BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      03-12-2014, 11:49 PM   #67
regular guy
Drives: Sprint car
275d - P0171, 275D - P0172
275D - P0171
275D - P0171
Information saved inDME
Fault code275D - P0171
Fault textOxygen sensor limit position fault, bank 1
Fault descriptionSystem Too Lean (Bank 1)
Condition for fault identificationTest condition: Controller pegged at the MIN threshold 0.75 (K_LAM_REG_F_MIN) for at least a period of 30 sec. K_LAM_DIAG_REG_T
Terminal condition: Engine running
Voltage condition: none
Condition for fault memory entryController limit for K_LAM_DIAG_REG_T (60s)
Action in service1. Check fuel system for leaks, initiate test routine as indicated
2. Check exhaust system for leaks
3. Check HFM for leaks and correct operation
4. Read out oxygen sensor diagnostic data, perform both oxygen sensor test routines as indicated
Fault effect and breakdown warningEngine runs erratically
Potential collateral error: Miss errors and lamda error MIL after engine runs 2x
Driver informationWarning light: MIL
Service instructionNone
275D - P0172
275D - P0172
Fault code275D - P0172
Fault descriptionSystem Too Rich (Bank 1)
Condition for fault identificationTest condition: Controller pegged at MAX threshold 1.25 (K_LAM_REG_F_MAX) for time of at least 30 sec. (K_LAM_DIAG_REG_T)
      03-13-2014, 12:13 AM   #68
regular guy
Drives: Sprint car
27ba - P0171, 27ba - P2177, 27ba - P0172, 27ba - P2178
27BA - P0171
27BA - P0171
Fault code27BA - P0171
Fault textFuel system, lambda/charge plausibility, bank 1
Condition for fault identificationTest condition: Deviation from mean value (depending on psau, lam, aq) in percent is determined and compared with the max. deviation (in relation to rpm/load factor) KF_FPLAU_OBD_LAM_DELTA_ML_MAX
Condition for fault memory entry10000 ms
Action in service1. Check the fuel system for leaks
2. System test routine
3. HFM and charge path must be flawless.
4. Defective fuel pressure sensor
Fault effect and breakdown warningMIL on after engine runs 2x
27BA - P0171
27BA - P0171
Condition for fault identificationTest condition: Deviation from mean value (depending on psau, lam, aq) in percent is determined and compared with the max. deviation (in relation to rpm/load factor) KF_FPLAU_OBD_LAM_DELTA_ML_MAX * expansion factor (KL_FPLAU_OBD_LAM_CSS_F)
27BA - P2177
27BA - P2177
Fault code27BA - P2177
Fault descriptionSystem Too Lean Off Idle (Bank 1)
27BA - P2177
27BA - P2177
27BA - P0172
27BA - P0172
Fault code27BA - P0172
27BA - P0172
27BA - P0172
27BA - P2178
27BA - P2178
Fault code27BA - P2178
Fault descriptionSystem Too Rich Off Idle (Bank 1)
27BA - P2178
27BA - P2178
      03-15-2014, 01:26 AM   #69
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Originally Posted by tmntmn
Do you know what codes 2789 and 278a are
Thanks
Cat efficiency bank 1 and 2.
Same as P0420 and P0430
If you have Catless exhaust or high flow cats without a tune, these are the two faults you will get.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      03-21-2014, 01:08 PM   #70
Petros
Drives: M3
What about 273B
      03-23-2014, 11:27 AM   #71
regular guy
Drives: Sprint car
273b - P2273, 273b - P0156, 273b - P014a, 273b - P2272
273B - P2273
273B - P2273
Fault code273B - P2273
Fault textOxygen sensor vibration check behind catalytic converter, bank 2
Fault descriptionO2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 2)
Condition for fault identificationTest condition: Trim control suspicion with observation of P component and I component leads to guided LEAN control; if the post-cat oxygen sensor signal fails to respond accordingly, the error is assigned to the post-cat oxygen sensor
Condition for fault memory entryAfter K_LAVK_OBD_ACT_NK_M_CNT (1x) LEAN control events the oxygen sensor remains stuck at RICH
Action in service1. Check exhaust system for leaks
2. If OK, replace post-cat oxygen sensor LSNK B2
Fault effect and breakdown warningMIL on after engine runs 2x / no effects on drivability
273B - P0156
273B - P0156
Fault code273B - P0156
Fault descriptionO2 Sensor Circuit (Bank 2 Sensor 2)
Condition for fault identificationTest condition: Oxygen sensor signal too low, low threshold 649 mV (K_LANK_OBD_S_VL_US) for 2 (K_LANK_OBD_S_CNT) /K_LANK_OBD_S_AUTOM_CNT requests
Condition for fault memory entryFull-load K_LANK_OBD_S_VL_T (6s) for K_LANK_OBD_S_CNT (3x) /K_LANK_OBD_S_AUTOM_CNT (3x) attempts
273B - P014A
273B - P014A
Fault code273B - P014A
Fault descriptionO2 Sensor Delayed Response - Rich to Lean (Bank 2 Sensor 2)
Condition for fault identificationTest condition: * Determine whether oxygen sensor voltage remains above 649 mV (K_LANK_OBD_S_SA_US)
* Fault after 2 (K_LANK_OBD_S_CNT)/K_LANK_OBD_S_AUTOM_CNT attempts
Condition for fault memory entryTime K_LANK_OBD_S_SA_T (3s) after SA for K_LANK_OBD_S_CNT (2x) /K_LANK_OBD_S_AUTOM_CNT (3x) tries
273B - P2272
273B - P2272
Fault code273B - P2272
Fault descriptionO2 Sensor Signal Biased/Stuck Lean (Bank 2 Sensor 2)
Condition for fault identificationTest condition: Trim control suspicion with observation of P component and I component leads to guided RICH control; if the post-cat oxygen sensor signal fails to respond accordingly, the error is assigned to the post-cat oxygen sensor
Condition for fault memory entryAfter K_LAVK_OBD_ACT_NK_F_CNT (1x) RICH control events the oxygen sensor sticks at LEAN
      03-23-2014, 11:31 AM   #72
regular guy
Drives: Sprint car
2789 - P0420
2789 - P0420
2789 - P0420
Fault code2789 - P0420
Fault textCatalytic-converter conversion, bank 1
Fault descriptionCatalyst System Efficiency Below Threshold (Bank 1)
Condition for fault identificationTest condition: Diagnosis value above threshold K_KAT_OBD_WERT_MAX
Terminal condition: Engine running - Condition idle or part-load
Condition for fault memory entrynone
2. No faults related to oxygen sensor or fuel system or VANOS should be present
3. Conduct oxygen sensor test routines, even if no oxygen sensor fault is present.
4. Replace catalytic conveter near engine
      03-23-2014, 11:33 AM   #73
regular guy
Drives: Sprint car
278a - P0430
278A - P0430
278A - P0430
Fault code278A - P0430
Fault textCatalytic-converter conversion, bank 2
Fault descriptionCatalyst System Efficiency Below Threshold (Bank 2)
      04-06-2014, 12:56 PM   #74
regular guy
Drives: Sprint car
2b15 - P1636, 2b15 - P2100, 2b15 - P0638
2B15 - P1636
2B15 - P1636
Fault code2B15 - P1636
Fault textThrottle-valve actuator, governor monitoring, bank 1
Fault descriptionThrottle Valve Circuit (Bank 1)
Condition for fault identificationTest condition: Actuator shifts to Failsafe mode
Terminal condition: TERM87
Voltage condition: None
Condition for fault memory entry10 ms
Action in service1. Clear fault memory, conduct EDR electronic throttle valve control system test,
2. Check plug and wiring harness at throttle valve sensor DKG1 and electronic throttle valve control EDR1,
3. Replace DKG1 or EDR for Bank 1
Fault effect and breakdown warningCC message
Engine speed limited
Reduced power
Driver informationWarning light: MIL, EML, CC message, backup program
2B15 - P2100
2B15 - P2100
Fault code2B15 - P2100
Fault descriptionThrottle Actuator 'A' Control Motor Circuit/Open
Reduced power
2B15 - P0638
2B15 - P0638
Fault code2B15 - P0638
Fault descriptionThrottle Actuator Control Range/Performance (Bank 1)
Condition for fault identificationTest condition: Actuator reports system error
Reduced power
2B15 - P0638
2B15 - P0638
Condition for fault identificationTest condition: Actuator reports regulator error
Action in service1. Clear fault memory, carry out EDR electronic throttle valve control system test,
2. Check plug and wiring harness to throttle valve sensor DKG1 and EDR1,
3. Replace DKG1 or EDR Bank 1,
4. With UMWB engine protection check throttle valve assembly for stiction
Reduced power
      04-06-2014, 01:11 PM   #75
regular guy
Drives: Sprint car
2b25 - P154c, 2b25 - P154d, 2b25 - P154e, 2b25 - P154f
2B25 - P154C
2B25 - P154C
Fault code2B25 - P154C
Fault textThrottle-valve monitoring, bank 1
Fault descriptionThrottle Actuator Monitoring Dissimilar Desired Values (Bank 1)
Condition for fault identificationTest condition: Difference too large
Voltage condition: Battery voltage > 6.8V (k_egas_can_ed_ub_min)
Condition for fault memory entry300 ms
Action in service1. Clear fault memory, EDR system test
2. Check plug, wiring harness and power supply to EDR1
3. Replace EDR1
Reduced power
2B25 - P154D
2B25 - P154D
Fault code2B25 - P154D
Fault descriptionThrottle Actuator Monitoring Incorrect Actual Value (Bank 1)
Action in service1. Clear fault memory, EDR electronic throttle valve control system test,
2. Check 2nd plug, wiring harness and power supply for throttle valve DK1, EDR1 and DME,
3. Replace DK1
Reduced power
2B25 - P154E
2B25 - P154E
Fault code2B25 - P154E
Fault descriptionThrottle Actuator Monitoring Actual Value / Desired Value Correlation (Bank 1)
Condition for fault memory entry350 ms
2. Check plug, wiring harness and power supply to throttle valve DK1 and EDR1
3. Check throttle valve assembly B1 for mechanical stiction
4. Replace DK1
5. Replace EDR1
Reduced power
2B25 - P154F
2B25 - P154F
Fault code2B25 - P154F
Fault descriptionThrottle Actuator Monitoring Reset Error (Bank 1)
Condition for fault identificationTest condition: Not identical for too long
Condition for fault memory entry250 ms
3. Replace EDR1
Reduced power
      04-06-2014, 01:23 PM   #76
regular guy
Drives: Sprint car
2779 - P0442
2779 - P0442
2779 - P0442
Fault code2779 - P0442
Fault textDMTL leakage detection
Fault descriptionEvaporative Emission System Leak Detected (small leak)
Condition for fault identificationTest condition: Current rise during diagnosis less then (dmtl_i_ref - dmtl_i_min) x 0.21 (K_DMTL_I_FAKT_GROB) + dmtl_i_min
Terminal condition: TERM15 off
Voltage condition: 11V < UBatt < 14.5V (k_dmtl_ub_min ; k_dmtl_ub_max), with start using tester: None
Condition for fault memory entryNone
Action in service1. Check filler cap seal
2. Pressurize tank and search for leaks
Fault effect and breakdown warningCC message / possible gasoline odor
Driver informationWarning light: MIL, CC message
      04-09-2014, 11:25 PM   #77
regular guy
Drives: Sprint car
277c - P114a, 277c - P114b, 277c - P2096, 277c - P2097
277C - P114A
277C - P114A
Fault code277C - P114A
Fault textOxygen sensor trim control diagnosis, bank 1
Fault descriptionPost Catalyst Fuel Trim Via Oxygen Sensor System Too Rich (Bank 1)
Condition for fault identificationTest condition: LEAN suspected under consideration of P-component ((6 (K_LA_TRIM_P_ANZ_MAX) + 3 (K_LA_TRIM_DIAG_P_SCHW P-spikes)) leads to deliberate RICH/LEAN control activation; if the pre-catalyst and post-catalyst oxygen sensors respond accordingly a trim control error is recognized.
Action in service1) Check intake and exhaust systems for leaks; incl. HFM operation/ ..if no fault is present..
2.) Conduct oxygen sensor test routine
3.) If the test does not produce any results and the trim control error is still present ->Replace the sensor before the catalytic converter
277C - P114B
277C - P114B
Fault code277C - P114B
Fault descriptionPost Catalyst Fuel Trim Via Oxygen Sensor System Too Lean (Bank 1)
277C - P114A
277C - P114A
Condition for fault identificationTest condition: LEAN suspected under consideration of I-component (( 2 (K_LA_TRIM_DIAG_I_MIN_SCHW) recognition of I-component limit) leads to deliberate RICH/LEAN control activation; If the pre-catalyst and post-catalyst oxygen sensors respondaccordingly a trim control error is recognized.
277C - P2097
277C - P2097
Fault code277C - P2097
Fault descriptionPost Catalyst Fuel Trim System Too Rich (Bank 1)
Condition for fault identificationTest condition: LEAN suspected under consideration of I-component (( 2 (K_LA_TRIM_DIAG_I_MIN_SCHW) recognition of I-component limit) leads to deliberate RICH/LEAN control activation; If the pre-catalyst and post-catalyst oxygen sensors respond accordingly a trim control error is recognized.
277C - P114B
277C - P114B
Fault descriptionPost Catalyst Fuel Trim System Too Lean (Bank 1)
Condition for fault identificationTest condition: RICH suspected under consideration of I-component (( 2 (K_LA_TRIM_DIAG_I_MAX_SCHW) recognition of I-component limit) leads to deliberate RICH/LEAN control activation; If the pre-catalyst and post-catalyst oxygen sensors respond accordingly a trim control error is recognized.
277C - P2096
277C - P2096
Fault code277C - P2096
      04-11-2014, 11:32 AM   #78
regular guy
Drives: Sprint car
273d - P2415
273D - P2415
273D - P2415
Fault code273D - P2415
Fault textOxygen sensor, part/full-load diagnosis, before cat., bank 2
Fault descriptionO2 Sensor Exhaust Sample Error (Bank 2 Sensor 1)
Condition for fault identificationTest condition: Oxygen sensor voltage less than 4800 mV (K_LAVK_OBD_TL_SCHW_MAX) and greater than 3149 mV (K_LAVK_OBD_TL_SCHW_MIN) for a total of 1 (K_LAVK_OBD_TL_CNT) after a lag period before active functionality of 8s (K_LAVK_OBD_TL_T) seconds
Terminal condition: Engine running - Condition part-load or full-load
Condition for fault memory entryK_LAVK_OBD_TL_T- seconds (8s) lag for K_LAVK_OBD_TL_CNT-attempts (1x)
Action in service1. Install oxygen sensor in exhaust system (oxygen sensor exposed to ambient air)
Possible negative effects on drivability
      04-13-2014, 09:39 AM   #79
regular guy
Drives: Sprint car
2b4c - P0111
2B4C - P0111
2B4C - P0111
Fault code2B4C - P0111
Fault textIntake-air temperature sensor, plausibility
Fault descriptionIntake Air Temperature Sensor 1 Circuit Range/Performance (Bank 1)
Condition for fault identificationTest condition: Engine runs with limited dynamic response in part-load range
Condition for fault memory entry30 s
Action in service1. Check plug and wiring harness at temperature sensor B1
2. Replace temperature sensor B1
Fault effect and breakdown warningDriver does not notice
      04-13-2014, 10:16 PM   #80
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Any idea what fault code P1118 means?
      04-26-2014, 11:25 PM   #81
Facsombh
Facsombh's Avatar
Drives: e90 M3
Can you check what P0500 means..
      04-27-2014, 03:03 PM   #82
regular guy
Drives: Sprint car
2b13 - P0500
2B13 - P0500
2B13 - P0500
Fault code2B13 - P0500
Fault textSpeed recording
Fault descriptionVehicle Speed Sensor 'A'
Condition for fault identificationTest condition: v_direct == 0
Condition for fault memory entry120 ms
Action in service1. Read out stored error codes logged in DSC
2. Check wire and/or sensor
Fault effect and breakdown warningEngine speed governed to K_N_BEGR_V_FEHLER
      04-27-2014, 08:32 PM   #83
Facsombh
Facsombh's Avatar
Drives: e90 M3
Originally Posted by regular guy View Post
2B13 - P0500
2B13 - P0500
thank you !
      05-02-2014, 09:00 PM   #84
Petros
Drives: M3
What about CDB6, 2AF9, 2B61, and 2B20?
      05-04-2014, 05:49 PM   #85
regular guy
Drives: Sprint car
2af9 - P0116, 2af9 - P0117, 2af9 - P0118, 2af9 - P3198
2AF9 - P0116
2AF9 - P0116
Fault code2AF9 - P0116
Fault textCoolant temperature sensor
Fault descriptionEngine Coolant Temperature Sensor 1 Circuit Range/Performance
Condition for fault identificationTest condition: (Measured value + 20°Kelvin (K_TMOT_SK_DELTA) < oil temperature
Terminal condition: None
Condition for fault memory entry2000 ms
Action in service1. Check plug and wiring harness,
2. Replace coolant temperature sensor
Fault effect and breakdown warningMIL lamp comes on after engine runs 2x / idle may be high for brief period after engine start
2AF9 - P0117
2AF9 - P0117
Fault code2AF9 - P0117
Fault descriptionEngine Coolant Temperature Sensor 1 Circuit Low
Condition for fault identificationTest condition: Measured value >= 136°C (K_TMOT_DIAG_MAX)
2AF9 - P0118
2AF9 - P0118
Fault code2AF9 - P0118
Fault descriptionEngine Coolant Temperature Sensor 1 Circuit High
2AF9 - P3198
2AF9 - P3198
Fault code2AF9 - P3198
Fault descriptionEngine Coolant Temperature 1 Gradient Too High
Condition for fault identificationTest condition: Measured value gradient > 1 K/100 ms (K_TMOT_DIAG_GRAD_MAX)
      05-04-2014, 05:57 PM   #86
regular guy
Drives: Sprint car
2b20 - P0222, 2b20 - P0223
2B20 - P0222
2B20 - P0222
Fault code2B20 - P0222
Fault textThrottle-valve sensor, bank 2
Fault descriptionThrottle/Pedal Position Sensor/Switch 'B' Circuit Low
Condition for fault identificationTest condition: Measured value <= 0.2V (K_EGAS_WDK_MIN)
Condition for fault memory entry100 ms
2. Check installation of throttle valve sensor DKG2,
3. Replace DKG2
Reduced power
2B20 - P0223
2B20 - P0223
Fault code2B20 - P0223
Fault descriptionThrottle/Pedal Position Sensor/Switch 'B' Circuit High
Condition for fault identificationTest condition: Measured value >= 4.8V (K_EGAS_WDK_MAX)
3. Replace DKG2
Reduced power
      05-04-2014, 06:02 PM   #87
regular guy
Drives: Sprint car
CDB6 - UNK01, Post-88
2AF9 - P0116, Post-85
2B61 - DME - Gearbox input speed/sensor slipping clutch (no further information on 2B61)
2B20 - P0222, Post-86
      05-04-2014, 06:30 PM   #88
regular guy
Drives: Sprint car
CDB6
CDB6
CDB6
Fault codeCDB6
Fault textDiagnosis monitors the required torque.
Fault descriptionMalfunction monitoring conditions The fault is detected if the torque is higher than the required torque.
Temperature condition - None
Time condition - None
Other preconditions - None
Terminal status - Terminal 15
Voltage precondition: Vehicle voltage between 9V and 16V
Condition for fault memory entryThe fault is entered immediately.
Action in serviceCarry out bus system analysis
Fault effect and breakdown warningNone
Driver informationNone
I found this description on BMW ISTA, but can't guarantee it's for M3.
m3post
