BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Help, no crank no start only click
Extreme Powerhouse
      04-19-2024, 08:27 AM   #1
Supremebrandon
Drives: BMW 435i 2014
Hi everyone. For a long time I had a dying battery that I attributed to cold weather. Finally got it changed and a week later died again. Realized there was a parasitic drain somewhere so I started disconnecting the negative terminal when not driving. Couple days ago I gave my car a good full throttle and it was crapped out, started flashing drivetrain malfunction. Made it home and shut off the car, when I started it again no start or crank showing starter malfunction and drivetrain malfunction. Although I don’t believe it’s a starter problem. Any ideas?
      04-19-2024, 11:36 AM   #2
wishbone
///M
wishbone's Avatar
Drives: '18 F80 M3 ZCP, '14 F30 328i
2014 BMW 328i  [0.00]
2018 BMW M3 ZCP  [9.00]
What code(s) do you read?
F80 ///M3 2018 / ZCP / executive / 6-speed / nav
F30 328i 2014 / dinan sport kit / premium pkg / 6-speed / nav / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CAI
      04-20-2024, 05:36 AM   #3
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Did you register the new battery after you installed it?
Does your code reader offer any clues?
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      04-20-2024, 07:14 AM   #4
pshovest
BMW CCA 69606
86
Drives: '15 435i,'10 535i,'08 X5,'98M3
Originally Posted by Supremebrandon View Post
Hi everyone. ....... I gave my car a good full throttle and it was crapped out.......
How long have you owned?
Has any work on lubrication system, like OFHG or oil cooler, been performed?
Put battery on charger
Put socket on front crankshaft pulley bolt and confirm engine can be turned over. Only turn CW, not CCW, from front.
      04-20-2024, 11:00 PM   #5
Supremebrandon
I get code 160504 for the PCV. But that shouldn’t cause a no crank issue, and it looks fine. The battery was also registered at BMW
      04-20-2024, 11:01 PM   #6
Supremebrandon
Also, I had the code come up about a few days before the no crank, even with that code the car was running perfectly fine in terms of no bad idle or anything
      04-21-2024, 05:15 PM   #7
Orion4
Drives: 2013 335i Sport Line Sedan
Have you verified the output of your alternator? Should be around 14-14.5 VDC (if I recall correctly).
      04-21-2024, 11:56 PM   #8
Supremebrandon
Yes I had the alternator checked a little bit after changing the battery
      04-22-2024, 02:50 AM   #9
im_an_alien
im_an_alien's Avatar
1151
Drives: 2016 340i
Can the motor be turned by hand?
      04-23-2024, 12:56 PM   #10
f30jadyn
f30jadyn's Avatar
13
Drives: 2012 bmw f30 335i
Could possibly be dealing with a seized motor. What engine do you have? Also have you done any maintenance like oil leak repairs or anything recently?
      04-24-2024, 10:28 AM   #11
Supremebrandon
Im going to try to turn the motor by hand. 2014 BMW 435i n55
