08-18-2020, 04:18 PM | #1 |
Supreme Allied Commander
3888
Rep 54,575
Drives: F80 M3
CSF High Performance Alum. Radiator 135/335/1M
High perfomrance all alum. radiator with increased capacity and cooling.
2 row 42mm core (dual core) featuring CSF’s exclusive B-tube technology* Core features an ultra-efficient fin with 6.5mm fin height and multi-louvered design for maximum surface area contact Triple-pass flow structure allows the coolant to flow across the core of the radiator 3 times before exiting the radiator for lowest outlet temperatures possible CNC machined “quick-connect” inlet/outlet connections CNC machined brackets and fittings for superb fit and durability All-aluminum race style drain plug 1 hour “mirror finish” hand polish “Drop-in fit” requiring no modifications to install. Accepts all attaching OEM components including “quick-connect” hoses, AC condenser, mounting brackets, and fan shroud 7045 2011+ BMW 1 Series M 08-11 BMW 135i 07-11 BMW 335 manual transmissions only 7046($80 more) 2011+ BMW 1 Series M 08-11 BMW 135i 07-11 BMW 335 2009+ BMW Z4 sDrive30i sDrive35i Automatic transmissions Order here: https://www.hpashop.com/products/csf...b341a0e1&_ss=r Last edited by HP Autosport; 09-13-2023 at 04:28 PM.. |
