ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      03-18-2018, 08:38 PM   #89
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Just dropped in here to see what you've been up to Matt. Exemplary work mate. Very bloody nice indeed. I love how your doing everything mostly yourself and I love your attention to detail/skills.
Off topic question if I may please, that blue bike you've got in your workshop, is that a Benelli?
Love where your taking this project mate.
      03-19-2018, 12:09 PM   #90
mattfwalters
mattfwalters's Avatar
226
Drives: 06 Z4MC (Sepang/Sepang/insane)
Originally Posted by Sliktop View Post
What are the part numbers on the offset GC FCABS? I want to order them asap if they exist.
Sweet build thread, btw!
I'm actually not sure - I just traded emails with Donavan at GC and he's shipped out replacements. They may actually not be offset (i.e. they will be 66mm OD + 22mm ID, but might be centered), but I think the offset only serves to increase caster by a little bit. Given the car's focus, I'm not too worried about caster - decreased resistance to high-speed steering input doesn't bother me.
And thanks!
      03-19-2018, 12:13 PM   #91
mattfwalters
226
Thanks! This is a pretty big learning experience for me, but hopefully the cost of that learning will only be my time. The proof will be when the bloody thing finally starts...
The blue bike is a '77 Honda CB400F - it's a parts donor for the crashed black '76 CB400F beside it. The crashed bike was one that I did a frame-up ~restoration on as a 40th birthday present for my wife, which turned out to be a shitty present since it tried to kill her. Long story but she's fine now.
      03-19-2018, 06:18 PM   #92
vbelsky
Drives: 2003 3.0i 6MT
Phew, I was worried I'd see some bagged stance garbage when I read the title. Nice build!
Originally Posted by jns_e85 View Post
Gasket selection matters! I have done numerous VCG on a variety of BMWs and when I did the valve adjustment on my M I also replaced the VCG. At a friend's recommendation, I got the Victor Reinz VCG. After installing it, there was a slow leak in the back off one of the half moons. Annoyed at myself, I reinstalled it, and it continued to leak. Then I tried again with a high degree of James May OCD on doing it proper, anddddd still leaked.
Pissed I ran to the dealer and bought an OEM gasket, and wouldn't you know it, no more leaks!
Elring or nothing.
      03-21-2018, 12:24 AM   #93
mattfwalters
226
Elring or nothing.
Yeah, not my style. I appreciate the aesthetic, honestly, but I prefer things that are fast.
Turns out the GC 66mm / 22mm bushings are not offset, for those who were curious. They showed up today.
      04-08-2018, 01:54 PM   #94
mattfwalters
226
Home again, home again. Jiggity-jig.
Yesterday was a Good Day.
Appreciate 4
SaltyNC369.50
Azeka1285.50
ZAR4MC93.00
      04-08-2018, 11:47 PM   #95
StickMon
My other car is on Mars
StickMon's Avatar
Drives: 2006 MR
Giggity!!
Where did you get the Vanos accumulator line?
Warning: May contain traces of nuts.
      04-10-2018, 08:25 PM   #96
mattfwalters
226
Originally Posted by StickMon View Post
Giggity!!
Pretty sure that's a Bimmerworld piece.
StickMon636.00
      04-23-2018, 01:38 AM   #97
mattfwalters
226
Lots of little stuff done in the past couple of weeks while:
* Fixed the strut tower load-spreaders
* Replaced the idler / tensioner pulleys
* Installed / wired the starter
* Installed the front rotors and calipers
* Installed the steering column
* Installed water temp sensor
* Installed serpentine belt
* Installed front exhaust header
...the slow march of progress...
Azeka1285.50
wdb4732.00
      04-29-2018, 08:46 PM   #98
mattfwalters
226
Some progress today. I guess "RTS" is officially not an option:
I left the front / top portions of the support in place because they hold the bumper. This gives me an excellent view of the space I have to work with, though, so I think I'll probably get the splitter sorted next - should help me understand exactly how much space I have to package everything and sort out some nice, smooth, laminar-flow-allowing curved ductwork.
And then the oil system.
And then start the goddamned thing already.
ZAR4MC93.00
      04-29-2018, 09:21 PM   #99
dre99gsx
Drives: 1994 Toyota Supra
Yeah, I once did a project that was shiny and clean! That won't last long
Great progress! Get it done so you can drive it already
      06-11-2018, 01:36 AM   #100
mattfwalters
226
Well, productive weekend.
Got the radiator in place and mocked up some brackets for the oil cooler:
Found the power steering radiator a cute little home:
Made a bunch of -10AN hoses, figured out where the oil cooler thermostat lives, and got a bit unhappy with how close the lines run to the CSL airbox :
Super, super thanks to my buddy Chris for spending the weekend with me on this. Making hoses with the two-piece AN fittings is both easier than I thought and a complete bastard of a way to spend a day.
Have some 45 and 30 degree fittings coming to replace the straight fittings currently attached to the oil cooler outlet / inlet on the oil filter block - the hoses foul the underside of the airbox a bit, so I want to gently arc them over the alternator. Everything otherwise clears the airbox and other stuff, so I just need to make some nice brackets and line holders, get decent fasteners for the radiators, and tie the bottom brackets for the oil / PS coolers to the bottom of the rad brace.
Also got irritated with the stock fan shroud, so I ordered a SPAL 16" high-flow unit.
Nowhere near as fancy as I'd thought I might have to get for the radiators. Everything packages nicely there, even the oil accumulator - it looks like it should foul the inside of the bumper there, but unless I'm greatly mistaken it will sit right in behind the kidney grilles, snug as a bug in a rug.
wdb4732.00
      06-11-2018, 04:01 PM   #101
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Nice work!
A larger oil cooler is my next upgrade. What model are you using by chance? Looks like a Setrab but curious as to the size.
      06-11-2018, 08:03 PM   #102
mattfwalters
226
Originally Posted by longress View Post
Nice work!
Thanks - lots still to do in here for sure, but it feels really good to have the oil system nearly plumbed.
The cooler is indeed a Setrab, specifically the 50-650-7612 (6 series, 50-row). I selected it based on packaging, cooling capacity, and incredibly low pressure drop (1.1-1.8 PSI) it provides.
      06-11-2018, 08:25 PM   #103
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Looks good. Will be curious to hear how that oil accumulator works out.
      06-11-2018, 09:24 PM   #104
mattfwalters
226
It will at least keep the engine first start from being dry... we'll see after that.
      08-05-2018, 12:06 AM   #105
mattfwalters
226
Progress! Again.
I strapped the fan onto the front of the rad, plumbed the rad, found a better arrangement for the oil cooler and PS cooler, and realized it opened up a nice space in around the radiators for the oil accumulator!
This means I'll be replacing the hood latch support hoop with the brackets and braces I'm going to build for the radiators, along with a bracket for the oil cooler thermostat. I am decided: the accumulator is getting a remote-switched solenoid valve so that I can put a fuckoff-bright LED on the switch that will warn me if the ignition is on but the accumulator valve is closed.
Behold, a fully plumbed water and oil system!
wdb4732.00
      08-05-2018, 10:15 PM   #106
mattfwalters
226
Started fabricating the actual support for the bumper, radiators, and accumulator:
I'll be running tubing from this front support structure around the radiator for lower supports; haven't quite sorted upper rad support yet but I don't think it'll be much trouble compared to this part. I will use the bottom of this structure as the main attachment point for the splitter.
Also sorted out what was causing my issues with the TIG torch (me) so the welding is going much more smoothly than the last few times I've attempted to make multiple pieces of metal into a single piece.
ZAR4MC93.00
longress104.50
      08-07-2018, 01:45 AM   #107
mattfwalters
226
Spent another hour and a half on this tonight:
Next I'll notch this brace so the cooler frame fits into it, and then add the lower radiator brackets and tie them in to the frame. Then the oil accumulator supports.
THEN MAYBE I'LL START THE @$^#$&$#^
Appreciate 3
Mirko182.00
SaltyNC369.50
      08-29-2018, 11:58 AM   #108
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Been away for awhile. Nice to see the progress. Can't wait to see the finished product.
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete
      11-06-2018, 10:26 AM   #109
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
What's the latest??
Racerbruce
      11-07-2018, 07:56 AM   #110
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Originally Posted by racerbruce View Post
What's the latest??
^ WHS
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
zpost
