How to replace LCD on BMW Professional radio
07-29-2015, 02:16 PM | #67 |
Rep 14
I have the same bad lcd panel on my car. Is there a way to tell the difference between the these,
Non I-Drive Business HU (Option 662) Professional HU (Option 663) Do the units in the links above in ebay auctions work for both business and professional head units? |
07-29-2015, 02:42 PM | #68 |
Rep 13,116
Isn't it labled on the front.
Isn't it labled on the front.(upper left corner)
I believe the US only has the Pro Radio. They only time the business radio is mentioned here is when its a Non Us poster. http://www.e90post.com/forums/showthread.php?t=687463 pictures of the business radio in entry 1 and as you can see its labeled and has less selection buttons and a different button layout. If you buy a radio of ebay it needs to be programmed for the sound system and options on your car. There are big threads already explaining this. Also there are variations on the pro radio. http://www.e90post.com/forums/showth...ighlight=Radio Last edited by ctuna; 07-29-2015 at 06:21 PM.. |
03-08-2016, 03:13 PM | #69 |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
Job well done. Smash that appreciate button for BeakerBoy.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
08-19-2016, 12:07 PM | #70 |
Rep 12
Wellps, I did mine and it seemed easy and straightforward, did everything the instructions said however the end result seems to be inverted quadrants.
My guess is one of the connections is backwards but want to make sure it's not a faulty LCD before I pull the unit apart again. Any thoughts? |
02-04-2017, 12:48 PM | #71 | |
Fixing stuff is fun.
15
Rep 26
Thanks for the great DIY! Very easy (if you have soldering tools and skills). |
02-04-2017, 12:52 PM | #72 | |
15
Rep 26
Thanks for the great DIY, I followed it this morning. |
12-16-2017, 09:51 AM | #73 |
10
Rep 47
i did the pixel repair on my e39, but this looks harder and i don't really want to do it.
is there anybody that sells one fixed already that i can just swap in? |
12-16-2017, 11:39 AM | #74 |
Rep 13,116
If you swap radio's there is about a 98 percent chance you
will get a radio that is not programmed for the sound system and option in your car . Better to send the exitsting one to someone that will do the Pixel repair and send it back. Be sure to write down your Serial number if you send it in so you get the same on back. Getting a new one programmed can be a more expensive and convoluted At least the above is the case for all cars past 2005. Last edited by ctuna; 12-16-2017 at 08:04 PM.. |
12-16-2017, 08:07 PM | #76 |
Rep 13,116
There are services on ebay that do it for 150 which is 50 bucks
more than the kit. Repair resources http://cgi.ebay.com/ebaymotors/BMW-C...ioQ5fVideo#ht_ http://www.e90post.com/forums/showth...ighlight=pixel http://www.diyparadise.net/bmw_cd73_repair.html http://www.e90post.com/forums/showthread.php?t=1306708 http://www.bimmerfest.com/forums/sho...d.php?t=761513 Repair http://www.bmwradiorepair.com/?gclid...FccbQgodIEn0Cg http://beckerautosound.com/ http://www.hitechserv.com/electronic...nger-repair/67 http://www.bmwlogicseven.com/?p=3837 http://www.bmwgm5.com/Logic7_6941681.htm https://www.ebay.com/itm/BMW-CD73-PR...-/391232582630 They must have increased there prices 10 bucks. |
02-08-2018, 01:37 PM | #77 | |
Rep 41
10-25-2018, 02:46 PM | #80 |
Rep 1
Hi!
I have done all the procedure and I get this display (background is too orange, it should be more black) https://ibb.co/nzSJ1V What could I have done wrong? I am 99% sure that the orange background is mounted in the right direction, the only thing I noticed is that this orange paper was a little glued to the old LCD. Perhaps I should have mounted it more close (I mounted it on the white support, but it should all close together) or glued it? Last edited by Alvy; 10-25-2018 at 02:52 PM.. |
12-10-2018, 06:24 PM | #82 | ||
Rep 41
I had the problem a few posts back where the second and third quadrants were blinking solid orange while the other quadrants were black. I actually returned the screen and put the old one back. I can barely see the quadrants flashing so they're still there. Maybe I had the iron on the board for too long, I don't know, but now I'm facing another problem. If I have the radio on, the presets will cycle through them in 2-3 second intervals. If a CD, same thing, but tracks. Hot or cold, it's totally random. I don't know if it's the head unit itself or the steering wheel button.
01-01-2020, 03:48 AM | #83 |
Rep 109
Does anyone have a current source for these screens? It seems like all of the vendors mentioned in previous threads have dried up and the only ones I see on eBay are really expensive...
cliffschum15.50 |
04-27-2020, 01:22 AM | #84 |
Rep 93
Drives: 2006 BMW 325i
bump. I'm having trouble finding a company I can ship my radio to, have it repaired professionally, and then have it shipped back to me. any options in 2020? thanks
cliffschum15.50 |
04-27-2020, 01:32 AM | #85 |
Rep 13,116
http://www.bestpixelrepair.com/pixel...r-service.html
https://www.germanaudiotech.com/prod...iant=535851565 If you send it in write your serial number down so you know you got the same one back. |
cliffschum15.50 |
11-16-2020, 08:28 AM | #86 |
78
Rep 239
It seems like the CD73 LCD module is no longer in production. Anyone have a source or advice on upgrading a 2006 model to an LCI radio?
*edit* found this info, but appreciate any other advice: https://www.e90post.com/forums/showthread.php?t=1036190 https://www.e90post.com/forums/showthread.php?t=687463 Last edited by drawz; 11-16-2020 at 12:07 PM.. |
05-22-2022, 04:55 PM | #87 |
16
Rep 78
Pixel repair - updated sources ?
https://www.germanaudiotech.com/prod...iant=535851565 Best pixel is out of stock.. German audio tech charges $350 ! That's as much as a new radio, no ? All other search results I found are out of business, stock, etc. Any other current options ? |
cd73, lcd replacement, pixel fade |
