Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 1
      06-20-2014, 07:06 PM   #1
boostjustkickedin
Drives: 6MT, 135i, N54
Question 1
      06-20-2014, 07:36 PM   #2
Miller335
291
Drives: 2007 E92
I see what you're saying about the throttle in the graph.
Just a shot in the dark but have you tried reset throttle adaptions.
      06-20-2014, 08:55 PM   #3
boostjustkickedin
good call....I haven't tried it...I haven't got INPA up and running yet, doing it right now
How to I reset throttle adaptations?
      06-20-2014, 09:12 PM   #4
Miller335
291
Drives: 2007 E92
BT cable/software can also reset just throttle adaptions and menu option 1-7 on JB4 will reset all adaptions.
Your idle may go wacky when you do this.
If it does, just shut off engine, turn ignition back on and hold throttle WOT for 30 seconds.
After that just start the car back up and the cars idle should be fine.
      06-20-2014, 09:32 PM   #5
11SEC
Drives: E92 335i
Make sure you do 1-7 with just the ignition on.
      06-20-2014, 09:33 PM   #6
11SEC
Drives: E92 335i
I think it has something to do with your auto shift reduction setting
      06-22-2014, 05:40 AM   #7
3000GT MR
3000GT MR's Avatar
Drives: 09 335i/3000gt vr4
From my experience from being stock, piggybacked, or ST'ed it seems that the logic in the dme does this on purpose only when you are within a couple hundred RPM of redline. It's almost like another over engineered logic to either reduce spikes at the turbos or run some cooler air thru the engine after a high load pull. I wouldn't worry too much about it.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
      06-22-2014, 12:46 PM   #8
HOTROD329
Drives: 2007 TiAg e90
more info on the boost guage set up? how is it mounted?
      06-22-2014, 10:24 PM   #9
boostjustkickedin
Hey just did it...its still spiking the throttle body open after letting off the accelerator...
      06-22-2014, 10:27 PM   #10
Whiteout335i
30
Drives: 2010 335i alpine white
I have the hks bov and mine blows off twice too under heavy load...im basically stock with just dps and exhaust tho
      06-22-2014, 10:30 PM   #11
boostjustkickedin
I still haven't messed with this parameter.
on a side note, It did it without the JB4...it did exactly what its doing now bone stock!!
I sent terry JB4 all this VIA email, and he confirmed that the jb4 did not have any calibration to remove the throttle body spike...nothing they can do.
I think at this point a reflash of the DME is the only option as it looks like this issue I have might be a feature BMW coded deep into the logic of the DME to reduce boost lag during shifts...it'll always hold 5psi
It's a huge drivability issue for me tho...I really wanna get rid of this
      06-22-2014, 10:56 PM   #12
boostjustkickedin
I hear you....I'm leaning more towards BMW intentionally coded this into the DME's logic to reduce lag between shifts, sort of like a 'No lift shift" setup...
If this is true, I guess a cobb DME reflash would remove this feature?
Or alteast give us access to the throttle body reference maps, in hopes of maybe removing this spike?
      06-22-2014, 10:57 PM   #13
boostjustkickedin
is it not annoying?????
      06-22-2014, 10:58 PM   #14
boostjustkickedin
thanks for the reply guys
Has anyone has any success removing this spike with COBB?
      06-23-2014, 06:16 AM   #15
Tzu
29
Drives: 335i
I spent some tim chasing this a couple years ago. It's some logic in the DME that permits it to happen, and is perfectly normal. I assumed it was for an OEM shift softening technique.
      06-23-2014, 07:17 AM   #16
3000GT MR
3000GT MR's Avatar
I'm not sure if it can be tuned out. If anything PTF would have the knowledge to do so. My compressor surges very little when this happens so what ever it's for its not hurting the turbos.
135i, blow, double, n54
