PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
OFFICIAL THREAD: Forgestar F14 Super Deep Concave
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
12-15-2015, 10:01 PM | #23 |
Reborn
87
Rep 1,217
You have an E90 which has more room than those of us E92 guys.
12-16-2015, 07:03 PM | #24 | |
Rep 5,120
E90 lci has less clearance and needs 8mm higher offset on the rear because the rear track is wider. |
01-01-2016, 09:40 AM | #26 | |
Rep 8,339
I'm trying to do 305s on the rear on 19x11s and the 245s will match better.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
01-01-2016, 10:00 AM | #27 |
Rep 1,602
That tire will fit but will be a bit stretched on a 9.5" rim. I run a 8.5 width rim with that size on a ET35 though could go more aggressive on the offset.
01-01-2016, 10:04 AM | #28 |
Rep 8,339
I figure these guys are running 235 and 225 on these so 245 might work. It's the max width wheel listed by the makers for 245 also so I figure it'll still be safe at very high speed, which I will be doing. Right now I have 19x8.5 et 30 front with 235/35-19 if they're running the same tire et 25 on 9.5 wheels maybe 19x9.5 et 30 would work with a 245.
01-01-2016, 11:09 AM | #29 | |
Rep 551
Apex EC-7 - Black Front - 18x9 - ET 31 / 245/40/18 Rear - 18x10 - ET 43 with 5mm spacer = ET38 / 285/35/18 the fronts rubbed away 1/16" of the front bumper plastic lip(inside) on dips, now its great no front rubbing, rear hardly mounted without spacers due to a suspension arm that is well out of the way when the suspension compresses, but it looks much better with a 5mm spacer, but rubs on large dips and leave no marks, but a slight rear fender roll would fix this. |
01-01-2016, 11:34 AM | #30 |
oG
56
Rep 487
I need to see more of an e90 335i LCI alpine white msport with these installed please! Anyone?
01-01-2016, 11:47 AM | #31 |
Rep 8,339
Gonna have a wheel guy see my actual car and find out what I can get away with. Front I want them to be as far out without rubbing. Rear as far in as I'm going to have to modify the quarters to fit and I want to do as little as possible.
01-01-2016, 12:05 PM | #32 | |
Rep 5,120
I would say 245/35/19 9.5et30 would work on an e90 or e91 at stock camber with minimal effort. On an e92 or e93 I would worry about breaking the plastic fenders so I recommend 235/35/19. Another thing to consider is if you are using coilovers they might not clear the front with 9.5et30 because they are wider than stock struts. I would recommend et26-28 with a little bit of negative camber. |
01-01-2016, 12:28 PM | #33 | |
Rep 8,339
01-01-2016, 04:51 PM | #34 | |
Rep 5,120
01-01-2016, 05:51 PM | #35 |
Rep 8,339
Yeah. I'm not looking for stretch. I'm looking for steamroller. My 8.5" 30 offset wheels now with 235 barely clear. I'm thinking 245 on a 9.5 the tread will be 1/4" back on the rim edge from my current setup, 6mm, so I can go 4-5mm out more, less offset, and be OK.
01-01-2016, 11:37 PM | #36 | |
Rep 5,120
http://www.willtheyfit.com/index.php...et2=28#content |
01-13-2016, 04:09 PM | #39 | |
Rep 462
Does anyone know, do they still do polished finish? Anyone know how much $$ they charge for that finish? |
01-15-2016, 10:22 AM | #40 |
83
Rep 240
You get one style, I'll get the other style, and if we both wish we got the opposite color, we pay shipping to each other?
01-15-2016, 10:51 AM | #41 |
Rep 462
01-15-2016, 01:33 PM | #42 |
83
Rep 240
I'm actually wanting 18s to stay reasonable, but I'm not sure the 18s are as deep as I want them. I may be forced to go 19. I had 19s on my G37, and the tires weren't too bad. $650 for a set of Potenzas.
01-29-2016, 11:59 PM | #43 |
41
Rep 263
Drives: 2012 N55 E92 335i M Sport 6MT
