BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Seeking advice about oil change, US spec being used in Europe, 640i N55 engine.
Extreme Powerhouse
      03-18-2024, 11:45 AM   #1
marlboroplug
Drives: 2015 BMW 640i F06
Hey everyone,
I'm planning to do an engine oil change for my 2015 BMW F06 with the N55 engine, and I'm seeking some advice on which oil to use. I've been considering Liqui Moly Leichtlauf High Tech 5W40, or should i go with 5W30? Summer temperatures can reach as high as 40° C or 104° F, but they are usually around 33° C or 91° F. Car has 80k miles.
Additionally, I'm curious about the differences between the US and EU formulas of engine oil. My car is US spec but i am currently living in Europe.
Would it be okay to opt for a EU formula, or are there significant distinctions I should be aware of?
Any insights or recommendations would be greatly appreciated!
      03-18-2024, 12:59 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
There are literally thousands of posts debating the 'best' oil in these forums: https://f30.bimmerpost.com/forums/fo...play.php?f=437
The TLDR is just pick an approved oil and run a reasonably short OCI and you will be fine.
      03-18-2024, 01:02 PM   #3
marlboroplug
Sorry did not mean to bother. Was just wondering if i should use a US or EU formula.
      03-18-2024, 01:20 PM   #4
thejeremyman9
4364
No bother! Just saying the "which oil is best" question gets asked over and over and there's never a clear winner. Just pointing you to the endless debate should you care to read what people think.
Personally dont know enough about the US vs. EU formulas but you should be able to find a LL or whatever the applicable certification is. I have used that exact liqui moly kit from FCP euro before, it works fine. You can also just get OEM BMW oil change kits
      03-18-2024, 01:52 PM   #5
marlboroplug
I understand. Thank you for the insight i appreciate it.
      03-20-2024, 06:25 AM   #6
lucasborka
lucasborka's Avatar
40
Drives: BMW F36 435i FBO
2015 BMW 435i   [7.50]
No need to mess with viscosity if you haven’t changed any tolerances in your engine.
Stick with bmw-ll-04 5w-30 and you are good, change oil with tight interval and use MANN filters.
I run Motul 8100 x-clean efe 5w-30 on my stage2+ 435i with no issues. It is a slightly thicker 30 oil fyi
      03-20-2024, 12:09 PM   #7
marlboroplug
Hey thank you for the reply,
Would a Ll-04 Oil be okay considering my owners manual recommends LL-01 or LL-01 FE?
      03-20-2024, 12:39 PM   #8
lucasborka
lucasborka's Avatar
40
Are you in Europe?
      03-20-2024, 02:06 PM   #9
marlboroplug
Are you in Europe?
Yes i am.
      03-20-2024, 02:15 PM   #10
lucasborka
lucasborka's Avatar
40
Yes i am.
BMW-LL-04 then
      03-20-2024, 02:26 PM   #11
marlboroplug
BMW-LL-04 then
I see. Thank you i will go with LL04
      03-20-2024, 03:01 PM   #12
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
If you aren't in Europe you wanna use the US spec oil.. it has to do with the additives in the fuel.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      03-20-2024, 03:12 PM   #13
marlboroplug
I am in Europe but car is US spec. What oil would you recommend?
      03-20-2024, 03:14 PM   #14
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Are you importing fuel the the states?
      03-20-2024, 03:49 PM   #15
marlboroplug
No i am not.
      03-20-2024, 04:16 PM   #16
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
No i am not.
Then use euro spec oil. Use what ever weight fits your climate.
      03-20-2024, 04:20 PM   #17
marlboroplug
Then use euro spec oil. Use water weight fits your climate.
Thank you i appreciate the help.
n55david1295.50
      04-09-2024, 06:51 PM   #18
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
When your manual was printed the US had not yet transitioned to ULSG. LL01/01fe are for fuels with higher levels of sulfur.
LL04 is for ULSD/ULSG. BMW has been on LL04 for almost 20 years in the EU.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
