BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      12-05-2011, 09:07 PM   #67
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
I tried to get my rear camber to -2.4 but my guy says my max is -2.17 why?
anyone can help?
my front is -3.0
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      12-12-2011, 11:54 AM   #68
Dodge2Dub
Drives: E90 M3; Ducati
Originally Posted by 4sevens.com View Post
zcp with edc
gc plates
-3 front
-2 rear
for street and track.
4sevens, how is your tire wear on the street?
All, will the GC Plates work with the EDC still entact?
Are these the GC plates that you guys are using?
http://www.ground-control-store.com/...ion.php?II=897
E90 M3: Some cool stuff...more to come
Ducati 1199 Panigale: Bucket full of mods
      12-12-2011, 12:07 PM   #69
quads
Drives: bac mono
The wear is fine as I frequently go to the track. When I don't I just drive a bit more aggressively on the street! The cornering ability is a difference between night and day.
yes edc is intact
yes those are the plates
      12-14-2011, 06:49 AM   #70
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
anyone can help?
my front is -3.0
Can you take a picture of your rear suspension lower camber arm (4) and toe arm (13), in particular where they mount to the sub frame?
      02-16-2012, 07:15 PM   #71
Eugene-TAIWAN
Taiwan
249
do you mean i have to loosen them and adjust them to ideal camber then tighten it?
      03-01-2012, 11:09 PM   #72
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
My new settings are as follows:
Front:
1/32" toe out per side
-2.0* camber per side
Rear:
1/16" toe in per side
-1.8* camber per side.
Thrust Angle = 0.00
Car drives worlds better with a hair of toe out on the front end compared to zero toe or toe in. A bit more sensitive, but turn in is great along with grip.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      03-08-2012, 12:15 AM   #73
yyoo
Drives: 2011 E90 M3 DCT
Front:
-3.0 camber
1/16 total toe out
Rear:
-2.0 camber
1/8 total toe in
      07-26-2012, 07:13 AM   #74
gsrbri
gsrbri's Avatar
Drives: F87 6MT
2011 E90 ZCP - Stock Suspension
Along w/new Michelin Super Sports, I had my car aligned as-follows:
F: -1.4 deg camber and 0 toe (before was 1.0 deg from factory)
R: -2.0 deg camber and 1/16 toe-in (before was 1.4 deg from factory)
I'm running factory tire width w/ZCP wheels and suspension. With the strut pins pulled, -1.4 was the most camber I could get.
Car drives smoothly, has nice turn-in, and no tramlining. It will see another 3 or 4 track days this year. I'll provide feedback.
-Brian
      08-07-2012, 07:02 PM   #75
grussell
grussell's Avatar
Drives: 2012 SG E92 M3
Here are my current specs. Big improvement over stock for the street.
Car has Dinan springs, stops and camber plates.
      10-30-2012, 03:07 PM   #76
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I ran:
-3.0 front camber; -2.0 rear camber
1/16 toe in all around
and it ate the front insides more than I'm comfortable with. They were wearing ~50% faster than the middle even with little street driving and a couple of track days a month.
Now I run:
-2.5 LF/-2.0 RF; -1.7 rear
0 toe in front; 1/8 in rear
I will report back with wear with the new setup.
      10-30-2012, 03:52 PM   #77
ortho281
ortho281's Avatar
Drives: 2011 E92 M3 6MT
Recently switched to -2.4f/.1.8r due to excessive inside tire wear on rears!
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL
      10-30-2012, 06:19 PM   #78
Sleeper519
Sleeper519's Avatar
Drives: 08 E92 M3 DCT
Just got new set of super sports and thus a new alignment:
2008 w/ EDC, GC plates
Front: camber -2.6 , toe 1/16" IN street , 1/16" OUT track.
Rear: camber -2.0 , toe 1/16" IN.
Just got back from VIR, turn in is great, stable under high speed braking, smooth on highway. Will give a wear update as well.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20
      10-30-2012, 07:03 PM   #79
Porschefile
59
Drives: E92 M3
Do you adjust the toe link or is the camber different street and track as well?
      11-02-2012, 10:01 AM   #80
Sleeper519
Sleeper519's Avatar
Both front and rear camber stays static. Only front toe is adjusted.
      11-07-2012, 11:05 AM   #81
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
From yesterday. The toe was equal but some guy go into the lasers when he pushed print.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      11-22-2012, 08:42 PM   #82
Sleeper519
Sleeper519's Avatar
Bigjae,
you had asked how I had marked the left front tierod: one black hash mark for street--two marks for track. It's about ~2/3 of a revolution to go from 1/16" toe IN to 1/16" toe OUT. (counterclockwise lengthens the rod and hence toe goes out). You only have to do one side. * I would only advise doing this after marking it while the car is on the alignment rack for precise measurements.*
It's a small change but I think it makes a noticeable difference on turn in, but saves wear on the tires for the DD.
      11-23-2012, 12:03 PM   #83
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
Awesome and thanks! I think I'll cover the marks with some clear tape or something so they don't go AWOL from dirt, rain, and general road use.
      12-02-2012, 02:19 AM   #84
Xcelrrate
Driver
Xcelrrate's Avatar
Drives: E90 ///M3
2008 BMW E90 M3  [10.00]
20 days ago, I lowered my car, week and a half ago, I got my Super Sports...
Stock 220 wheels
F255/35/19
R276/35/19
H&R Sport Plus
F: 12mm MS Spacers
R: 10mm MS Spacers
My specs were way off prior to the alignment... musta been from the drop?
Initial readings:
F camber L: -1.73° R: -1.96°
R camber L: -1.86° R: -1.94°
F toe L: -0.32° R: -0.20°
R toe L: -0.65° R: 0.00°
Thrust angle 0.33°
Final readings
F camber L: -1.89° R: -1.89°
R camber L: -1.90° R: -1.90° <-- Should have I got more? There was plenty room to, but what about thread life or straight line acceleration ?
F toe L: 0.06° R: 0.06° <-- is that close enough to Zero?
R toe L: 0.10° R: 0.10°
Thrust angle -0.01°
My alignment guy was able to get -2.00˚ on my front right but wasn't able to achieve the same on the driver side...WHY? -2.0˚ would have been nice considering I don't have Camber plates! So we had to back it down to equal the other side.
Specs for the Trust angle is -0.07˚ - 0.07˚ How the hell did I end up at 0.33˚
Any thoughts about my initial readings? It just looks weird to me
I have to say though (don't know if its just in my head) but the car feels faster. lol Seems like it has less rolling resistance.. feels silky smooth, like more neutral I think... can't put a word to it, but it feels NICE and a night and day difference from prior...
Stable at high speed, but didn't test high speed braking stability. I will next time I get the chance too. Hopefully on a track Soon!
'08 Jerez Black E90 ///M3
Pics of my Ride
      12-07-2012, 09:02 AM   #85
Car54
Drives: 2014 M-Sport Wagon - EBII
Bigjae,
Why do you just adjust one side? Doesn't your center steer go off?
      12-10-2012, 09:56 AM   #86
Sleeper519
Sleeper519's Avatar
It goes off so slightly that its hardly even noticeable. It's just much simpler to do one side, doing both sides just adds more complication. Yes, I want it totally straight for my DD but this is fine for the track.
Now, a much larger toe swing than we're doing would be a whole different thing...
      01-11-2013, 10:58 PM   #87
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
im at -2.53 front and neutral toe and -1.92 rear with slight toe in.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      01-28-2013, 10:04 PM   #88
joedr
Drives: BMW
I like
-1 to -2 Front
-1 Rear
m3post
