07-25-2023, 09:32 AM | #1 |
Rep 62
Reset Engine Adaptations
I just replaced the plugs and coils with Bosch plugs and Dinan coils, and also replaced the charge pipes and intakes with the Burger Motorsports package.
I'm seeing a slight rpm fluctuation at idle, and have already cleaned the MAF sensors. One post mentioned resetting the engine adaptations with INSTA. I also found that resetting these could produce a lot of short term strange behavior, so I didn't do it without getting some feedback first. There was one option in INSTA for the engine electronics and another for the flywheel. Is this worth doing or should I just let the car adapt naturally? Thanks! |
07-26-2023, 03:30 AM | #2 | |
Rep 9
If above are checked okay, you can temporarily restrict the cone with a towel in the garage and monitor the Idle for change. I also replaced with Dinan coil, plugs and charge pipe. Getting better charge pipe clamps with proper fitment for silicon hose was a challenge. T-bolts are too wide, norma is too weak, worm gear will cut through the silicone. Good luck and enjoy your ride. |
adaptations, engine adaptations, idle fluctuations, o2 adaptations |
