BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Differences between N55 variations?
Studio RSR
      12-04-2018, 12:52 AM   #23
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
Originally Posted by XutvJet View Post
That is a forged crank.
i did some googling and realised it is forged due to the wide parting line and smooth edges. it also made a harmonic singing noise when i tapped it vs a thud a cast crank would make.
this then means that a pwg m135i which looks identical also has a forged crank as i have seen one as well.
what i dont understand is if the crank is forged and the rods are as well what makes the n54 internals stronger?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 //
      12-04-2018, 02:55 AM   #24
enemigo13
Drives: F32 LCI 440xi citrineblack
I'm not sure if rods are forged. In n54 technical training from bmw ag they state that they are forged. in s55 or n55 documentation I haven't found that rods are forged.
      12-04-2018, 01:24 PM   #25
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Originally Posted by enemigo13 View Post
Difference is in manifold and N55 turbo comes together with the manifold, that's why M2 turbo has another part no.
Sorry Im not too clear but then what are the obvious physical manifold turbo differences between the M2 N55 and the other N55 cars that you see so that we all can know, because I always wanted to know this? Fine you say the turbos are the same compressor and turbine wheels then what is the story between the two manifolds? Please show us a stock M2 turbofold setup. I am not saying you are wrong so I will make that clear.
Do you have a pic of the differences as well? Would love to see.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      12-04-2018, 07:05 PM   #26
bradsm87
Australia
595
Drives: F25 LCI xDrive30d
I'd be interested to see this difference and if it's just a change for packaging or one for performance.
      12-04-2018, 09:00 PM   #27
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Guys, I made a list for you. See the attached picture. To the best of my knowledge.
Outside of the obvious EWG big turbo, keep in mind the following two points that is critical but is not often talked about.
1) Steel forged crankshaft is the key to M135/235/M2 making noticeably more power everything else being equal.
2) M2 manifold is why it easily holds up 16+psi at 6k+ rpm, with stock turbo and pump gas.
Lemania 2320
bkdore103.00
      12-04-2018, 09:20 PM   #28
bradsm87
Australia
595
I believe all of the rods would be forged. Forged rods are so common these days, manufacturers don't even mention that they're forged, hence why some people presumed that they're cast.
We really need to see the visual differences on the M2 manifold to understand.
      12-04-2018, 09:25 PM   #29
SeanWRT
SeanWRT's Avatar
3179
It was my typo. I really meant to show all N55 rods are the same.
And yes they're forged.
Chart updated.
Lemania 2320
      12-05-2018, 02:02 AM   #30
enemigo13
please correct your chart, intercoolers are the same part number either it is F30, F22 M235i or F87 M2.
Chart updated.
      12-05-2018, 02:42 AM   #31
SeanWRT
SeanWRT's Avatar
3179
Chart updated.
I thought they're the same until the day of Wagner IC install. There was a F30 doing IC upgrade at the shop as well. We compared the two stock ICs and saw M2 was like 10% taller if memory serves right.
Didn't care too much as stock IC is the first thing to go once you power mod.
Lemania 2320
      12-05-2018, 07:08 AM   #32
enemigo13
it is the same part number.
ceedawg467.50
      12-05-2018, 10:49 AM   #33
6SpeedCrewCab
6SpeedCrewCab's Avatar
Drives: 2015 335i MSport
for unknown reasons you're confusing superseded and just different parts. e.g. maybe you will remove M2 turbo, then compare with usual N55 ewg turbo and will report - guys, part numbers are different but I've checked turbine/compressor wheels dimensions - they're actually the same turbos! But they're not. Difference is in manifold and N55 turbo comes together with the manifold, that's why M2 turbo has another part no.
Originally Posted by ceedawg View Post
I will not go strictly by part numbers when it comes to engines in the same family. This can also be true with transmission parts for these cars as well. Yes years can vary with different parts it is a real mess Like I said
I have seen this with MB/AMG . The only true and accurate way to confirm what you have is when you have the actual motors from the different cars broken down right in front of your face. M235,335i,M2 let me see an actual motor broken down and each part compared. You will be surprised to find out how the different part numbers can actually be for the same part and sometimes depending on year. Some part numbers become discontinued and they will give a totally different part number for the same exact part. Happens to Engine parts,tranny parts and even suspension parts.
I have seen this with M50,52,S50,52 motors in the E36. Many interchangeable parts ,some with different part #s but the exact same part.
Just to throw this they also have an aluminum block M52 motor and a cast iron M52 block. Lots of folks did not know this. I always like to see the motors in person before the car maker starts spewing out differences for marketing purposes. Sometimes they are correct and sometimes the info is way off.
I've actually been looking for those turbo specs. Do you mind sharing what numbers you found for wheel and housing sizes? Maybe even A/R?
      12-05-2018, 11:37 AM   #34
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
M135/M235/M2 also have different oil cooler system than regular N55 equipped cars, although it looks like F30 with M-Sport has the same system.
      12-05-2018, 01:38 PM   #35
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
so its basically safe to assume the n55 can handle 400-450rwhp daily comfortably.
      12-05-2018, 07:07 PM   #36
bradsm87
Australia
595
The engine itself, yes no sweat as long as you have the mods to safely achieve it such as turbo upgrade.
      12-06-2018, 12:57 AM   #37
enemigo13
strange that in B58 technical training it is mentioned that rods are drop forged, while not a word about it in n55 or s55 pdfs. But I agree, it would be nonsense to use non-forged rods in s55 and part numbers are the same with n55. Interesting thing that s55 holds higher power than n55 which tends to bend rods at lower power level than s55..
      12-06-2018, 04:08 AM   #38
ceedawg
ceedawg's Avatar
468
Do you have Pics /info on the difference between the two manifolds 335 vs M2 ?
      12-06-2018, 07:34 AM   #39
enemigo13
exhaust manifolds? sadly not..
      12-07-2018, 12:28 AM   #40
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
I think those bent rods might be tune related rather than hardware. Achieving tuned S55 power on a N55 require going PS2+++ on the turbo which not many do; hence the experience tuning these turbos is less and more mistakes are made. Just a theory
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      12-07-2018, 01:33 AM   #41
enemigo13
PS2 is only capable of max max ~550hp, to make 600+ on n55, PS2 is not enough for sure, need to go speedtech, but not many people went that way and almost no info about blown engines..
      12-09-2018, 03:33 PM   #42
bradsm87
Australia
595
N55 bent rods are most likely due to people targeting ~19psi at as early as possible RPM with the stock turbo without great tunes. It's this low RPM extreme cylinder pressures that bend rods.
harkes1078.00
      08-13-2022, 08:05 PM   #43
perryreid90
Drives: 2015 F30 335i xDrive
Originally Posted by 6SpeedCrewCab View Post
I plan on making somewhere around 400-450whp so that's good to know. Do you know if a clutch upgrade is required to hold that much power?
not required, but recommended. the more power youre making the sooner your clutch disk will need to be swapped out, apparently the synchro’s start to get eaten alive with mods as well, the ZF 6 speed MT is a good trans but its not known to be very mod friendly
      08-13-2022, 08:16 PM   #44
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Why did you reply to a post from 4 years ago
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
