Autotalent
      03-28-2024, 09:18 PM   #1
BillNguyen
BillNguyen's Avatar
30
Drives: F83 M4
Is it safe
I would it be safe to run extended bolt meant for 10mm spacer on 13mm if not what size bolt should I get
      03-29-2024, 12:47 AM   #2
Miyamodel
Miyamodel's Avatar
15
Drives: 2016 F82 M4
This is what I used when buying bolts for my 7mm that didn't come with extended bolts. Pulled from Bimmerworld's extended bolt product page. Personally, I would err on the side of longer than shorter i.e. using extended bolts meant for a 15mm spacer on your 13mm spacer.
https://www.bimmerworld.com/Wheels-T...Bolts-M14.html
      03-29-2024, 03:34 AM   #3
robbo mcs
Australia
143
Drives: F82 M4 and others
With a 14mm x 1.25 pitch thread, you want a minimum of 11x full turns of thread engagement.
An extra 3mm spacer means you will lose nearly 2 1/2 turns over what you currently have.
Having said that, wheel bolts are cheap. Much cheaper than rims, cars or hospital bills. So get the right size.
Also, if you are racing on them, replace them once every 1-2 years
      03-29-2024, 04:52 AM   #4
BillNguyen
BillNguyen's Avatar
30
Drives: F83 M4
The reason why I’m asking because my 10mm spacer is currently have a 38mm thread which is right according to bimmer world but bms 38mm is also rated for 12/13mm so that’s why I’m confused
f80post
