Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > 10s runs on E30 and 20.7psi Boost
      06-30-2023, 08:43 PM   #1
Coupes33
Drives: 2006 335i, 2017 Audi S3
I had 2 runs last night at the Willowbank Raceway Test N Tune using the E30 tune and launching in 1st gear. The results were a 10.804s@128.62mph run followed by a PB 10.636s@128.64mph run. The 60' times were 1.637s and 1.581s respectively. Launches were abrupt using the transbrake which has resulted in some damage to the driveline which I got to find. There is now a loud whine coming from somewhere when driving. Hopefully, it is the centre bearing or rear CV joint on the driveshaft.
Name:  30th June Test N Tune 2023 -  (411)-(ZF-0940-61270-1-001).jpg
https://datazap.me/u/coupes44/datalo...57&tmax=374.38
Datalog for 10.6s run.
shannon1639.50
      06-30-2023, 08:44 PM   #2
whyzee125
Drives: Dinan stage 2 335i
Holy crap that's impressive. Nice work man, even with a few battle scars!
      06-30-2023, 11:22 PM   #3
Brule
Australia
827
Drives: 2007 335i e92 6spd man
Wow!
Awesome!
20psi!
Dam!
      07-01-2023, 06:54 PM   #4
Coupes33
Thanks
      07-01-2023, 06:56 PM   #5
Coupes33
Originally Posted by Brule View Post
Wow!
Awesome!
20psi!
Dam!
More boost and ethanol should get me into the low 10s if the drivetrain can take it.
      07-01-2023, 07:25 PM   #6
Brule
Australia
827
Yep I can see that time improving with more power.
Very impressive.
      07-03-2023, 04:03 PM   #7
Coupes33
Very impressive.
I might need a diff and axles like yours Brule. I think the M3 diff maybe damaged from the savage launches. There is a howl/whine coming from the driveline on deceleration which indicates to me the diff.
      07-11-2023, 11:35 PM   #8
Coupes33
The M3 diff has been dismantled and it requires the crown and pinion gears to be replaced as well as the bearings. No more trans brake launches as they are too expensive.
      07-11-2023, 11:38 PM   #9
Coupes33
Name:  30th June Test N Tune 2023 -  (409)-(ZF-2637-89332-1-001).jpg
      07-24-2023, 09:08 PM   #10
Coupes33
The whine I had after the TNT was found to be coming from the diff. I had to have the pinion and crown gears, bearings and seals replaced. $2,700 later I have the diff back and installed in the car. I haven't driven it as yet so hopefully, there are no other hidden issues. Needless to say, I won't be launching on the trans brake anymore. I will try a normal TC launch on the brakes which isn't as harsh on the driveline because all components are in tension at launch.
      07-25-2023, 03:57 PM   #11
sbmws
9
Drives: BMW 335i
Attachment 3217932
Attachment 3217933
That’s bloody quick
What Turbos are you running?
      07-26-2023, 03:37 AM   #12
Brule
Australia
827
Crazy to hear the price of fixing the diff.
Sell it and get a ford 8.8 diff next.
      07-26-2023, 04:25 PM   #13
Coupes33
Originally Posted by sbmws View Post
That’s bloody quick
Twin RB GF 19t High Flows
      07-26-2023, 04:27 PM   #14
Coupes33
If I remember correctly, Brule didn't you have delays and issues with your 8.8 diff and axles.
