07-03-2018, 06:16 PM | #23 | |
Stop the hate, get a V8
3853
Rep 8,625
It's just an approximation. If it's at 35 or 45 I don't think it'll be the end of the world. The point is that you don't want to do it when the transmission and fluid is cold (ambient) or really hot. 40 C isn't even that hot for a transmission.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
09-24-2020, 06:27 PM | #25 |
Rep 709
Thank you! I was halfway through when I realized these lines were in the way of the filter, and no DIY seemed to mention them.
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
WingZeroX5767.00 |
01-13-2021, 10:07 PM | #26 |
Rep 7
Bump for the helpful DIY!
WingZeroX5767.00 |
05-05-2024, 04:19 PM | #27 |
9
Rep 22
Thanks for the DIY - just looking into this and wondered if anyone knows if a seal is required for the "Hydraulic Lines" described in the attached procedure screenshot? Maybe they're compression fittings instead?
05-05-2024, 04:36 PM | #28 |
9
Rep 22
This video shows they're O-Rings, but now I need to find the correct O-Ring size/material. Anyone know? I'm not sure if it's worth replacing the "Sucking Jet Pump" (sucks fluid from the DCT sump), I'll replace if it's not too expensive to buy from BMW. Thanks in advance. |
05-05-2024, 05:20 PM | #29 | |
767
Rep 2,362
Harryc99.00 |
05-05-2024, 06:41 PM | #30 | |
Rep 1,130
Drives: 2009 E92 M3 Dakar Yellow II
Harryc99.00 |
05-06-2024, 04:52 AM | #31 |
9
Rep 22
Thanks very much - I missed the notification where you replied to one of my other messages. Looking forward to ticking this job off the list now I have everything I need.
05-08-2024, 01:39 AM | #32 | |
9
Rep 22
Where has the wear on a the Sucking Jet Pump Been demonstrated? Also, I've had a look on a few threads, really helpful having a DCT expert on the forum. I found post #9 from the thread below very interesting - didn't realise the DCT benefitted from periodic fast drives like you've diagnosed from some previous faults. https://www.m3post.com/forums/showthread.php?t=1903696 Also, does anyone know if rotational 'play'/backlash between prop shaft and gearbox output shaft (up to 2deg approx. by eye) causes any issues? Is there a spline connection that could wear or maybe has worn to cause this on my car? Thanks all |
05-08-2024, 02:03 AM | #33 |
Rep 1,130
Click on his name, select show all threads.
