02-01-2023, 12:00 AM | #1 |
25
Rep 110
Anyone running NGK 97506?
Anyone with a supercharger running NGK 97506 2 Step colder plugs? I searched the forums didn't find much. I know of one member running them without issues curious if anyone else out there is running them without issues.
Alpine E90 M3
Dakar E36 M3 |
02-01-2023, 04:39 AM | #2 |
3751
Rep 2,907
Drives: 2011 E93 M3
Remember that the S65 is unique with its ionic knock control built into the coils and specified for use with LKR8AP plugs. Changing plugs is not common in this platform and would risk the knock control not reacting properly.
DrFerry6728.50 ///M Power-Belgium63403.00 |
02-01-2023, 05:16 AM | #3 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Davisca4552207.50 DrFerry6728.50 |
02-01-2023, 07:18 AM | #4 | |
Friends don't let friends ESS
3166
Rep 872
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
NGK 93253 R2556G-9 It’s an iridium plug and at least some of us are using them on supercharger kits to extend plug life (30-40k miles versus 10k miles). |
02-02-2023, 10:39 AM | #5 | |
229
Rep 350
Drives: E53 X5, E83 X3, E93 M3
I would be super-interested in this, but I've been burned before using other iridium plugs. -_-
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
02-02-2023, 11:27 AM | #6 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
This same topic is discussed in these threads. Search the forums or threads below by keyword = R2556B-9 or R2556G-9
https://www.m3post.com/forums/showthread.php?t=1763451 https://www.m3post.com/forums/showthread.php?t=1070943 https://www.m3post.com/forums/showthread.php?t=1802212
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
02-02-2023, 08:07 PM | #7 | |
229
Rep 350
Reading your suggestions and searching the forums didn't yield much of the answer I was looking for I guess (or I'm not very good at it). There was a post, from your above, someone asked/mentioned whether the Harrop supercharger mod didn't use the ion-sensing. "I guess they don't use the ionic knock sensing?" This makes me think that perhaps this feature is modified or even turned off (kinda doubt it turned off) within the Harrop tune...? I couldn't find much detail here to confirm if a tune was made directly for this in the installation pdf: https://www.harrop.com.au/shop/tvs1740-bmw-e9x-m3 I know the OP originally intended the question to be for supercharger configurations (which imply a tune of some sort), but what about using this iridium spark plug with stock-tune, NA? Would the ion-sensing work appropriately enough using the iridium race plug?
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
DrFerry6728.50 |
02-02-2023, 08:43 PM | #8 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
. https://www.m3post.com/forums/showpo...&postcount=148 From the post above: "I was told the only reason these NGK Iridium Racing plugs work so well in boosted applications is because in boosted applications the misfire sensing routine has been 'coded out' with (by) the supercharger tune(r). Not that these plugs ever misfired when I was running them." . As far as I understand the topic(s): The ionic knock sensing routine is not the same subroutine as the misfire sensing routine. More simply put: the stock tune would "see" boost as a misfire. Hence, tuner(s) code such functionality out to allow boost to be run with the S65 DME. Hope this helps: PS: Over the years, this exact topic of alternative spark plugs has caused serious debate on the forums. Happy searching. PPS: Not all NGK iridium plugs are the same as NGK Racing iridium plugs.
RocketyMan229.00 |
02-02-2023, 08:51 PM | #9 | |
229
Rep 350
Okay. That is explanation enough, and now it makes sense!! You're clearly a better searcher than me! lol
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
DrFerry6728.50 |
02-02-2023, 11:34 PM | #10 |
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Just to add these plugs are favorites for stage 2 n54's that are highly boosted and s55's as well but then again you have to gap them to your specific preferences. Not sure how that translates to a supercharged s65 with tune..
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
DrFerry6728.50 |
02-03-2023, 07:09 AM | #13 | |
Rep 865
I bought my car in ‘18 with the blower kit installed. I needed to get the car SMOG’d, so I removed the blower kit except that I left the NGK Racing plugs and the big injectors in place thinking I’d save myself some time. The car would barely run, all popping an farting…not good!
Chris, 2008 E92 |
DrFerry6728.50 |
02-03-2023, 07:12 AM | #14 |
Rep 10,616
This is an interesting question and I am not an automotive electrical engineer. My very simplistic guess is that if plug resistance is the same, there should be no effect on current measurement during the exhaust stroke. As I understand, the requirement that misfire detection has to be disabled is for forced induction in general, not specific to use of aftermarket plugs.
DrFerry6728.50 |
02-03-2023, 07:46 AM | #15 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
https://www.m3post.com/forums/showthread.php?t=1763451 .
02-03-2023, 08:00 AM | #16 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
I'm interested to know how many miles you've put on the OEM spec NGK plugs in the last 3 years in your E85 boosted application?
02-03-2023, 09:19 PM | #17 | |
wannabe
252
Rep 819
I am interested in going with a 1-2 step colder plug but I need to consult with my tuner, interested to see if there is any actual benefit…..
E90 M3 - 6speed - slicktop - single hump
02-03-2023, 09:41 PM | #18 | ||
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
02-04-2023, 02:03 PM | #19 | |
wannabe
252
Rep 819
I have no doubt the oem plugs in my current setup will last 10-15k. The benefits of the colder plug are obvious, I will have to check with my tuner to see how the knock system is being managed currently. With bpm handling the tuning for the harrop kits, what has Mike had to say regarding running the colder plugs and their effects on the knock system? (Forgive me if it’s covered in another thread).
02-04-2023, 02:16 PM | #20 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
One day I’ll dig into the details regarding the wizardy of the ionic knock sensing routine inputs because other people have speculated all that’s important is the resistance of the plug. Whatever the case, I and others have run these particular plugs successfully for over 50K miles without problems BUT only because our Harrop supercharger tune disables the misfire DME subroutine coding - as do other supercharger tunes such as G-Power or VF-Engineering. Please do let us know what your tuner says..
02-04-2023, 03:44 PM | #21 |
Rep 10,616
E85 burns cooler. Could the reduced combustion temperature also reduce the need for a cooler plug? I would probably focus more on reducing spark blowout and increasing spark energy given the larger combustion event from the airflow of 12.5psi. Reduced gap and/or stronger coils, but I would also want to be confident any changes did not affect the knock sensing though E85 (assuming it is tested to be E85) should reduce the likelihood of knock. Probably the E85 tune is really an E60 tune if pump E85 is being used since it is well known the E content can vary.
02-05-2023, 09:52 AM | #22 | |
wannabe
252
Rep 819
