All COBB Tuning AccessPORT Flash for N54 335i Discussion Here
01-06-2011, 03:22 AM | #89 | |
Rep 1,284
01-06-2011, 06:15 AM | #90 |
Rep 1,184
is this tune restoring the "turbo lag" to the original pre 29.1 throttle response?
Discussed here on the forum, GIAC restores the wastegate PID to the 25.1 program, it is the most responsive does the AccessPort do the same? |
01-06-2011, 06:39 AM | #91 |
Rep 1,748
It would take me 1550 miles from NYC, so probably an additional 300 miles for you... If only I could take the time off from work for a road trip like that... Then they would have an N55 X5 to play with for a week or two...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
01-06-2011, 08:06 AM | #92 |
58
Rep 318
01-06-2011, 08:17 AM | #93 |
Rep 1,495
01-06-2011, 08:27 AM | #94 | |
58
Rep 318
Maybe Cobb isn't aware of this? |
01-06-2011, 08:32 AM | #95 |
Rep 7,377
its not about the MSD80 or 81 . is the OBD port which in very early model is not the same as the newer models. Check as well Rixster P3 gauge thread. same issue.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
01-06-2011, 08:44 AM | #96 |
Rep 1,617
+1 From MY 2008 on there are CAN signals in the OBD port.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
01-06-2011, 08:46 AM | #97 |
292
Rep 2,898
Cobb Tuning guys -
I hope you also will be taking a look at the 1 Series M Coupe. It will only be available with a 6-spd manny tranny (no DCT) and will have the so-called N54 B30 Overboost motor -- as is currently installed in the Z4 sDrive 35is and the 335is. The 1M is likely to have a slightly different version of the MSD81 DME since --unlike the Z4 35is and 335is -- it will come with a "M Drive" button that actuates more aggressive throttle response. EDIT: As pointed out below by Prince ///M, the Z4sDrive35is has a MSD85 DME -- not a MSD81 DME -- as I stated above. Presumably, the 1 Series M Coupe will also use this DME. Neil Last edited by MDORPHN; 01-06-2011 at 10:30 AM.. |
01-06-2011, 08:56 AM | #98 |
58
Rep 318
01-06-2011, 08:57 AM | #99 | ||
Rep 4,392
01-06-2011, 09:01 AM | #100 | |
Rep 4,392
I think it will be worth the money to have a custom tune specifically for your car and your driving habits. |
01-06-2011, 09:01 AM | #101 | |
Rep 1,184
but if the protocol (the language) that the 07 ECU talks has changed 08 on-words then it needs another firmware |
01-06-2011, 09:04 AM | #102 | |
Rep 200
01-06-2011, 09:06 AM | #103 | |
Rep 4,392
01-06-2011, 09:06 AM | #104 | |
Rep 1,723
What other tunes have you had experience with on your car and for how long? |
01-06-2011, 09:15 AM | #105 | |
Rep 8,830
Cobb - does your software make it very simple for Protuners to make adjustments to fine tune things without risking the safety of the motor by making changes way out of line? How much actual real world testing was conducted with your tune (hot and cold weather)? Curious if you guys ran into any tuner code or cel issues and will this be a flash that is still very much in its infant stage where more real world testing is needed by early adopters or if its something pretty much tested up its a55 and is pretty much bullet proof at this point. Alan
01-06-2011, 09:27 AM | #106 | |||
Rep 4,392
Edit: So if the OBD connection ports are different as you say then the AccessPoint OBD connector should be retrofitted. Last edited by BQTuning; 01-06-2011 at 09:38 AM.. |
01-06-2011, 09:36 AM | #107 |
Mad Linux Guru On The Loose
1128
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
I am wondering why the HP and TQ graphs are so choppy:
Compared to GIAC S1:
01-06-2011, 09:42 AM | #108 |
Team Zissou
3079
Rep 10,198
01-06-2011, 09:43 AM | #109 |
1128
Rep 5,400
I see. Is the smoothing applied by the dyno computer? Because my GIAC software has always felt extremely smooth and consistent.
01-06-2011, 09:44 AM | #110 | |
Rep 1,175
I see a new firmware was released this morning so I've got some more testing to do! |
