06-18-2022, 04:17 PM | #19075 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Took the M3 to see "The Power of M" exhibition at The Ultimate Driving Museum along with a buddy and his M2 Competition. The Power of M: Celebrating 50 Years. The new exhibition celebrates 50 years of BMW M and Motorsport. The exhibition is housed at the BMW CCA Foundation's Museum in Greer, South Carolina—right across Highway 101 from BMW Manufacturing, and just down the street from the BMW Performance Center.
Location (with plenty of free parking) 190 Manatee Court, Greer, SC 29651. . .
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
31
CTMike262.00 Dpc2u11503.00 CamasM3e933207.50 Vedubin01942.50 slcook541863.00 Davisca4552207.50 SAMM3Y3085.00 Uscray134.00 spammysammich1598.50 BOOF-M34451.50 Cmassey3420.50 Frostynorth432.50 MayallE93159.50 drwankel1053.00 mym3adventures176.00 M3 hacker70.50 Kowalski20111172.00 ///M Power-Belgium63949.50 Davey2767.50 Peertwelve782.00 tbuck1188.50 B8bydesign689.00 jvictormp907.50 Rochen_00349.50 Freiheit492.00 e90335e36m31425.50 ATLIEN549.00 Erickuokwa489.00 ES BMW67.50 CarbonBlack88177.50 M3E90sedan108.50 |
06-18-2022, 04:55 PM | #19076 | |
Friends don't let friends ESS
3208
Rep 883
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
https://www.bimmerpost.com/forums/sh...php?p=29025273 |
DrFerry6730.00 |
06-18-2022, 05:40 PM | #19078 |
Derbo Tuning
3610
Rep 3,026
DrFerry should've made this into its own thread in the gallery!
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
BOOF-M34451.50 |
06-18-2022, 06:10 PM | #19079 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Sorry. I never really was very good with the M3Post forum etiquette. Got banned from "Off Topic" for six years.. What is "the gallery"?
06-18-2022, 06:34 PM | #19080 | |
Rep 4,175
DrFerry6730.00 |
06-18-2022, 06:35 PM | #19081 |
Rep 3,738
Drives: 2018 M2
I so badly want to quote the whole post and just say “cool pics”
06-18-2022, 06:47 PM | #19082 | |
Derbo Tuning
3610
Rep 3,026
I meant the media gallery subforum.
IG:ruhrohz_m3
DrFerry6730.00 |
06-18-2022, 07:07 PM | #19083 |
35
Rep 65
Those are some nice pics of the event. Lots of great cars.
Steering wheel extension installed. For those interested in this, keep in mind the steering column angle doesn't change, so if you've bottomed out the vertical adjustment and want the steering wheel 1-2" closer to you than max stock adjustment, the extender brings the wheel closer but it sits higher. Adjust your seat accordingly. The stalks are 2" farther away too. |
CHSe92251.50 |
06-18-2022, 07:18 PM | #19084 |
Rep 4,175
06-18-2022, 08:07 PM | #19086 |
Derbo Tuning
3610
Rep 3,026
I guess if you are already that tall probably got big hands too. lmao
IG:ruhrohz_m3
06-19-2022, 11:42 AM | #19087 | ||
252
Rep 159
It's a ~1.9 inch spacer. Takes a little getting used to but after a few drives the muscle memory is there |
06-19-2022, 02:30 PM | #19088 |
3208
Rep 883
A mix of activity today. Added refrigerant, was down 24 ounces so probably have a leak to address. Also confirmed that the rubber/neoprene shield I placed over the brake boost pressure sensor is in place after 1000 miles of driving. It's approximately 2" x 3" and just riding atop the sensor, held in place by a cage of ABS brake lines. Hoping to prevent another failure if'n I spill anything down there in the future.
I haven't seen more than 5 psi boost since moving the Harrop to the e90. Pulled the Harrop to address a known boost leak after I had snapped one of the throttle body boot worm-clamps 2 weeks ago. In the process discovered a second leak on the other side. I had had to replace several of the rubber boots before the install and apparently didn't get the boot attached to the throttle body adequately with the pinch clamp. After some fussing got that nice and tight and buttoned everything back together. First pull: peak boost of 6.5 psi and the engine sounds tight. |
06-19-2022, 04:06 PM | #19089 | |
Rep 1,119
Drives: 2009 E92 M3 Dakar Yellow II
DrFerry6730.00 |
06-19-2022, 04:09 PM | #19090 | ||
3208
Rep 883
DrFerry6730.00 |
06-19-2022, 07:48 PM | #19091 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Would love to know what AC refrigerant kit you used and a bit more information on how to go about recharging or refilling the system. Mine has never been recharged in 14 years and I live in the south…
///M Power-Belgium63949.50 jvictormp907.50 |
06-19-2022, 08:56 PM | #19092 | |
3208
Rep 883
That said, if you are getting adequate cooling with your system I wouldn't touch it. Addendum: discovered I overfilled the system. High pressure relief valve vented refrigerant after a drive and the system stopped working. I bought a second hose and learned that the first charging hose had a faulty pressure gauge. The system takes 1.37 pounds of refrigerant per the label under the hood, so clearly 1.5 pounds of r134a was too much. With a second hose I vented to atmosphere until the gauge was in the green and the system is blowing cold again. Attaching pic of the low pressure inlet. Black plastic cap on silver tubing. I needed pliers to remove. |
06-20-2022, 01:08 AM | #19093 |
Rep 1,119
Did some troubleshooting on some slight vibration I was getting in the front wheels at around 70 mph with my recently repaired and powder coated Titan 7 wheels. With and without spacers.
It turns out they didn't mask the hub area or wheel lug mating surfaces and I noticed uneven compression of the coating. I carefully removed the paint from the area with a DA and some 120 grit making sure the hub contact area was not uneven and I stopped as soon as I saw metal. Shakedown run up to 75 was much improved. Still a little tiny shimmy there but the wheels were not road force balanced so I'm sure it'll get dialed out. The big lesson learned this weekend is if you're looking into getting into the Milwaukee M18 ecosystem home despot is selling the battery starter pack with your choice of a free tool. |
DrFerry6730.00 |
06-20-2022, 04:51 PM | #19094 |
3208
Rep 883
Used a heat gun and patience to remove an 11 year old clear bra. Lots of rounds of rubbing compound then used a TouchUpRx kit to paint over a decades collection of rock chips. Then more compound then wax. Not a bad outcome for 2 hours work.
akkando5864.50 brettcp348.00 Vedubin01942.50 Davisca4552207.50 DrFerry6730.00 mym3adventures176.00 slcook541863.00 jun_e92140.50 Cmassey3420.50 Kowalski20111172.00 motorsport_marc76.50 |
06-20-2022, 05:35 PM | #19095 | |
Rep 704
Thanks! |
06-20-2022, 05:40 PM | #19096 | ||
3208
Rep 883
