11-15-2009, 09:39 AM | #67 |
Bates '08 Interlagos Launch
126
Rep 1,230
Sounds a bit snappy like my car does. You should be really happy with the results!
Did you restuff it before bringing it to the welder?
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 |
11-15-2009, 11:02 AM | #68 | |
61
Rep 335
I did re-stuff the chambers. Actually, in my last video, the chambers are already packed. |
11-15-2009, 01:47 PM | #71 |
61
Rep 335
11-15-2009, 01:48 PM | #72 |
61
Rep 335
11-15-2009, 04:38 PM | #73 |
126
Rep 1,230
I bet it would gain a couple HP at least. More if you swapped the perforated pipe with a sealed one.
11-16-2009, 01:05 AM | #75 |
Rep 1,447
Nice project! Sounds pretty good.
Khalid
'12 BMW E92 M3 '03 BMW E46 M3 '14 Mercedes-Benz S400 '18 Alfa Romeo Giulia Quadrifoglio |
11-16-2009, 09:30 AM | #77 |
61
Rep 335
You are so right, check this pic out! This is just one side!
11-16-2009, 10:47 AM | #78 |
35
Rep 304
Great job! Now I just need to get the balls to do this myself! Haha! A+++++ work there! Thanks for spearheading it in the community.
2002 E39 M5
11-16-2009, 11:13 AM | #79 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
very nice i like it
11-16-2009, 01:29 PM | #80 |
18
Rep 182
I think Im gonna do the same thig, but cut the preforated pipe out completely and replace it with a new, non-pref. piece.
Nice work by the way... so the big question, any drone???? and compared to stock, on a scale of 1-10 (1 being stock) how much louder? |
11-16-2009, 01:31 PM | #81 |
9599
Rep 10,891
I think you could make a nice wig from that!
11-16-2009, 01:47 PM | #82 | |
126
Rep 1,230
Its like Christmas when you first turn it on after you get it back on Perio. Have fun with that! And there better be good in/out running videos or.... I was thinking that it would be neat to have a manual slider that would uncover the perforations.. Imagine a sleeve that you could pop over the pipe, then reconnect again with a couple screws. It would be allowed to slide and have a lever protruding outside of the exhaust that would simply let you slide it back and forth, maybe with a set screw to hold its place.. let me photoshop something quick. What about this.. would require a couple small holes in the back of the exhaust. You could cover the smaller sections, as pictured, or maybe part of the larger ones if there is room. Challenging parts would be making sure the packing wouldnt interfere over time and finding some way to lightly seal the sliding sleeve on both ends so there is little leaking when its closed. not as slick as my electronic valves (if I may say so! ) but I bet it would work!
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 Last edited by Subw00er; 11-16-2009 at 02:44 PM.. |
11-16-2009, 01:50 PM | #83 | |
61
Rep 335
No idea on drone yet. I am having the system welded and will then do some road testing. |
11-16-2009, 03:04 PM | #84 | |
61
Rep 335
Also, your diagram only shows the covering for the smaller holes, which are the ones I left open. You'd need to close the pipes that have more perforations and those holes go the entire length of the pipe within the chamber so it wouldn't work there. |
11-17-2009, 12:57 PM | #85 |
126
Rep 1,230
Ya, I already said that! I think you could engineer around both problems without too much trouble though. I drew it on the smaller holes, which I still think would make a noticeable difference to noise, but you could do it on the larger holes as well - possibly with a dual layered sleeve if there was not enough sliding room. Hey, If it was easy, everyone would do it, right? I was just throwing an idea out there. I know it would work.
When will your welding be done btw?
