09-28-2020, 04:44 PM | #23 |
Rep 3,413
09-29-2020, 07:52 PM | #24 |
Rep 424
Thinking of getting these for my granny coupe to prevent shooting nasty chicago winter salts up my fenders.
Anyone have pics of these installed ?
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
09-29-2020, 08:24 PM | #25 | |
Rep 893
The F30 fronts won’t fit. I’m running only the rears. (The lower rear fenders were where I was most concerned anyway.) I think I previously posted about the minor mods to make re: 2 new holes in the guards to pick up the different 4-series inner fender fastener locations. |
obzen189.00 |
09-29-2020, 09:40 PM | #26 |
Rep 8,942
Get a set from Tommy L Garage.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
09-30-2020, 06:25 AM | #27 | ||
Rep 424
On a scale of 1-5 how hard was the install of the rear
09-30-2020, 06:39 AM | #28 |
Rep 424
I saw the video for the f80 install they look awesome. Am I blind or are there no links in the comments of the video to buy them? Quick google search leads to Facebook page which I don't have... I know right.. I would love to get those
09-30-2020, 08:26 AM | #29 | |
Rep 8,942
got6speed@gmail.com
2022 Macan S
09-30-2020, 08:53 AM | #30 |
Rep 893
09-30-2020, 10:57 AM | #31 |
BMW CCA Member
491
Rep 808
So here's the OEM BMW F30 mud flaps / splash guards on my 2015 435i RWD.
Fronts fit perfectly with no extra work needed... Rears will fit, but you will need to drill two new holes to match up mounting points and trim the under (not seen portion of the flap under car). Maybe 30-46 min of more work. Total side looks... Here's where I drilled the three new mounting holes for the rear. The "slit" allows the screw to sit better against the flap inside. The only other production notes is for the double-stick tape. Have a hair dryer or heat gun handy. Heat up the tape and surface before applying. And then once applied, hold with gator clips at least over night. Once on, it's water/weather proof! Last edited by exE36M3; 09-30-2020 at 11:08 AM.. |
09-30-2020, 12:24 PM | #32 |
Rep 893
That's very odd. Maybe there's TWO different OEM F30 flaps?
There's no way the fronts fit my 435iX - no existing fender holes are close, plus major cutting would be required. I'd need to drill new holes in my bodywork - not gonna happen. And it doesn't clear the 'air breather' right... And my rears were a simple direct fit, 2 new flap holes, all existing fasteners, no trimming, and the bottom-seal flap fits perfect... Go figure. My old post, with photos: https://f30.bimmerpost.com/forums/sh...69&postcount=4 |
09-30-2020, 09:51 PM | #33 |
9
Rep 74
If you ever go to certain tracks that have all these teeny tiny lil pebbles that your front wheels kick up into your rear doors and rear quarter panels. They leave scratches and sometimes very smalls dents. Also depends on whether or not you live somewhere with bad quality roads. They can be very useful my friend
10-21-2020, 01:03 PM | #34 |
Rep 424
do you mind posting another picture of how the flap mounts into the inner fender? Does the install require to take the back wheels off?
10-21-2020, 01:09 PM | #35 | |
Rep 424
10-22-2020, 09:17 PM | #36 | |
E36fiend
286
Rep 637
Drives: 2014 435i xDrive
obzen189.00 |
10-22-2020, 09:54 PM | #37 |
David
787
Rep 2,009
OEM ftw, rally armor is just Subaru and focus ST rice.
Paint stays much cleaner longer between washes and it looks great
04-29-2024, 02:17 AM | #38 | |
Rep 2
Idk if I’m just missing it but where exactly did you buy these ? I live in the nasty roads of Massachusetts and would die for these !!! I saw the name Tommy L Garage but wasn’t too sure if you bought them there |
04-30-2024, 05:40 PM | #39 | |
///M
191
Rep 698
Drives: '18 F80 M3 ZCP, '14 F30 328i
TLG are different, at Kies: https://www.kiesmotorsports.com/prod...for-bmw-f30-31
F80 ///M3 '18 S55/ ZCP / executive / 6MT / eventuri CF CAI V2/ CSF TMIC
F30 328i '14 N20 / dinan sport kit / premium pkg / 6MT / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI |
05-01-2024, 07:30 PM | #40 | |
Rep 2
THANK YOU!! |
wishbone190.50 |
