      09-13-2015, 11:47 AM   #1
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Pic request: M-Sport front fender liner
Hi, I was hoping someone could snap a quick pic of their front fender/wheel well liner. Prefer driver's side with wheels at full-lock left for comparison to my pic below.
I'm looking at doing some brake ducting and want to see how your fender liner differs from mine (non-M-Sport) to allow airflow to the wheel wells, as mine are pretty well enclosed. I suspect yours are shorter or narrower or something, but would like to confirm.
Here's what mine look like:
Thanks!
      09-13-2015, 12:54 PM   #2
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Hope this helps
      09-13-2015, 01:06 PM   #3
3002 tii
3002 tii's Avatar
2288
Drives: Z4 M, X5, GX460
I wonder if you can do a fog delete, run the hoses from fogs to access panel via fender liner and the use a deflector plate of sort to direct the air to rotor (similar to Porsche's). It's not perfect not direct but it's clean and better than factory solution of hitting front of tire.
Follow for latest mods
      09-13-2015, 01:29 PM   #4
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Originally Posted by Kgolf31 View Post
Hope this helps
Thanks! This is super helpful. Is this the brake duct?
If so, is it just one piece (I assume p/n 51748046300, #4 in this diagram) that runs directly to the bumper?
I did do a fog delete, of sorts. Picked up a Performance aero kit - the front bumper does not mount fogs. For the 135i, the bumper has the ability to mount brake ducts. What I'm trying to figure out is why I can't go ahead and mount the Performance ducts - it seems like it should work, assuming I retrofit the appropriate fender liners at the same time.
The other question I have is do the Performance ducts augment or replace the stock ducts? I think they totally replace them.
      09-13-2015, 06:52 PM   #5
135TX
Drives: '11 135i
Yes that is the brake duct, I would just cut out the hole in your existing fender liners, with the exception of the hole they should be identical.
Exhaust, Flash tune, Suspension, LSD, Wheels/tires....
Originally Posted by IEDEI View Post
You'll never regret pursuing what you really want....ever. You will, however, regret NOT doing things you wanted to do.
      09-13-2015, 06:55 PM   #6
135TX
Drives: '11 135i
I'm sure one of us could help you with some rough measurement estimates for placement, however it may be more precise to install the bumper and trace where the ducts touch your liner and then jigsaw, or sawzall the hole out
      09-13-2015, 07:53 PM   #7
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
I remember I had the ducts for my M sport bumper but the hole wasn't there, so I traced with a sharpie where the hole would be, then cut it out with a razor blade
      09-13-2015, 08:37 PM   #8
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Yeah, I might do that. It sounds pretty easy...although, if I'm gonna go through all the trouble of getting the OEM bumper removed to put in the OEM brake ducts, might just spring for the correct OEM fender liners. They don't look too expensive.
What?!? That's crazy. I wonder if they just made a mistake or what. Anyway, how'd you know "where the hole would be?" Could you feel the duct hitting against the fender liner or something?
And, incidentally, I guess even with the factory cutouts, the duct isn't secured to the liner in any way? It just sort of lines up?
      09-14-2015, 07:46 AM   #9
chris82
chris82's Avatar
Drives: 128i
Yea it never had the M sport bumper as a factory option, so when the place I got it from put it on they never cut the hole out. And if you look into the duct you can see it contacting the fender where the hole should be. I traced that then cut it out.
The duct itself has a "leg" that secures itself so it can't move. And the way all the pieces behind the bumper fit together hold it in place. There's only one position for it to go
      09-20-2015, 03:47 PM   #10
Suhb
Suhb's Avatar
119
Drives: 2010 128i Coupe 6-Speed
Bob, don't you have the aero bumper? I was under the impression that the brake ducts were different for the M Sport Bumper and the aero bumper.
      09-25-2015, 09:00 AM   #11
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
I do have the aero bumper, and the brake ducts themselves are different from the M-Sport bumper, but the front fender liners are the same. However, my car came with the Sport Package and thus the standard 128i bumper, so the fender liners are closed. So if I want to fit the aero bumper brake ducts, I also need to retrofit the ducted M-Sport fender liners.
____________________________
      09-27-2015, 09:09 PM   #12
chris82
chris82's Avatar
Drives: 128i
I don't think you need M-Sport fender liners. Just look at where the brake ducts are contacting the fender liner and that's where the hole goes. Trace that and cut the hole out no?
      09-28-2015, 03:37 PM   #13
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Well, yeah, I could just cut my fender liners. I'm just saying that BMW made fender liners with and without the holes precut already.
      04-10-2020, 09:44 AM   #14
carscatscoffee15
carscatscoffee15's Avatar
Drives: BMW 128i ZED Package
Hey! I wanted to know if you found a solution to this as I'm in the same boat. I've been searching threads and threads on this to no avail this is the closest I can get on this subject as I too have a non M sport front bumper
      04-10-2020, 11:25 AM   #15
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
No, I didn't, but I don't remember if I hit technical roadblock, or if it was a time/money thing. Or maybe I just forgot, lol.
Frankly, I don't think brake ducts are strictly necessary for this car, but if it's just a matter of mounting the ductwork and cutting a hole in the fender liner, than it seems easy enough. That way you at least make the Performance Aero bumper functional.
      04-10-2020, 02:19 PM   #16
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
So it looks like if you order the BMW Performance Cold Air Package, you get modified brake ducts that run from the Aero bumper to the wheel wells. If you have an M-Sport car, no problem, you remove the stock air ducts and replace with the new ones. If not, it gets a little trickier. I'm sure there's space to route the new ducting, and as mentioned above, you can either cut holes in your existing fender liners or buy the M-Sport pre-cut versions - but I can't quite figure out where the ducts mount. They each have two tabs with holes for hardware, and I don't know if the non-M cars have the mounting points in place, or if we need to add a bracket or something. It's times like this that I sort of hate how sealed off the undercarriage is - I'm going to need to remove the splash guard and/or fender liner just to take a peek.
The other issue is money. The stock M-Sport ducts are about $11 apiece. The Cold Air Package is >$260!. Kind of crazy. It also includes new ducting for the 135i oil cooler, but obviously we don't need that part, and the individual kit components cannot be ordered separately.
      04-13-2020, 04:05 PM   #17
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
Not to be pedantic, but I paid $37.08 for the duct just to replace the stupid little rubber piece that I lost and can't buy separately.
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      04-13-2020, 04:22 PM   #18
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Yeah, I think I actually got the $11.00 figure from RealOEM, which of course is not reflective of current market value. I should've plugged the part number into a vendor's site.
      04-13-2020, 04:34 PM   #19
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
I only mention it because it pissed me off. Well, I pissed me off for losing it.
      04-13-2020, 09:15 PM   #20
carscatscoffee15
the kit I ordered from ECS tuning has these included so no issues there
I just need to get the wheel liners from either the 135i or F30 (I've seen people use these on E82s but I wonder what the difference is)
Mods Done: AA Exhaust/Headers | 3SIM | MILVs | StageFP Dyno Tuned | Euro Box Intake Swap | LCI Blackline Tailights | OEM Euro Bi-Xenon Swap from Halogen | Rear Bumper M-Sport Swap | Rear PDC Retrofit | BMW OEM CF Diffuser/Spoiler | BMW Front Aero Kit | Supersprint Sec 1 Cat Delete Straight Pipes
To Do: Ohlins R n T Suspension | Front/Rear Sway Bars | M3 Front Control Arms/Bushings
Eventually: AT -> MT Swap (!?)
      02-20-2024, 01:50 PM   #21
Jay15180
14
Drives: BMW 128i
Pardon the bump of this old thread. Does anyone know whether the M sport ducts require a bracket for installation in a non m sport 128i? I already retrofitted an m sport bumper previously and will be cutting holes in my fender liners to accommodate the ducts.
      02-22-2024, 03:59 PM   #22
spidertri
spidertri's Avatar
Drives: 11 128i 6MT Sport
2011 BMW 128i  [0.00]
I installed the 135i M sport bumper on my non-M sport 128i. The brake ducts do rely on the outer pieces inside the bumper to mount. So on the driver side, there's like a closed scoop part (51748046473) and on the passenger side the brake duct uses the oil cooler duct (51748046326) to mount.
I don't have the passenger side oil cooler on my 128i so I used some black plastic sheet to fab up a mounting solution for the passenger side brake duct.
I've searched but never found a blank closed scoop part for the passenger side of the bumper, I think all 135i came with the oil cooler.
11 128i slicktop
13 WK2
19 Alltrack S
