BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > B48 - Things to Worry About?
GetBMWParts
      03-16-2024, 09:20 PM   #1
hunginator
hunginator's Avatar
155
Drives: 2012 BMW 135i E82 DCT
Question B48 - Things to Worry About?
I have a 2018 BMW 330i (F30) with the B48 motor. Mileage is just creeping towards 60k miles/100k kilometres.
What are some of the "common" issues or preventative maintenance items I should start worrying about?
Thanks in advance!
      03-17-2024, 11:50 AM   #2
hunginator
hunginator's Avatar
155
Alternatively, is there an existing thread that covers this topic? I couldn't seem to find anything, hence this post. Thank you!
      03-17-2024, 05:46 PM   #3
alexonahurry
Ozzy Dude
alexonahurry's Avatar
Australia
222
Drives: BMW F30 330i LCI
Pretty much everything is covered here https://f30.bimmerpost.com/forums/sh....php?t=2061712
I would recommend to keep an eye on the cooling system as it's known for having issues as the car is getting older and the plastic is getting brittle. Apart from that, it's a pretty reliable engine.
      03-18-2024, 04:58 PM   #4
hunginator
hunginator's Avatar
155
Thanks for your reply! Happy to hear that it's a pretty reliable engine and will get a shop to preemptively take a look at the coolant system.
      03-21-2024, 03:14 PM   #5
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
I know in the US there was a recall for the coolant system issue.
At least I got a card in the mail about it but mine went a year earlier and I replaced it myself. Part was $30. Labor was a PITA.
      03-26-2024, 01:05 PM   #6
montr
Drives: 2010 335d, 2018 430i G-Coupe
I had two issues with my 2018 430i. First one was a plastic coolant hose that is covered by a recall. Second one is the plastic oil filter housing that developed a crack, started loosing coolant slowly and then very fast. Car was towed to the dealer. Replacing the housing was not cheap out of warranty.
      03-26-2024, 06:36 PM   #7
salty8snax
salty8snax's Avatar
Drives: 2018 330i Xdrive Wagon
At about 52k miles my oil filter housing cracked while I was driving and dumped all my coolant out. After inspecting it I noticed the water pump had been leaking along with the cooling line that runs into the turbo (probably why my oil housing failed) . I replaced everything with the updated BMW part numbers and haven’t had any issues since. I would highly recommend swapping out the oil filter housing as preventative maintenance if it’s never been done. There’s also a plastic flange that attaches to the engine block underneath the intake. This is the next part that will fail so I would highly recommend swapping it out for a new oem one or ordering an aluminum one off amazon and making a gasket for it since it doesn’t come with one. I replaced mine with the aluminum and haven’t had any issues so far. Only thing I want to do now is replace the hose that connects onto this flange because I could see some cracks forming. Lmk if you need any part #
      03-27-2024, 06:17 PM   #8
hunginator
hunginator's Avatar
155
thanks for this and would love to know what the BMW part #'s are so I can source them myself, and then have my local indy shop perform the labor.
      03-28-2024, 07:49 AM   #9
GreenF30N26
GreenF30N26's Avatar
153
Drives: F30 328ix N26
realoem.com
