      02-13-2008, 12:29 AM   #1
Rook24V
33
Drives: 2018 X3 m40i
US Owners Manual & Training Information & Technical Details !!! A MUST READ!
Here we go! This is the BMW internal training document on the E82, to familiarize their technicians with the model. Seems to share a lot with the E90.
Enjoy!!
E82 Coupe Internal Training Manual and Technical Info Manual (pdf format)
Interactive Flash Based US 135i/128i Internal Training Manual and Technical Info
E82 US 128i/135i Non-iDrive Owner's Manual (pdf format)
E82 US 128i/135i iDrive Owner's Manual (pdf format) -- Courtesy of BMWNA
Interactive Flash Based US 135i/128i Non-iDrive Owner's Manual
niceast47.00
      02-13-2008, 12:30 AM   #2
asv
Drives: 135i
missing a link?
      02-13-2008, 12:32 AM   #3
asv
Drives: 135i
email it to me to (address removed) and i will upload it to my www server
      02-13-2008, 12:32 AM   #4
Rook24V
33
heh, sortof.
I keep getting a database error when trying to upload.
*sent*
      02-13-2008, 12:37 AM   #5
asv
Drives: 135i
Here is the link:
[link removed since 1addicts is hosting it now]]
I'm sure the addicts admins will grab it, and post it to the forums soon.
Excellent stuff Rook!
      02-13-2008, 12:46 AM   #6
asv
Drives: 135i
With the adapter cable, the USB connection is used to control the iPod and the jack socket for audio playback. The reason for this method of connection is that music tracks obtained from iTunes are subject to DRM and can only be played on the device to which they were downloaded. The copyright protection prevents digital transmission of the music track via USB.
The Y cable is supplied with the vehicle and also maybe ordered through the parts
department.
      02-13-2008, 01:03 AM   #7
cracka
cracka's Avatar
Drives: VO 1M
Good stuff! Thanks, Rook! :w00t:
      02-13-2008, 06:41 AM   #8
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Here's a bit of interesting news. Not sure I like it too much:
The 135i is equipped with a trim weight on the rear bumper. This component contributes to an overall improvement in axle-load distribution.
It appears that the e90's front components are identical to the 3 series too, making aftermarket development that much easier! I already have some aftermarket suspension bits on my e90 that's getting traded in that I may be able to re-use... I have H&R Sport springs that look to be a perfect fit... We'll see though.
For the most part the E82 and E88 front and rear suspension are identical to those of the E9X vehicles. With the exception of the 135i sport tuned version.
      02-13-2008, 06:45 AM   #9
AwesomeBMW
Freude am Fahren
17
Drives:
shouldn't the title of the thread read 82 and not 28? damn we're going back in time
"Oversteer is best because you don't see the tree that kills you" -- Richard Hammond
      02-13-2008, 06:48 AM   #10
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
Fixed that - now, what is the composition of and weight of the rear trim weight (the old - we're going to make this thing 50:50 ; -)?
      02-13-2008, 06:49 AM   #11
larryn
Whoa!!! Trinkets of Gold!!!
The following steering systems are fitted in E82 vehicles:
• Conventional rack-and-pinion steering with Servotronic assist hydraulic pump (vane cell pump) this is the standard steering for all 128i and 135i vehicles.
      02-13-2008, 06:51 AM   #12
AwesomeBMW
Freude am Fahren
17
Drives:
But its not 50:50. BMW's website says 47.7:52.3. Maybe they put the weight there to keep the back end from bing to unruly, like the porsches:ionoThis is a WAG and is in no way based on any factual information):wink:
      02-13-2008, 06:52 AM   #13
AwesomeBMW
Freude am Fahren
17
Drives:
Hydraulic steering
      02-13-2008, 06:52 AM   #14
larryn
More Gold!!
In order to satisfy that demand on the part of performance-oriented spirited drivers, as of March 2008 the 135i will be fitted with the NEW DSC function program that simulates the action of a mechanical differential lock. The system uses the typical BMW open type differential and is comprised solely of an electronic intervention program inside the DSC.
When the vehicle is in tight bend the DSC applies the brakes the spinning (inside) driving wheel, the torque is then transmitted to the outside wheel which is carrying most of the load, optimizing power and maintaining vehicle speed trough the corner. The new function implemented in the DSC control module is thus, in effect, DTC without modulation of engine output. The DSC and DTC functions are unaffected by it.
BMW High Traction DSC applies brake to the Low Traction wheel that loses traction.
Indisputable proof of new functionality to the DSC!!!
In comparison with a mechanical differential lock, the advantage of the new DSC program function is more than just the fact that it is substantially more cost effective. Whereas a mechanical differential lock is permanently active, this DSC Function only comes into action only when required and if the DSC/DTC is switched off. Nor does it add to the vehicle weight and fuel consumption.
Furthermore, the function does not affect handling stability in DSC or DTC mode and the familiar understeer tendency produced by mechanical differential locks is also avoided.
The feature will also be introduced on BMW 3 Series models with higher performance engines at a later date.
Not in the 3 series cars at all right now...
      02-13-2008, 06:59 AM   #15
AwesomeBMW
Freude am Fahren
17
Drives:
Rook :respekt: :drinking:
Best info in a long time
      02-13-2008, 07:00 AM   #16
larryn
Just about the only thing this doesn't mention is the oil cooler. Fantastic work, Rook! I'm working on getting it uploaded here. There's a problem with vBulletin. You did nothing wrong...
      02-13-2008, 07:08 AM   #17
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
Dam - I've spent too much time editing in the past few months. First major spelling booboo - page 4, VAVOS instead of VANOS.
But we do get the Brake Energy Regeneration - that means we may be restricted to certain replacement batteries.
      02-13-2008, 07:10 AM   #18
ARES45
Drives:
I don't like how it says as of March of 2008, does that mean delivered after March of 08 or built after March of 08?
"Don't run, you'll only die tired" ~ Gunship Pilot
      02-13-2008, 07:12 AM   #19
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
They told me that the underbody had been cleaned up to reduce lift - w/o seeing it it was hard to tell just how good a job they did. Look at the undertray on page 6 - NICE.
      02-13-2008, 07:13 AM   #20
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
I'm going to sticky this dude - Rook , great find!!!!
      02-13-2008, 08:00 AM   #21
larryn
These cars won't be delivered or serviced by any US BMW Centers until then. They are not going by build dates, just availability.
      02-13-2008, 08:30 AM   #22
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
For further reading, I did a look up of one of the alloys, HC400TD and came across this *.pdf file. Nice chewy slide show for you technogeeks!!
http://www.google.com/url?sa=t&ct=re...kYRJwJPTafSMzg
