Newly fitted Valvetronic motor calibration??
12-15-2013, 04:33 PM | #1 |
Rep 1,834
Drives: '05 E90 330i Manual
So after my car's Valvetronic motor threw an error code I had ordered a new part and had the garage fit it since they were going to calibrate it with their coding tool, but it seems they did not do this properly.
The error code was as follows: DME - 2A38 DME: Valvetronic, monitoring, sluggish movement - Position regulator monitoring - Fault currently present - Valvetronic actuator motor B1214_NG6VMO - Learning Valvetronic limit positions B1214_NG6VVAL When I fetched the car on Friday afternoon I was hoping for a much better overall feel of the throttle in terms of response and smoothness, but it was anything but smooth and responsive! First thing I noticed while driving in peak traffic was that throttle seemed to need a fair amount of pedal movement to get the revs up and when setting off the car would jerk quite noticeably no matter what you do, and same when acceleration after being off throttle - was as if you were a learner driver! The other noticeable issue was when taking your foot off the throttle, the revs didn't return to idle speed nearly as quickly as before when revving, and when driving it was cause a nasty amount of jerking when reducing throttle! Not nice at all to drive when it's like this! Thinking that the adaptations still needed to settle and that maybe I just had to get used to it I continued home. Then I found some quite roads that I could put the car through its paces and the while the nasty jerking continued when setting off or accelerating in gear I decided to give the car a few WOT runs through the gears and this is when I noticed that it seemed to run out of steam or soft limit from 6000 rpm onwards. Again, thinking that the adaptations had to possibly relearn I continued to drive normally for a bit and tried again, same thing! Very disappointed I finally went home. Later that night, and after reading up about the simple DIY to replace the Valvetronic motor and particular with regards to the basic and initial calibration of the new motor which involves inserting the key fob and then turning the ignition on for a few minutes at which point the Valvetronic motor runs through its min and max positions (ignition off for 10 seconds and then repeat the process for good measure a few times), I decided to give this a go. And as sure as nuts, I heard a whirring sound as the new Valvetronic motor ran through its min and max positions! Left it for a few minutes and then turned the ignition off and repeated a few times but did not hear the Valvetronic motor again. So clearly it had self calibrated. I took the car for a drive and all was fine - throttle feel was as expected with no unnecessary jerkiness and response was also better, then once the car was properly warmed up I gave it some WOT runs and this time it ran cleanly up to 7000 rpm every time! So I am really not sure what this specialist garage did and will take this up with him on Tuesday! I gather that while the self calibration is fine, the proper calibration via the BMW tool (coding) is still required? As it stands, I could have just installed this myself! |
12-18-2013, 05:35 AM | #2 |
Rep 1,834
Was really hoping there would be some input or advice. Seems to still be running properly but still have to take this up with the tech...
12-19-2013, 12:50 PM | #3 |
Rep 648
I've never heard of this procedure, after removing my valvetronic motor to replace the leaky gasket I calibrated it using DIS and it did exactly what you described. I could hear the motor whirring and finding the stops and all was good. I assume since your car is driving fine you don't need to do any more.
12-19-2013, 02:22 PM | #4 | |
Rep 1,834
12-19-2013, 04:18 PM | #6 |
Rep 1,834
Thanks, this is my feeling too. And so far the car engine seems to be running fine, but I did speak to the tech and he has agreed that I can bring the car around sometime so that he can just make sure everything is spot on, which I think is the least he can do since this was part of what he was suppose to do in the first place.
12-20-2013, 06:03 AM | #7 |
172
Rep 2,373
I didn't read your whole post so forgive me if this doesn't apply...but there's a bulletin for programming for your fault and also look for oil in the eccentric shaft position sensor..I've replaced VERY few valvetronic motors..
12-20-2013, 11:52 AM | #8 | |
Rep 1,834
Will have to inspect the eccentric shaft sensor plug to make sure it is free of oil, no obvious oil leaks on or around the valve cover when the engine cover is off, but best to just check properly. |
12-20-2013, 10:56 PM | #9 | ||
172
Rep 2,373
12-21-2013, 10:25 AM | #10 |
Rep 1,834
LOL, seems like I am just constantly throwing money at this car then! And especially since my main problem being the pinging/rattle noise persists!
12-21-2013, 11:50 AM | #11 |
172
Rep 2,373
Define this ping and rattle?
12-21-2013, 01:42 PM | #12 |
Rep 1,834
Under part load in particular from 1500 rpm up it typically makes this rattling noise which BMW insist is pinging due to fuel issues which does not make sense since I know of other identical cars running the same fuel grade and not suffering from this in the least! I have replaced spark plugs (somewhere in the early 60k kms), replaced DISA flaps (another misdiagnosed affair), ran injector cleaner and octane booster, replaced temperature sensors suspecting they were misreading and showing a colder than normal operating temp but it seems the thermostat is the problem. Cleaned MAF and Vanos solenoids but didn't swap them around. The tech that had the car now picked up a smooth running issue which was found to be some dirt in the injector rail that was affecting the no.1 injector - cleaned and smooth running was within spec. The the engine apparently went into limp mode and the idle speed was fluctuating throwing the error above. He replaced the Valvetronic motor with a spare one and the engine ran fine with the error not returning.
The car currently has just over 72k km on the clock and this problem has persisted since early last year (2012). Frustrating as hell since I have done everything possible so far and nobody seems to be able to sort this out, just keep costing me more and more money! I replaced this part because it came up with what seemed to be a legitimate "fault" and since my throttle feel overall has been not the best for a fair while now, I felt it was worth a try. The pinging (or whatever is causing the noise) is not really affected by engine temperature, so even just after starting the car and driving a few blocks away I can often hear this while under part throttle. Also disabled the exhaust flap a few months ago and this made no difference thinking that it might have been that, but in general the exhaust mechanism feels tight and firm, so doubt that it's rattling. Octane booster as mentioned above made absolutely no difference and I had a local well known tuner flash the ECU with an optimised software map that increased fuel mixture below 2500 rpm to curb the chance of an over-lean mixture causing detonation, but no improvement, or not much. Currently have a more well balanced performance/economy map so that now at least my fuel consumption is a bit better. So really not sure what else to look at... |
07-27-2015, 12:11 PM | #13 | |
Rep 1
Valvetronic code 2A38 DME Programming
Or generally, does anyone have any experience with this issue being resolved by the DME programming? |
07-27-2015, 02:33 PM | #15 | |
Rep 1,244
Drives: 2013 F10 M5
As far as it being fixed with programming, if volkswackin' is pretty sure it's been resolved with a firmware update for the DME, that's most likely your fix. He knows these cars inside and out. |
11-02-2022, 12:36 PM | #16 |
Rep 2
Drives: 320i se
How do i calibrate z valvetronic motor once its fitted ?
11-04-2022, 09:15 AM | #17 |
Rep 1,834
Without starting the engine, turn the ignition on, and you will actually hear the Valvetronic motor cycle the end stops. Otherwise you can use something like INPA or BMW tools, or a decent diagnostics scanner.
12-03-2022, 04:55 AM | #18 |
Rep 2
Drives: 320i se
Ok i dont hear anything !
I have gotten inpa and on the control section for the vvt motor it says no tester request available |
12-03-2022, 08:42 AM | #19 | |
Rep 503
I also believe your motor is calibrated correctly. The procedure in INPA is the same as leaving your key in ignition. I wonder if you damaged the eccentric shaft when running the motor uncalibrated, but you don't have any issues with it so probably not. |
12-04-2022, 02:46 PM | #20 | ||
Rep 1,834
