The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Playing FLAC Files in E92
      08-20-2008, 10:48 AM   #1
SS32
SS32's Avatar
156
Drives: 2008 M3
I can play MP3s no problem using a flash drive, but I can't figure out how to play FLAC files, or if it's even possible. Could someone shed some light on this for me? I posted on M3post, but no one seems to know the answer.
      08-20-2008, 10:51 AM   #2
gravediggingaditch
gravediggingaditch's Avatar
21
Drives: '08 e92
I don't have knowledge but i can't imagine it would play Flac files. . .
usually need some sort of decoder or plug-in for most players anyways. . .
Just decode the flac files to mp3s for your car.
Sick car by the way
BMW 335i - e92 Ordered: 4.23.08 Picked Up: 6.19.08
Blk Saph, Black Lthr, Alum, 230s, Man, Prem Pkg, Sprt Pkg, Navi, Prk Dst, CA, iPod, Cstm Pedals, Pntd Reflctrs, GP Thundrs, 30% Huper Optik Tints / 60% Wndshld, Euro Fogs
      08-20-2008, 11:13 AM   #3
tintivilus
tintivilus's Avatar
Drives: E92 335i
2007 E92 335i  [0.00]
2003 325i  [0.00]
If the file type isn't listed as supported you can't play it. I think the list is: mp3, aac, wma.
What led you to suspect flac was supported?
      08-20-2008, 11:16 AM   #4
SS32
SS32's Avatar
156
Drives: 2008 M3
Someone mentioned it in a flash drive discussion on M3post. They were talking about the speed of the flash drives and one was fast enough to play FLAC files, which made me believe that the car could do it. I really don't have many FLAC files, but I have a few that are very very good quality and my home theater speakers aren't as clear as the ones in the car, so I wanted to hear them in it.
      08-20-2008, 12:21 PM   #5
Dolemite79
88
Drives: 19 z06
if you are using a hard drive of flash drive you can't play FLAC files, the bit rate is to high for the system to process. Even Mp3's encoded at 320 may not play properly.
The solution?
convert your FLAC files to WMA lossless. WMA lossless is as good as FLAC. I did it with all my music in FLAC and it sounds great in the car and plays without a hitch. DBpowerconverter is a great program to use for this and I use it my self.
If you need any help let me know
      08-20-2008, 05:43 PM   #6
SS32
SS32's Avatar
156
Drives: 2008 M3
Good stuff, I didn't know WMA was as good as FLAC or I would have done that in the first place. Thanks.
      08-20-2008, 11:20 PM   #7
Jeff Flowerday
Jeff Flowerday's Avatar
Drives: 2008 335i Coupe
FLAC, WMA Lossless, Apple Lossless they all sound the same. The difference is in file size and processing power required to decode.
PS) The best lossless codec is the one that works on the most hardware in your house/car.
      08-21-2008, 10:10 AM   #8
tintivilus
tintivilus's Avatar
Drives: E92 335i
2003 325i  [0.00]
"WMA Lossless" != WMA. They're different codecs, and support for WMA doesn't necessarily imply support for WMA lossless. Same goes for WMA Pro, incidentally.
...which is why I use Apple Lossless and an iPod adapter. It also helps that support for ALAC in third-party hardware is improving.
      08-21-2008, 02:38 PM   #9
SS32
SS32's Avatar
156
Drives: 2008 M3
I have the ipod adapter (tech package) but it still uses the aux input which doesn't sound very good to me. I'll try converting it to WMA lossless and using a flash drive.
      08-21-2008, 06:02 PM   #10
tintivilus
tintivilus's Avatar
Drives: E92 335i
2003 325i  [0.00]
Make sure you let us know if 6FL can decode WMA Lossless. I'm skeptical
      08-21-2008, 07:23 PM   #11
SS32
SS32's Avatar
156
Drives: 2008 M3
Like I said earlier, I'm basing a lot of what I say on what I read on M3post
Originally Posted by Xcellere View Post
Jason/mods, please don't move this to the Audio section. Being most people don't view that forum, I thought this would help the good amount of people that are getting the iPod adapter.
I started another topic a while back asking about what a good choice for a USB flash would be. After a ton of research, I settled on the Corsair Flash Voyager 8GB. I've had the unit for about three weeks now and can give a brief synopsis of its overall quality.
It's encased in sturdy and firm rubber padding. Tests have shown that you can run it over and it'll remain in pristine quality. This is unlike many earlier USB flash drives that were in normal plastic housings that could break without much harassment.
The unit I bought in particular is the 8GB version, which holds roughly 1,300 songs in 320kbps quality. A main factor in considering a flash drive is it's read speed, and the Flash Voyager is the fastest unit on the market (outside of its more expensive brother the Flash Voyager GT). It's average read speed is 38 mb/s, which is a great deal faster than other drives that average around 8 mb/s. Even if you're sending FLAC quality songs through your amp, there won't be any lag time in requesting the song and it appearing through the speakers.
The MAJOR plus in running a USB flash drive instead of your iPhone/iPod as the host of your MP3s is that iPhones/iPods process the audio signal and they do it in analog only. Flash drives on the other hand don't do any of the processing at all. They hand that task over to the unit installed in your car which in turn does it digitally, thus giving a more pristine representation of the original MP3/WAV's quality.
The Voyager comes with a USB extension cable that allows you to clear the height restriction in our tiny armrests. Overall I think this is the ideal piece of hardware to use with the iPod adapter that many of us will be getting. If anyone's interested, Newegg has a good deal on it:
http://www.newegg.com/Product/Produc...82E16820233037
      08-22-2008, 12:49 AM   #12
Winston1961
Member
Winston1961's Avatar
Netherlands
Drives: 335i Touring
WMA Lossless is supported and the sound is very good. You can use the Ipod as an external harddrive, put your WMA files on ite, connected it only through the USB port with the cable that you use to connect the Ipod to your computer.
MP3, WMA an WAV files are supported (AAC is not supported)
      08-22-2008, 01:37 AM   #13
slick101
slick101's Avatar
Drives: 07 335i coupe
it is possible... i have had a couple of FLACC files that i playes in my e92... burned it into a cd and played it.... it worked fine.... the sound was very crispy....
      08-22-2008, 02:10 AM   #14
Winston1961
Member
Netherlands
FLAC is not supported by 6FL option. I think that de program you used to burn the CD convert the files to WAV.
      09-22-2008, 11:24 AM   #15
Meats
Silky Johnson
Meats's Avatar
Drives: 2008 Jet Black 328xi
2008 328xi  [0.00]
Hey bro,
I just converted my collection to WMA lossless from FLAC using Media Monkey. The car recognizes the files, I can see them when i browse by directory, but when I try to play any of them, they dont work.
Any ideas on things I should try. I really, really, want to have my lossless available in my car.
The solution?
2008 Jet Black 328xi | 189 Wheels | Nav | Steptronic | Sport Package | Logic 7 | Xenon | BMW Assist | Comfort Access | Fold Down Seats | iPod/USB | HD Radio | 35% CS Tints | Happy Robot | V1 Hardwire | Homelink Retrofit | Depo Blacklines |
      09-22-2008, 11:38 AM   #16
Winston1961
Member
Netherlands
When using MediaMonkey you have several options for WMA (WMA, WMA pro, WMA lossless, WMA speeach). I have choose WMA lossless and it works fine.
As far as I know, WMA pro is not supported. Maybe you make the wrong choice.
BMW 335iA Touring, Blue Onyx Metalic, Black Dakota Leather, Active Front Steering, Active cruise control,Comfort opening, Shadow line, iDrive, Individual High End Audiosystem, 6FL
      09-22-2008, 11:57 AM   #17
kilmoremick
Drives: bmw 3 E90
Check this link http://flac.sourceforge.net/download.html
I always use dbpoweramp music converter to batch convert flac files to mp3/aac etc.- works very well.
      09-22-2008, 12:10 PM   #18
Meats
Silky Johnson
Meats's Avatar
2008 328xi  [0.00]
I did WMA lossless and could not get the files to play. They show up in the directory just fine, but when I click on one to play, it never starts up. Previously, my drive in my car had the same # of MP3s on it, never had an issue.
Any ideas on how I can get lossless to work in my car via the USB?
      09-23-2008, 04:41 PM   #19
Winston1961
Member
Netherlands
I have no idee about the problems you have. The only thing I can recomend is try knew WMA lossless file on an USB stick. Maybe you have a problem whit the conection, the hard drive or the files.
      09-23-2008, 05:52 PM   #20
jonywalker
Drives: BMW E91 325d
slick101 has said the CD-player does support Flac. It may be true that the HU doesn't play through USB connection because of bandwidth bottleneck. How about APE, another lossless audio codec?
      09-24-2008, 04:32 AM   #21
Winston1961
Member
Netherlands
There is no support for Flac or Ape. The only lossless format that are supported are: WMA lossless and WAV.
      12-31-2008, 02:25 PM   #22
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
What I have found is that the internal HD on the 09 system will not play back Lossless WMA. A USB stick, however, will. Go figure.
