      06-13-2017, 10:57 PM   #67
martymil
Australia
389
Drives: Garage is to big to list.
600 to 700nm
      06-13-2017, 11:09 PM   #68
hot-j
98
Drives: 1M
I am probably making closer to the 700nm than the 600... might as well give it a try and see.
      06-14-2017, 09:20 AM   #69
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Originally Posted by hot-j View Post
Yeah, but one of the things I think is wrong with the clutch masters is the thermal expansion of aluminium is 7x that of steel.... and I think its messing with the sac mechanism of the pressure plate. Maybe I just answered my own question.
Do you still have the stock DMFW or was it toast?
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
      06-14-2017, 10:04 PM   #70
hot-j
98
Drives: 1M
I still have it but will buy a new one anyway the Dual Mass part is in good shape but I'm not liking the looks of the facing on the flywheel
ronster17.50
      06-23-2017, 01:29 PM   #71
hot-j
98
Drives: 1M
Is anyone running the 550i clutch with a single Mass steel flywheel?
      06-23-2017, 07:36 PM   #72
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
The 550i clutch disk is unsprung. That would be a nightmare with a single mass flywheel.
      06-23-2017, 08:27 PM   #73
martymil
Australia
389
A guy here in Australia is running one and he reckons its pretty good with a single mass
I personally wouldn't
      06-24-2017, 01:37 PM   #74
hot-j
98
Drives: 1M
Ah, I see.
      07-31-2017, 01:37 PM   #75
micky 1m
Drives: Saphire black 1m coupe
I just bought a BMW F10 550i clutch and pressure plate, should get installed in October. It holds more torque (550i has up to 500 ft-lb depending on trim level) and feels stock according to those who have used it.
have you had the 550i clutch fitted yet,is it working ok as i need a new uprated clutch for my re mapped 1m
      08-01-2017, 09:51 PM   #76
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I had an issue with a slave cylinder failure shortly after the install, but other than that it has been perfect.
      08-02-2017, 12:28 AM   #77
martymil
Australia
389
Well just an update for you guys that are apprehensive to get this clutch fitted.
I've been running mine for 7000km now and making 350-360rwk with no issues, only sometimes when the clutch is cold it might slip for a split second but that's because of the stupid torque I'm making, but otherwise than that still going strong and still nice and soft like oem stock clutch feel.
      08-02-2017, 08:41 AM   #78
micky 1m
ok thanks for quick comeback guys, i shall order f10 550i clutch + pressure plate and new oem dual mass flywheel now with new stainless steel pivot pin
      08-03-2017, 05:48 AM   #79
Ewok
16
Drives: AW 1M
2011 1M  [0.00]
Hi, I'm running stock tune with OEM DMFW.
Switched to the 550 clutch about 1000km with steel pivot pin.
Can't tell the difference from the standard 1M clutch in terms of pedal feel..
No slippage with gear changes.
Think this is the best compromise between comfort and performance i have experienced so far.
Hope this helps !
      08-03-2017, 12:18 PM   #80
micky 1m
Hope this helps !
sure doest,thanks,not feeling so worried now,550i clutch ordered yesterday, the mechanic is going to visually check the dual mass flywheel to see if i need a new one as he has been quoted nearly £1000 for it, but he is trying to find if he can get it cheaper
      08-05-2017, 10:50 PM   #81
hot-j
98
Drives: 1M
Weird my slave AND slave master failed DIRECTLY after installing. Otherwise, so far so good, and is holding fine.
      08-07-2017, 08:56 PM   #82
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
When my slave failed, the mechanic put it back together and it worked, but we replaced it anyway. He mentioned that it has a plastic housing, but he couldn't find a source for a better one. I wonder if a slipping clutch generates enough heat to deform the housing.
      08-07-2017, 10:27 PM   #83
julienjj
julienjj's Avatar
135
Drives: 135i 6MT
Have you noticed a creaking sound with a metalic pivot pin instead of the platic one ? I have a brass pivot pin I installed at the same time I did the 550i clutch, and the clutch operation got a bit noisy since then. It could be just the stiffer spring doing that noise as well or just me xD
2016 435i xdrive Gran Coupé
2011 E82 1M Custom Frozen Brilliant White
2006 E60 M5 Alpine white SMG DELETE 6MT swap.
Gone : 135i 2008 | Gone : 2008 535i Touring|
      08-08-2017, 04:32 PM   #84
hot-j
98
Drives: 1M
The creaking noise is your self adjusting clutch mechanism combined with the fingers being depressed on the pressure plate maybe they weren't lubed properly?
      08-08-2017, 04:33 PM   #85
hot-j
98
Drives: 1M
My slave literally exploded, maybe it was misaligned I'll never really know but still it's a weird coincidence
      08-12-2017, 12:15 PM   #86
micky 1m
update:new clutch in
went for the bmw F10 550i clutch part no 21-20-7-603-248 ,new bmw 1m dmf and new clutch slave cylinder ,on inspection of slave it looked ok but replaced it anyway, and stainless steel pivot pin( old plastic pin looked ok also ). clutch feels alot lighter and smoother now and can handle the 450nm torque ,409 bhp ,remap done by dms southampton. thanks guys for the recommendation on the 550i clutch much appreciated, i would love to put some pics up but cannot work out how to do it. mike
      10-31-2018, 09:41 PM   #87
lightning
Singapore
70
Drives: 1M Pure S2
Hi hot-j, did you resolve your clutch issues in the end?
      01-25-2019, 11:24 AM   #88
diegorst
Peru
16
Drives: ‘11 BSM 1M | ‘14 Caterham 485S
Hey guys,
So I ordered the clutch you’ve all been discusing here on ECS tuning: (ECStuning.com - ES#: 1897635)
The shop that has installed all my upgrades and manages my car for the last 7 years told me they are having trouble fitting the new disc.
They told me its a lot thicker than the old one I have and once its installed, there is no clearance left and so the clutch remains engaged.
I am baffled by this as I had read a lot of the comments herr that said it was a direct fit for the 1M!
The new plate does fit, the problem apparently, is the thickness of the new disc.
Does anyone have any insight into this?
Here is a pic of the two clutch discs; the one on top is the old one, and the one below the new one.
Thanks!
Diego RdS - Lima, Perú
2011 /// 1M Coupe - BSM
