Homelink (Garage Opener) for condo residents
01-30-2008, 11:43 AM | #1 |
Rep 1,287
Can someone help me! I have read every thread on this site .
I can press the outer two buttons and get the system to reset itself. But I can not get my door transmitter to link with the homelink buttons on the rear view mirror. the problem is I live in a condominium please tell me what to do ? |
01-30-2008, 11:45 AM | #2 |
Rep 46,029
honestly...simply read the user manual.
should be really easy to set up. you click the button you want on the mirror for like 20-40 seconds (forgot, refer to manual) then it will start blinking, then you press your transponder, then it will be hella blinking and you know ur done |
01-30-2008, 12:41 PM | #3 |
Rep 4,320
Drives: '07 Z4 M Coupe
Just because it's called "home-link" doesn't mean it won't work in a condo. Unless BMW is in the process of developing a "condo-link" and "townhouse-link"
I know when I programmed mine, I had to get out a ladder and reset the actual opener, then follow the programming instructions. Give that a try.
01-30-2008, 12:57 PM | #4 | |
Rep 1,287
we dont have access to actual opener in building , that's why i said the problem is I live in a "condo" |
01-31-2008, 10:32 PM | #5 | |
Rep 1,350
Drives: 330i
I spend more then 2 hr first day, try to program HL (my Acura and Nissan was 2 min job). And almost decided use remote control. Then I change battery and 3 min later damn HL work. Year after I change door open motor and again reprogram remote in 2 min. Good luck.
'06 330i Monaco Blue/Gray/Walnut/ZPP/Navi/CA/AT -->ED 2006
'18 330i Estoril Blue Metallic/cognac/AT/Sport |
02-01-2008, 10:16 AM | #7 |
Rep 6,805
Don't press and hold your remote when you try to get the signal to sync with homelink, press it couple (may be many) times until the light blinks to confirm it's sync'd up...
MY07 A22 E90 N52Nxi
02-01-2008, 10:39 AM | #8 | |
Rep 278
Just a little info for those who may not know that BMW is not responsible for the HomeLink name, HL products offered or how the HL technology works. You'd be surprised how many people think everything in a BMW is built by BMW. |
02-01-2008, 10:48 AM | #9 | |
95
Rep 2,573
Drives: AW DCT M3
I live in a condo as well and had no issues when establishing the link...
02-01-2008, 10:58 AM | #10 | |
Rep 4,320
02-01-2008, 11:09 AM | #11 |
Rep 587
Your dealer should be able to give you a 800 number to talk to someone who will walk thru the process. Mine didn't work either and that helped me a lot.
2006 A6 3.2 Quattro
2008 e93 335i, 6sp MT, Montego Blue, Saddle, Burl, ZSP, Bluetooth, iDrive, PDC, V1+CD 2007 e92 335i coupe, 6sp MT, Montego, Beige, ZPP, iDrive, PDC 2006 e90 325i, ZPP, iDrive, Arctic, Xenon |
02-01-2008, 11:55 PM | #12 |
Rep 8,375
Drives: Just a car
I have no problem and I live in a condo as well!!
02-02-2008, 12:49 AM | #13 |
Supreme Allied Commander
1971
Rep 61,781
Drives: A BBS WHORE
There's a 1800 number in ur user manual that you can call to help you setting up homelink.
Usually the step missed was the "rolling-code" set up, you will need to actually go to the garage motor and press the "learn" or "connect" button in order the receiver to acknowledge the signal sent from your car.
02-03-2008, 09:16 AM | #15 |
Rep 85
i am having trouble also. I think i've synced up my remote to the homelink button and now it's blinking really fast. Does that mean that all I have to do now is press the learn/connect button on the garage door and press the homelink button for it to work, or do I have to reset it and start over since it's been more than a day?
'06 330i - Alpine White - Terra - Premium |
02-03-2008, 09:28 PM | #16 |
14
Rep 326
Try holding the transmitter right next to the homelink buttons. That is the only way I got mine to work.
The will to do - The soul to dare
-Taylor Knox |
02-05-2008, 10:45 PM | #17 | |
Rep 278
My opener throws one short burst and it wasn't enough to program the HomeLink mirror. The Canadian programming step (not sure why its called that) seemed to do the trick. Basically it involves cycling your opener until HomeLink has a chance to learn the code. Its also worth mentioning I had been using a mini universal opener. That would open the garage door but wouldn't program the HomeLink mirror. I had to use the original opener (pushing the button over and over) to get HomeLink to learn the code. My house gate also required I use the Canadian instructions. Hope this helps. |
02-05-2008, 10:51 PM | #18 | |
Rep 1,350
Drives: 330i
I try to find this document - you just post a thread where I post this instruction.
02-05-2008, 11:00 PM | #19 |
Rep 278
Thank You! I've seen the instructions on various websites like the HomeLink site. But they weren't all in on place so I didn't combine the steps until I looked at your document. Your post from a year ago helped me get my HL working. Thanks!
02-06-2008, 01:57 AM | #20 |
Rep 976
I just picked up a 328i myself and had issue programming the homelink at first. do this...
- press and hold button 1 and 3 for 20 seconds or until rapid blinking. - press and hold the desire button then pres and hold the hand held remote - wait until the LED blinks rapidly. at this point if your homelink is programmed, your garage door should either open or close depending on the previous position. Now if this didn't work, immediately follow the instructions below WITHOUT DOING ANYTHING ELSE! - press (DO NOT HOLD) the program button on the garage door opener - press the desire button on the home link THREE times at this point if your homelink is programmed, your garage door should either open or close depending on the previous position. it's basically the short version of what's in the manual, you just have to read it word for word, line for line, step for step. No matter how simple the instruction might be, you just have to follow it like a little baby. good luck! |
02-06-2008, 12:33 PM | #21 | |
Rep 278
From the manual: If the system fails to function even after repeated programming, check whether the original hand-held transmitter uses an alternating-code system. To do so, either read the instructions for the original hand-held transmitter or hold down the programmed memory button of the integrated universal remote control (HomeLink). If the LED on the integrated universal remote control (HomeLink) flashes rapidly for a short while and then remains lit for about two seconds, the original hand-held transmitter uses an alternating-code system. If it uses an alternating-code system, program the memory buttons as described under Alternating-code hand-held transmitters. |
02-06-2008, 12:41 PM | #22 |
Rep 3,807
Drives: Retired 2017 F87 M2
sorry to hijack the thread but, I would just like to ask if the 2008 328i sedan comes with a homelink system. If not, where can I get a homelink system to have it installed in my 328i?
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
