      01-27-2024, 08:45 AM   #1
paixerino
Germany
Drives: E87 123d 2011
Sunroof leak
Hello!
Recently due to heavy rain i noticed that the passenger side carpet is fully wet. I checked the door and it had no leaks. Next i tested the sunroof to see if it was clogged. The water goes down completely fine, has no puddle of water in it, but i still see water coming from between the plastics under the glovebox into the passenger footwell.
Is it possible that somehow the drain that goes through the pillar is either cracked/broken or could this still be a clog somewhere in the line? Water seems to at least flow pretty much instantly through to the bottom of the drain.
      01-31-2024, 12:53 AM   #2
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
Look at where the fresh air intake is. There is supposed to be a plastic rise with a foam gasket. If that is not there you'll get water through the blower motor. There are also 2 drains on either side. if one is blocked water may be backing up.
You will have to remove the cabin air filters and the wiper cowl thing to see.
      01-31-2024, 07:43 AM   #3
paixerino
Germany
Gonna definitely check that out, thank you a lot!!
