99
I'm running B8's with F80 Springs (MA/MR) H&R front sway bar and BMW 15mm rear. Adjustable end links and SPL bump steer/tie rod ends. One of the best decisions I made was to switch to a 245/40/18 set up |
03-09-2023, 10:12 PM | #109 |
Rep 13
For people who've done this, would you be kind enough to drop all of torque specs for this install on f30? I saw @[FaRKle!]'s specs, however I think they're still a few missing? Hard to keep track. Thanks!
03-10-2023, 10:56 AM | #110 |
16
Rep 132
cansomeone advise if a rear "strut bar" is useful and how difficult to install?
I know it isn't a strut in the rear ...the one I added in the front - a true strut bar-- helped somewhat. I would imagine a rear reinforcement bar would reduce understeer, if have any effect.
Thanks. Charlie |
