04-19-2024, 02:51 PM | #1 |
Rep 2
Some black F 1-50 backed into my X3 2018 320i xdrive
What do you boys think? Is it totaled? I know it’s hard to tell from picures, I’m just looking for any opinions. I will have details Monday from the geico adjuster. UPDATE: Adjuster said 2300 and this is before it went to the mechanic. I will keep you boys updated. |
04-19-2024, 04:16 PM | #3 |
Rep 507
This much work, I'd only accept repair via a good BMW dealer, so they can put their seal of approval on the geometry. And a warranty. This doesn't look a small cosmetic job.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
thebigb0.00 |
04-21-2024, 08:13 PM | #11 |
General
17371
Rep 18,772
Not totaled. The light is the expensive part. I'll guess $6,200 repair. Definitely go to a BMW certified body shop.
Westside Guy5825.00 thebigb0.00 |
04-22-2024, 06:24 AM | #12 |
General
17371
Rep 18,772
You may want to look into the lower control arm ball joint. It looks like the rubber boot is split, which will eventually lead to the ball joint wearing out. The split in the boot was not caused by the accident.
thebigb0.00 |
