ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      03-24-2009, 04:44 PM   #1
strokeZ
strokeZ's Avatar
10
Drives: '11 e92 M3 6MT
Battery drain
Have 2003 Z4 2.5. After 2 days of no use the battery is dead. Have brand new battery, checks out good (after several checks). Needs 6 hour trickle charge to start it up. Anyone heard of issues or common switches that go bad? Obviously a battery drain, but cant locate it. Have turned all switches off, top up, top down....no luck isolating issue. As long as I start it once per day and drive for a bit, things seem to be fine. I am stumpped! Any help is welcomed!
      03-27-2009, 04:03 PM   #2
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
Get a voltmeter and go through the fusebox.
You need to find out which relay/fuse is faulty and not shutting off when the car shuts off.
Hope this helps:
http://www.aa1car.com/library/battery_runs_down.htm
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
      04-07-2009, 07:20 PM   #3
biminibmw
biminibmw's Avatar
Drives: 2006 BMW Z4 M COUPE
i've been having the exact same problem for the past few months... took several trips to the dealer, first they switched out the battery, then the second time they said it was a problem in the gauge cluster and replaced it, and after that didn't work they replaced the ipod module convinced thats where the draw was coming from. but low and behold, i didn't drive the car this past weekend and monday morning i had to get a jump to get to work.
needless to say, its been quite frustrating.
please post if you find the source of the problem.
      04-08-2009, 11:57 AM   #4
strokeZ
strokeZ's Avatar
10
I think best approach is to use a volt meter. Going to try it this weekend. I have been told that the convertable top switches tend to go out, but still I am suspicious. Definitely a parasitic drain as I have run the car all week with no problems. will post something if I find the problem.
      04-08-2009, 08:30 PM   #5
Graham M
I love my Z. Pure sex on wheels.
Graham M's Avatar
49
Drives: Is sold, goodbye everyone!
^ Youd hear the motor whirring if the switch was stuck on, of which the motor would burn out shortly thereafter.
Yeah the volt meter technique should work great, thats exactly what I was about to suggest, thats how I used to check for simular problems over the years.
      04-11-2009, 05:35 PM   #6
strokeZ
strokeZ's Avatar
10
Ok so here is the strange thing.....check battery and NO unusual voltage drain when car is off. Battery is charging as normal when car is on (alt. is working). One shop suggested that even new, the battery may be bad - not able to hold a charge. Not sure if I believe but out of ideas.
      04-12-2009, 12:11 AM   #7
Graham M
Graham M's Avatar
49
^ Do a "carbon pile" test on the battery. Thats basically when they hook up a small ($30) device up to the battery, while it measures the continual voltage as it drains significant amounts of amps. The more of a voltage drop, the weaker the battery.
You can do it yourself, as they can be picked up at any auto parts store for $20-$50++ most times. They come with instructions as per how to use them. That way you can know what to expect, and not be taken advantage of if another shop suggests you may have to replace the battery that you just bought.
I still find it odd that you have this problem. So you checked ALL the fuses for ANY current draw? That is seriously odd. Another thing that they can do (or yourself) is to check the actual charging system power of the altrenator. Your Alt should do around 60-80amps at idle, and do 120-160amps at 2,500 RPM +
      04-13-2009, 12:48 AM   #8
papitosabe
Drives: '06 Z4 Coupe
happened to me twice in less than a year....it was always after a few days after non-use as well... i remember a i would hear the cd spinning if it was left in, but no key ...i never thought anything of it... 1st time battery was replaced...2nd time i don't remember...haven't heard the cd spinning after car being turned off since..
      04-13-2009, 09:31 AM   #9
strokeZ
strokeZ's Avatar
10
would love to know what your second fix was pepitosabe.....
had battery checked as a few locations and all reported no unusual drain other than power to keep the electronics alive (memory etc....). mechanic tested the alternator and no problems there. Agree this is strange and hard to believe.....but stranger things have happened.
      04-13-2009, 10:37 AM   #10
Incompatible
Drives: 07 AW Z4C 3.0Si
Had a similar problem. Installed new battery to replace the oe 6 year old one. Worked great for 3 months as a daily driver. Went on a 4 day trip and battery was dead on return: jumped...charged....everything OK. Car would start fine if I drove the following morning, let it sit for more then a day, battery dead. Clean contacts again, check charging system, check for shorts.....everything OK. Load test on battery was erratic, seemed like it would read fine one time and low voltage another: conclusion was a short within the battery. Replaced the battery and problem solved.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      04-21-2009, 08:06 AM   #11
strokeZ
strokeZ's Avatar
10
Tested the battery and turns out it was from the factory HU. Seems that it remained ON all the time (even w key out of ignition). I checked the amp in the trunk in the morning and it was still warm. Replaced the HU with an aftermarket and checked battery when car was off....reading 0.16 mA. I think this is normal, as my other vehicles read nearly the same.
      04-21-2009, 08:10 AM   #12
strokeZ
strokeZ's Avatar
10
After another dead battery incident I replaced my volt meter. Turns out it was factory HU and amp remaining on all the time (even with key out of ignition). Repaced HU with aftermarket and battery reading only 0.16 mA when car was off. I think this is normal (my other vehicle read 0.15 mA). Will post any updates if needed. Good news is that I now have hi speed iPOD connectivity with all the goodies.
      07-29-2022, 06:36 PM   #13
ajax_borges
Drives: BMW Z4
What is "HU"?
I am having the same problem and would like to try to troubleshooting myself, but not sure I really know how to.
      07-29-2022, 07:51 PM   #14
Clearancediver
Drives: 2004 Z4
Head Unit… radio
Sent from my smart phone...
      12-07-2022, 06:51 PM   #15
Tozzfhj
Drives: M5
I also need to learn more on thisb
      04-12-2023, 10:49 AM   #16
Z4Kevo
Z4Kevo's Avatar
85
Drives: 2007 M Coupe
ever since i got the car...2008...on every battery that has ever been installed. i have battery drain problems if i leave the door open and listen to the radio (while cleaning or detailing) in 10-15 minutes battery is dead and won't crank. has been a real frustration over the years.
i drive it infrequently and way too often would want to go for a drive and no crank. so i leave it on a tender all of the time now...just don't trust it.
2007 BMW Z4M Coupe | Sapphire Black | 19" ZCP Wheels | Michelin PSS - 245/285 | Carbon Leather
Black Corners | UUC Short Shifter | ///M Racing Pedals | OE Strut Brace | LED Accents | PEMP Android
      10-22-2023, 06:33 PM   #17
bimmernut9002
18
Drives: 2007 Z4 3.0si
I realize that this is an older thread, but I found that my E85 was draining the battery because the rear between-the-seats compartment light was staying on 24/7. Turns out the little plastic finger (like a twig the size of a pencil lead) at the bottom of the door had broken off and therefore the door was no longer making contact with the switch. I just put a small screw in there as replacement and voila, light goes off when the compartment door closes.
Z4Kevo84.50
zpost
