What did you do to your car today?
03-07-2023, 07:44 PM | #22045 |
Rep 3,047
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
03-07-2023, 08:55 PM | #22046 |
617
Rep 351
I got the valve spring off and put the rollers back where they go. Just need to re-seat the spring and my car is no longer broken.... just disassembled
I'm hopeful I can be back in action by the weekend. It's gonna feel so good to hear the engine come back to life! |
Seattlesquash911.00 colorado.e9x3107.50 |
03-08-2023, 09:15 AM | #22048 | |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
I just grabbed the whole unit, changed gaskets and a new hose (If you are manual too then ya you will need that metal pipe as well). Super easy install other than the metal pipe bit |
03-08-2023, 09:58 AM | #22049 | |
Rep 3,047
03-08-2023, 10:24 AM | #22050 | |
Rep 1,364
You can do the pipe with the ex manifold in place with some 1/4" sockets and extensions but you do have to take the waterpump/thermostat out to replace it basically. I managed to do both that and an oil pan gasket in a day (8ish hours) and it wasnt even my damn car |
StradaRedlands4991.00 |
03-08-2023, 10:35 AM | #22051 |
309
Rep 266
Drives: Green '07 & Arctic '08 335i's
New coils for all!
Replaced the coils on the green car. Removed coils were all dated 12/06, no real issues, not bad for 16 years! Also replaced knock sensors due to fault code.
03-08-2023, 05:28 PM | #22052 | |
55
Rep 109
03-09-2023, 08:15 AM | #22053 |
Rep 1,364
03-09-2023, 09:18 AM | #22054 |
55
Rep 109
03-09-2023, 02:46 PM | #22055 |
Robot
1694
Rep 2,193
Not today, but last week I hit a pot hole and it made a nice picture in my sidewall. I carry a plug kit and compressor, but that wasn't going to fix this. I've even driven (temporarily, short distances) with sidewall punctures that I've patched but this time it was a big flap that I couldn't fix. Since I was far from home, I got AAA to tow me to the only tire shop nearby that was open at the time, and they installed a used tire to get me on my way. Tire was the wrong size, too narrow and sidewall too thick, and it had a bulge in the sidewall but it got me home. Then a few days later I found a perfect matching used tire!
I'm wondering if there's any other damage from the impact, or if I got lucky and it was just the tire that suffered. I don't feel any unusual vibrations and visually the strut and control arms look fine. The rim looks fine too aside from the rubber scuff marks where the tire impacted it. Two years ago I had an issue with high speed vibrations (70+ on perfectly smooth roads) and after two attempts at road force balancing my tires I learned one tire was out of round and no balancing would have countered it. I left it alone thinking I'd just wait until I needed new tires. Well this out of round tire was the one that got the puncture from the pot hole, and it's been replaced. I just don't have any smooth roads nearby to test the new tire out yet to see if that resolved the vibrations. |
03-09-2023, 03:43 PM | #22056 |
323
Rep 230
Found a leak in the flex pipes so got new ones and had em welded on by an exhaust shop. The difference is night and day. All this time, was thinking the exhaust was loud by design
03-10-2023, 02:47 AM | #22057 |
27
Rep 34
Drives: BMW E90 325i 2012 B25
Gasket at 50k miles, I use elring gaskets and didn’t replace the valve cover.
03-10-2023, 09:49 AM | #22058 |
Rep 3,060
FimbulWinter I did mine over two years ago and just replaced the gasket, no issues so far. It’s a straight forward job but there’s so many little things to pull or move before getting to the gasket but I know how much I saved doing it myself.
FimbulWinter27.00 |
03-10-2023, 01:43 PM | #22059 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
RealJ22 cool thing about those alpinas is the hidden valve stem in the center cap . Always liked that idea. Too bad they're not 19s
- On things I've done today- more ACC retrofit prep. Couldn't stand all the corrosion. Wire brushed it and sprayed all the metal black. Also my new trim pieces arrived Since the M3 style bumpers naturally do not have an ACC trim, I'm going to do something similar to what I did on my old bumper for my ram intake. If its possible, I'll be doing that again as well. stormtrooper_f80 was my original inspo for the rings. To give you an idea, the ACC will be in the left ring, and a tube into the intake box will be in right ring.
Common sense is a flower that does not bloom in everyone's garden
StradaRedlands4991.00 Seattlesquash911.00 GnomeChild323.50 CornerGorillaPit238.50 feuer4277.00 johnnyorange58.50 |
03-10-2023, 02:39 PM | #22060 |
Rep 24
Drives: 2006 BMW 325i
clean the wheels
Once again I attempted to clean the wheels of the brake dust from factory pads! Alas, to no avail. Have ceramic pads and rotors ordered and will solve this soonest. Feeling better now.
03-10-2023, 07:05 PM | #22061 | |
27
Rep 34
Sadly I don’t have the tools. |
03-10-2023, 09:17 PM | #22062 |
IN54NE
324
Rep 483
Drives: e90 335i LCI M-Sport
I didn't do any work on my car today, but I spent an exorbitant amount of money sourcing parts together for a bracketless B58 coil install, something exactly along the lines of this member's install:
I figured I would always need a bracket or plates to install B58 coils but after seeing someone do it without, I absolutely jumped on the idea to do so. I may do a DIY writeup to share my experience once I get around to installing these
colorado.e9x3107.50 fazm616.50 StradaRedlands4991.00 FimbulWinter27.00 Seattlesquash911.00 CornerGorillaPit238.50 johnnyorange58.50 |
03-10-2023, 10:16 PM | #22063 |
617
Rep 351
I'm making progress. I'm 4/6 on installing the MILVs and have a rhythm going now. The install method in the instructions isn't working for me, the springs are still too tight, so I'm just using my spring tool to take the spring off, seat the MILV, then put the spring back on. The most time is spent making sure the spring is back on the rollers correctly.
I'm hopeful to start buttoning up the car tomorrow. Had a really excellent scare earlier today: I decided to replace the eccentric shaft sensor while I'm in here. Sadly, the bottom bolt on that sensor can only be accessed through a hole in the plastic timing chain guide and my bolt fell into the timing chain cavity. I thought I was toast! I managed to fish it out with a magnet and I'm back in business. When I went to install the new sensor, I glued the bolt into my 10mm socket to avoid that risk a second time. I'm deffo getting some intimate bonding time with my bmw! I probably will not plan to do a major service solo next time. A second set of hands and a little bit of moral support go a REALLY long way on this stuff and youtube and bmw bros via text only cover so much. |
03-11-2023, 12:09 AM | #22064 |
Rep 3,047
I can't believe the difference from putting some Akebonos on... stock pads are the dirtiest things ever! I had to clean them weekly just to keep ahead of the layer of grime... now it's just whenever I feel like it!
03-11-2023, 09:16 AM | #22065 |
99
Rep 154
FAzm, instead of gluing the bolt into your socket you can do the ‘Ed China’ trick. tear off a bit of plastic bag, spread it over the socket before inserting the bolt head into the socket. The plastic will stop the bolt from falling out of the socket. Go to a thicker bag if it’s not tight enough
Looking forward to hearing your review on the MILVs |
fazm616.50 |
03-11-2023, 09:26 AM | #22066 | |
Rep 4,330
I usually just put some tape on two flats of the socket. |
Runnin'Rich99.00 |
