View Poll Results: I own a...
2008 model and the waterpump failed. 176 14.05%
2008 model and the waterpump is ok. 194 15.48%
2009 model and the waterpump failed. 65 5.19%
2009 model and the waterpump is ok. 195 15.56%
2010 model and the waterpump failed. 18 1.44%
2010 model and the waterpump is ok. 87 6.94%
2011 model and the waterpump failed. 73 5.83%
2011 model and the waterpump is ok. 172 13.73%
2012 model and the waterpump failed. 52 4.15%
2012 model and the waterpump is ok. 103 8.22%
2013 model and the waterpump failed. 23 1.84%
2013 model and the waterpump is ok. 95 7.58%
Voters: 1253. You may not vote on this poll
      04-14-2013, 05:56 PM   #89
PA135i
PA135i's Avatar
Drives: 08 135i 08 CR-V
Just had my car in a local BMW indy shop for the "lifetime" fluid change. Had power steering, rear diff., manual gear box and antifreeze fluids done.
I asked them about getting the WP replaced as preventative. (I am at 64,000 now)
They told me it is $1,400 to replace with thermostat. He recommended that I should wait and get it done closer to 100K. It will show symptoms first.
      04-14-2013, 08:20 PM   #90
PawlyGuNNz
PawlyGuNNz's Avatar
Drives: 135i SGM 6spd MT N54
'08 135 water pump failed at 51,000 miles. Purchased the kit from tischer BMW for $585 w free shipping...my warranty expired so I had to pay out of pocket unfortunately.
MODS: JB4 G5 ISO, VRSF V2 3"DPS, N55 mid, ER CP, TIAL BOV, BMS DCI
      05-02-2013, 10:08 AM   #91
1Mer
Drives: 1 Series M Coupe
1 Series M Coupe went yesterday at 28k - no warning! Fortunately under warranty
      05-02-2013, 10:11 AM   #92
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Thanks for posting, sorry to hear about that. I think yours is the first 1M that the waterpump has failed on. Did your dealer say why it failed? Or IF they have seen other 1M's with waterpump problems/failures?
      05-10-2013, 11:43 PM   #93
HIPSI
21
Drives: 08 135i
I waited too long.... 08 nearing 75k miles just died $1178 to replace including new thermostat
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler
22 C8 Corvette 3LT HTC
      05-11-2013, 06:54 AM   #94
CBRacerX
Drives: 2008 135iC
Replaced at 48k miles
2008 135ic production date 3/2008
6/2012 repair with 48k miles
Covered under CPO warranty
Have 56k miles now...
      05-11-2013, 07:33 PM   #95
IS+1
Drives: 2017 M2 (AW 6MT)
2011 N55 - 102,000 km and water pump is fine (car has been mechanically flawless since day one)... but now reading this thread I think I'll replace my water pump and thermostat at my next oil change....
      05-11-2013, 11:09 PM   #96
HIPSI
21
Drives: 08 135i
Learn from my mistake purchase one from ECS and save yourself $280 or so Vs. the dealer price... http://www.1addicts.com/forums/showt...ecs+water+pump
      05-29-2013, 08:06 PM   #97
96ti
LB TOWN
Drives: 96' 318ti; 08' 135i
2008 / June 2008 ______45K______cost me... $612 not covered under warranty or good will_______N54
Just started having the low coolant light come on. I topped it off once, drove it for a day. Light came back on. Topped it off again and drove it to work and back. I noticed there was a bit of coolant leaking onto the ground. It had been raining for the past 2 days and couldn't see anything.. Today I got the car in the air and dropped the sea of plastic underneath.
My pump has not officially failed yet, but is leaking at the aluminum/gasket/plastic sandwich. I'll be doing it myself this weekend if I get parts in time. Ordered everything from Turner Motorsports.
      05-29-2013, 11:57 PM   #98
no
no's Avatar
Drives: '09
08/2009 N54.....36,000 kms...everything is fine !
      05-30-2013, 09:50 AM   #99
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
So your 2nd water pump is now leaking? Was the 2nd pump replaced at a BMW dealer? You know BMW warranty's its parts for 24 months with unlimited miles. IF a BMW dealer did the install... all work is free IF the part has failed again. IF an indi shop replaced your water pump with a BMW original part... the part still has a 24 month warranty. It might be worth your while to contact a dealer to see if you are covered.
Dack
      05-30-2013, 12:17 PM   #100
96ti
LB TOWN
Dack
Dack,
I guess I should rephrase. I was explaining the lead up to the replacement of the water pump.
My low coolant lamp started lighting up for two days and consumed (expelled) over a gallon of coolant over the course of 2 days. Once I finally had the chance to get the car up in the air, I discovered the WP was leaking.
I just called the dealer and had them look at the service history; still the original WP.
      05-30-2013, 12:20 PM   #101
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Dack,
I guess I should rephrase. I was explaining the lead up to the replacement of the water pump....
Thanks for clearing that up. Good Luck on the R&R.
It seems to me from this poll that the early cars are really at a higher failure rate. Maybe as time goes by that will also be true for later M.Y. builds. But so far the failure rates are quite high for 2008's and to a lesser extent 2009's.
      05-31-2013, 02:18 AM   #102
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Looks like mine went last night.
fyi fault code was 377A which is descibed as
"coolant pump, shutdown: Pump blocked.
It is at the dealer now so I will find out for certain soon.
      05-31-2013, 11:04 AM   #103
Zeros and ones
Zeros and ones's Avatar
Drives: 128i MT6 M Sport, Dinan 5
2011 128i  [5.66]
2000 Dinan 5  [0.00]
Engine: n51
Millage: 43500
Water pump: Still Original
I am shocked and surprised.
"Nobody makes me bleed my own blood. NOBODY!!!!!"
      06-03-2013, 07:46 PM   #104
96ti
LB TOWN
adding more info to thread
Hey Dack,
Do you think it would be worth it to add the manufacture of the failed water pumps and the one they replaced it with? I know this may not be possible for everyone because some may be serviced under warranty, but it could be worth a shot. Possibly add just a tally to the first thread.
Failed WP: Siemens
New WP: Continental
^^Continental bought Siemens not too long ago. Curious as to if anything actually changed.
      06-03-2013, 11:27 PM   #105
mleskovar
Drives: '18 230i
'09 128 N52 38K miles original pump. You would think that after all the cooling system failures in BMWs throughout history they would have figured it out by now. It's not rocket science
      06-07-2013, 11:49 AM   #106
Mr. Toad
Mr. Toad's Avatar
Drives: 2011 328i Coupe
2009 128i
CPO
50,000+ miles
I've had it since last December and, to the best of my knowledge, the original water pump is still on the car.
2011 328i Coupe | Alpine White | Oyster/Black Dakota Leather | M Sport Package | Premium Package | iDrive | Harman Kardon Surround | Steptronic
      06-07-2013, 01:01 PM   #107
631twentyeighteye
631twentyeighteye's Avatar
Drives: 08 335i
Glad to see very few 128's and 2010's in general have failed. I'm at 43k so hopefully it makes it till 80 or higher.
08 e93 335i MT
      06-07-2013, 04:37 PM   #108
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Water pump failure rates so far as reported by us 1Addicts
2008 = 36%
2009 = 12%
2010 = 5%
2011 = 10%
2012 = 0%
2013 = 0%
      06-07-2013, 05:42 PM   #109
Rotaryghost
Drives: 2008 135i
Mine went out last week, 2008 n54 with 78k kms, about 49k miles. Under certified series warranty.
      06-07-2013, 06:09 PM   #110
bozola
Unloved BMW Addict
bozola's Avatar
Drives: Z3 Coupe, 3 318Ti
1999 Z3 Coupe  [10.00]
1998 318Ti  [0.00]
1998 318Ti  [10.00]
2008 128i  [9.00]
Any way to see the 128 vs 135 data?
BTW.... 08 128 66666 miles and still going strong.
