01-02-2024, 09:10 AM | #1 |
94
Rep 95
Drives: 2011 BMW 128i 6MT M-Sport
Which year 328i rear calipers for my 128i
I want to upgrade the rear brakes on my 128i (my fronts have already been changed to 135i calipers). I understand the calipers off a 328i are plug and play, but should I look for units from specific years?
Thanks
2011 128i M-Sport 6MT Coupe
Space Gray Style 372 Wheels Red Manual Sport Interior |
01-02-2024, 01:25 PM | #2 | |
Слава Украине!
2317
Rep 2,441
34216768698 Right From RealOEM: Part 34216768697 was found on the following vehicles: 1' E81 (02/2006 — 12/2011) 1' E87 (02/2003 — 02/2007) 1' E87 LCI (01/2006 — 06/2011) 1' E88 (11/2006 — 10/2013) 1' E82 (11/2006 — 10/2013) 3' E90 (02/2004 — 09/2008) 3' E90 LCI (07/2007 — 02/2012) 3' E91 (02/2004 — 08/2008) 3' E91 LCI (07/2007 — 05/2012) 3' E92 (05/2005 — 02/2010) 3' E92 LCI (11/2008 — 06/2013) 3' E93 (09/2005 — 02/2010) 3' E93 LCI (11/2008 — 10/2013) 3' F30 (02/2012 — 07/2015) 3' F30 LCI (01/2015 — 03/2019) 3' F35 (06/2011 — 08/2015) 3' F35 LCI (01/2015 — 03/2019) X1 E84 (09/2008 — 12/2015) Zinoro M12 (01/2013 — 07/2015)
HappyDuck93.50 |
01-17-2024, 10:10 AM | #3 |
94
Rep 95
@Suprgnat Thanks!
01-27-2024, 05:42 PM | #4 |
Rep 13
How come the E90 328i brakes are an upgrade to the stock ones if they share the same part number?
cerealwars78.00 |
01-28-2024, 08:58 AM | #5 | |
Слава Украине!
2317
Rep 2,441
34216768697/34216768698 from the 328i are an ugrade to the 128i because they have 42mm pistons.
Geran4.50 |
01-28-2024, 02:37 PM | #6 | |
Rep 13
01-29-2024, 01:15 PM | #8 | |
Слава Украине!
2317
Rep 2,441
328i
01-30-2024, 01:46 AM | #9 |
87
Rep 265
Worth noting here is that the rear rotors stay the same (i.e., E82 128i) even if using the E9x 3 series rear calipers. I believe (but am not sure) the caliper bracket stays the same as well. I forget whether the rear pads are different from the E82 128i and E9x 3 series, though.
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
cerealwars78.00 |
02-19-2024, 12:53 PM | #10 |
Rep 437
Why not F30 rotors/brakes? Just out of curiosity
I'm trying to decide which route to take in my brake upgrade.
Mods Done: AA Exhaust/Headers | 3SIM | MILVs | StageFP Dyno Tuned | Euro Box Intake Swap | LCI Blackline Tailights | OEM Euro Bi-Xenon Swap from Halogen | Rear Bumper M-Sport Swap | Rear PDC Retrofit | BMW OEM CF Diffuser/Spoiler | BMW Front Aero Kit | Supersprint Sec 1 Cat Delete Straight Pipes
To Do: Ohlins R n T Suspension | Front/Rear Sway Bars | M3 Front Control Arms/Bushings Eventually: AT -> MT Swap (!?) |
02-21-2024, 08:49 PM | #11 |
Rep 13
F30 brakes on the front work great. To put them on the rear is a little harder unless you use the SLG brackets, but that forces you to use 18in wheel.
02-21-2024, 11:50 PM | #12 | |
Rep 437
You don't need a bracket if you're going 370/345 S2NHA M Sport/ZTR option or M Performance BBK (these two are the same, the former are the blue calipers with 370s/345 out of the assembly line or the red/orange/yellow retrofit kit)
02-22-2024, 10:50 AM | #13 | |
Rep 13
