02-19-2022, 08:55 AM | #1 |
Rep 4
Dipped Right Beam Failure
Hi guys
I’ve had this error a few times, the local garage just replaced the bulb for me. The issue then comes back over a month later, they did a test and confirm the voltage is fine. Does this sound like a new headlight is needed? I have the standard headlights, not the xenon/led ones. |
02-19-2022, 11:14 AM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
Can you confirm what you mean by dipped? The lights have auto leveling and are moving/dropping down on their own?
If so, I had this issue with my xenon lights. It ended up being frayed wiring going to the headlights. You have to remove your wheel, wheel liner and check the wires on the wire bundle.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
320d, headlight, right beam failure |
