Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > eBay Bluetooth Streaming Box DIY and Reveiw
      05-28-2018, 02:42 PM   #23
neopolymath
neopolymath's Avatar
Drives: 2006 BMW 330i
Originally Posted by Nickco43 View Post
I want to clean up the DIY a bit more and take a demo video. Apparently both the SD card and USB work for playback but I have not used them yet.
Please let me know if you end up testing the SD card slot and the USB. I mainly want to know if it will display track info if connected via usb. Thank you for the documentation. I really appreciate it. This looks like it is the solution for us 06 people!
      05-28-2018, 03:33 PM   #24
ctuna
Drives: 325xi 06 wagon MT
BMW aux is definitely the gating point on high quality audio.
Some have applied DAC's to improve it but it seems to still fall short
of USB in. It would be nice if this module used aptx for streaming.
      05-28-2018, 04:15 PM   #25
bluewater328
Drives: 2011 bluewater 328i LCI sedan
I’ve actual contemplated using a power adapter to use one of these units:
https://www.crutchfield.com/p_772B1A...engine-B1.html
      05-28-2018, 04:34 PM   #26
gamesfrager
198
Drives: 2011 328i
Hi, Nickco43
I do have one question though, can it stream from Android and retain steering wheel previous/next functions? I don't care much for title or artis name, that's just a nice added bonus. Thanks.
      05-28-2018, 04:47 PM   #27
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
I tried playing audio through USB on an iPhone 6 and my pixel 2 XL it would not work. I can test if it works with a USB drive with mp3s on it. I Bluetooth audio shows track names or whatever your playing. Even shows text for a YT video or a radio stream on tune in.
Originally Posted by gamesfrager View Post
Hi, Nickco43
Steering wheel controls work with my phone connected over Bluetooth.
The listing says it uses A2DP
      05-28-2018, 05:12 PM   #28
ctuna
Playing a usb stick or sd would not be considered a2dp(bluetooth streaming) nor
would hooking your phone up via a usb cable.
Add says wireless streaaming which is A2dp also you had pairing
pictures up and said you were using the BMW oem phone bluetooth
for phone only .
So I am confused by your last statement.
Plays usb with a usb stick = great
play with power chord attached to usb = great
wireless streaming?(which would mean no chords attached )
"I tried streaming audio on an iPhone 6 and my pixel 2 XL it would
not work"
I thought you said it has worked with your Pixel for streaming.
"Bluetooth off my phone sounds comparable to a CD. Steering wheel controls work fine. I can stream music from Apple Music and Tune in. I can't comment on the calling function of the box since I don't need to use it. If you knew what you were doing and have a coding laptop ready to go this install should take maybe an hour. "
How was it hooked up when you did the above ?
On bluetooth phones have both a media and phone option when
paired at the phone end they both have to be on?
      05-28-2018, 08:27 PM   #29
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
for phone only .
not work"
I rushed that reply and made a logical error.
I have a pixel 2 XL that I have hooked up with Bluetooth audio streaming using the eBay box. Phone calls go through the OEM bluetooth calling box. Bluetooth audio streaming has working steering wheel controls and CD quality audio. Dip 4 on the back of the box removes the calling functionality of the eBay box.
I made a demo video of this at the end of the OP.
I tried playing music with my pixel through USB with the eBay box and it did not work. It is only intended to charge a phone or play music off a USB drive.
      05-28-2018, 10:18 PM   #30
bluewater328
probably means it can’t handle full hdds or its looking for a simple file system format like fat32.
glad that you can pick and choose which BT functions it uses as I think you made a good call there in the config.
ATP-X codec via A2DP would have this thing on my Buy Now list. Otherwise, if the radio controls/display and steering wheel functions are working, it’s still a great piece that leaves the headunit DAC as the weak point, which at least is consistent.
      05-29-2018, 09:23 AM   #31
PaKii94
9
Drives: BMW 335D
That was the board recommended unit until the firefly came along.
I actually just bought this to try it out: https://www.ebay.com/itm/Bluetooth-5...D/273161931903
It supports up to aptx HD and the dac on there got good reviews on other devices.
I wish these CD boxes had aptx also
      05-29-2018, 09:36 PM   #32
bluewater328
Well, my gripe with Firefly is the same with Tune2Air and that's the DAC and the reprocessing by way of the aux to the radio and back out.
I'm always a little weary of something that has a coax or split plug out vs the straight RCAs but that looks like it fits the bill decently. I was trying to dig, but it wasn't obvious: which DAC does it have? AK or Sabre? How do you like it?
      05-29-2018, 10:03 PM   #33
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I bought these:
https://www.ebay.com/itm/KKmoon-USB-...53.m2749.l2649
https://www.ebay.com/itm/USB-A-Male-...53.m2749.l2649
and a used OEM BMW Aux + USB port with cable to see if I can have a functional usb port in the center console.
      05-29-2018, 11:23 PM   #34
neopolymath
I love where this thread is going. Looks like I have a fun summer project to do now.
      05-30-2018, 10:44 AM   #35
PaKii94
9
Drives: BMW 335D
There are similar models with RCA out if you want. I haven't gotten it yet. It's coming from china so it'll take forever (estimate is June 2 to June 22)
The DAC is PCM5102. It's used in Arcam products like I mentioned before. Here is a review: http://www.portablehifi.com/arcam-rb...rblink-review/
I guess there is quality dangers to the Chinese implementation but it costs <20% of what the rblink costs
PORTMOODY140.50
      05-30-2018, 11:40 AM   #36
bluewater328
I bought these:
Could you explain your install a bit more?
      05-30-2018, 01:21 PM   #37
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I am going to see if I can hook up the OEM USB port to the box with that ebay cable and the adapter.
Update: There is a Navi car with the same interior is my car at the junkyard. Hopefully everything is still good so I can do the idrive swap for pennies.
      05-31-2018, 01:33 AM   #38
bluewater328
While the Navi would certainly be cool and undoubtedly tons of effort, therre’s a side if me that would prefer to see your lab results with the usb experiment.
      05-31-2018, 11:55 AM   #39
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I already ordered the parts for the USB
Today I raided my local pick and pull and got 95% idrive swap and a full rear folding seat retrofit for $140. It's a CCC but a damn good deal.
      05-31-2018, 03:38 PM   #40
PaKii94
9
Drives: BMW 335D
nice haul
      05-31-2018, 04:20 PM   #41
bluewater328
yup, very nice...especially because I don't see that interior color around much. great price too. CCC might be better than CIC tho.
      05-31-2018, 06:44 PM   #42
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I need an idrive controller and a few odds and ends but I should be under $200 for the idrive retrofit which is absurd. Probably the cheapest idrive conversation on record.
Update: I am at $425 for the retrofit. My first navi was broken so I bought an replacement. If it worked I would have been at $300.
      06-13-2018, 10:23 AM   #43
PaKii94
9
Drives: BMW 335D
I just received the device. It is pretty solidly built and has excellent range. The range might be overkill. The audio quality sounds good enough to me! (I used apt hd to connect btw). It can be powered by the USB port, and the device powers on and connects automatically. I think it can fit well under the center console lid like how a previous poster did with his audioengine b1. I can post some pics once I have the setup nice and clean.
One downside is I need to get a short flat 90 degree aux cord. It sticks out too much on the front
      06-13-2018, 11:25 AM   #44
michaiel
Drives: 2006 BMW 325i
my car is prewired for the microphone above my head with the interior lights...can the factory mic 84 31 6 938 762 be added and implemented with dip switch 4?
Am I understanding that correctly?
If not can some upload some pics of how they discretely added the included mic with the box?
thanks
