Water Pump failure. Any experience? Cost?
12-02-2016, 11:56 AM | #221 | |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
I've replaced my oil filter housing gasket about 4 years ago and just last weekend I replaced my valve cover gasket. The valve cover gasket is a pain in the butt, but ECS Tuning has excellent DIY instructions in PDF. Now it looks like I've got a coolant line leaking on my rear turbo, which is causing white smoke or steam from that area. It puffs white smoke for about 3 to 5 seconds ever 20 or 30 seconds, even after I've shut the engine off. That's the electric water pump doing what it's supposed to, in order to cool the turbos, even after the car has been shut down and lasts for several minutes usually. Anyway, I'm struggling with how I'm going to tackle that job or if I should just take it to my trusted independent shop. My turbos were replaced under that 82k mile warranty at about 80 miles. Now I'm at 128k miles. Everything else is working perfectly though.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
12-02-2016, 12:22 PM | #222 |
Rep 3,854
Drives: 330i, 135i
"The water pump is attached directly to the water pump"
12-02-2016, 01:15 PM | #223 |
Gunny
30
Rep 623
Well it is! Lol! I meant the thermostat...
While we're talking about thermostats... these BMW t-stats are just a poor design, in my opinion. I wish it were the normal $15 part that just inserts between the upper coolant hose and the engine that takes like 15 minutes to swap. Not only that, the t-stat is fully encased in a hard plastic casing with way too many complicated parts and fittings that don't look like they're built to last.
12-02-2016, 01:48 PM | #224 | |
Rep 3,854
Drives: 330i, 135i
I know my thermostat also gave me a code like a year before water pump died Code was "stuck open thermostat" at least when these go bad they are designed to remain open and not closed... |
12-02-2016, 01:57 PM | #225 |
Rep 458
The previous owner replaced the water pump and thermostat on my 2008 335i at a local dealership January 2015 (70,000 miles) for a total of $1174.04 plus tax ($638.54 for parts and $535.50 for labor).
12-02-2016, 11:22 PM | #226 |
Rep 545
I would say that is exemplary and outstanding price for a dealership. I'm surprised. My friend was quoted on his 2009 528xi E60 n52 (same engine and exactly same layout for thermostat/water-pump) $2600+ for parts and labor at his local NY (Long Island) dealership
12-03-2016, 06:10 AM | #227 |
Rep 424
I just hit 101,010 on the odometer. As for the quote Im gonna try and call him today. Im hoping for $300-400
12-04-2016, 03:36 PM | #228 | |
Rep 2,825
a waterpump will not set you back $1000. my friend had his replaced for $400. |
12-04-2016, 04:34 PM | #229 | |
Rep 545
I'm thinking ordering the kit and keep it in trunk if the worst case scenario comes - just head straight to repair shop in limp mode Last edited by WhiteBeard; 12-04-2016 at 05:04 PM.. |
STR8-6IX536.00 |
12-04-2016, 06:20 PM | #230 | |
Rep 2,825
WhiteBeard151.00 |
12-04-2016, 08:09 PM | #231 |
Rep 545
12-05-2016, 09:18 AM | #232 |
59
Rep 275
12-20-2016, 05:58 PM | #233 | |
Rep 1,232
12-21-2016, 12:39 AM | #234 | |
Rep 5,002
12-22-2016, 11:17 AM | #235 | |
31
Rep 263
12-27-2016, 02:58 PM | #236 |
Rep 5,002
12-31-2016, 09:28 PM | #238 |
59
Rep 275
01-01-2017, 03:45 AM | #239 |
Rep 424
Yeah I thought the same thing. As for the DIY, I just don't want to
01-24-2017, 10:49 AM | #241 |
Rep 16
Drives: '09 335i, '11 M3
That's a GREAT price! Water pump + T-stat job on my 335 was $1200 (indy shop).
tischer, waterpump |
