BMW M3 Forum (E90 E92)
BPM
      01-28-2013, 10:18 PM   #89
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
not enough.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      01-28-2013, 10:19 PM   #90
PrimeBMW
PrimeBMW's Avatar
662
Drives: E46 M3+S62, E92 M3
-4.4 front and-3.0 rear (E46 M3)
-2.6 front and-2.0 rear (E92 M3)
      01-28-2013, 10:34 PM   #91
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
what is max at the rear on e9x?
      01-29-2013, 05:42 AM   #92
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I'm at 2.5 fr and factory spec for rear camber. Loved it! Although the rears on the outside edge took a beating.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-31-2013, 11:01 AM   #93
xccess
18
Drives: none
Originally Posted by LiM3y View Post
These sheets are from when I knocked the alignment out on the stock set up. The original dealer aligned me to 335 specs, which are different. Another dealer faxed me the specs shown on this sheet. When I had the Eibachs added, the new specs lined up with these specs limits - they didn't even comment that the car had been dropped a little. The car has been aligned twice since the install - once immediately afterwards, and again after I hit a kerb hard during a track day and knocked the alignment out slightly enough to be irritating. I don't have the before/after spec sheet any more
I had Eibach Pro-Kit for E93 M3 and they did the factory spec, however it wear out my front tire in side pretty fast, does your do the same thing? or you have different kits then me?
      01-31-2013, 09:16 PM   #94
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
factory spec should wear out the outside edge faster if you ever turn.
      02-01-2013, 03:00 PM   #95
Sleeper519
Sleeper519's Avatar
Drives: 08 E92 M3 DCT
I was advised to keep rear camber within ~0.5 degrees of front to keep it balanced, hence -2.6 Fr and -2.0 R for me, which was about all we could get in the rear.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20
      02-13-2013, 09:22 AM   #96
RingMeister01
Croatian
RingMeister01's Avatar
884
Drives: PORSCHE
Love this thread
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only)
Husqvarna FS450 (track only)
Looking for an SUV
      02-13-2013, 10:42 PM   #97
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
was thinking of going more front and rear. any suggestions. most street driving involves getting to and from the track. was thinking 3ish front and 2.2-2.3 rear? sound reasonable?
      02-21-2013, 06:08 AM   #98
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
I run Conti DW tires (265/35/18 fr, 285/35/18 r) on the street, so the rate of wear is less noticeable, with rears wearing about twice as fast as the fronts. On the track (275/35/18 sq), the outside of my fronts is getting wrecked. I am having camber plates installed for next season
      03-01-2013, 06:02 PM   #99
llis
octane chick
llis's Avatar
Drives: ex-M
2013 BMW M3 ZCP  [10.00]
2003 BMW M5  [0.00]
New car, new specs.
Before: 2011 E92 M3 with GC camber plates--
Originally Posted by llis View Post
Camber:
Front: -3º left, -3.1º right
Rear: -1.9º left, -1.9º right
Toe:
Front: .12º left, .11º right
Rear: .11º left, .14º right
Now: 2013 E92 M3 OEM, with pins pulled--
Camber
Front: -1.42º left, -1.49º right
Rear: -1.65º left, -1.70º right
Toe
Front 0.02º left, 0.02º right
Rear: 0.06º left, 0.06º right
I wish I knew what was different in the rear of the 2013 to account for 0.2º of difference. Both cars were maxed in the rear.
      03-11-2013, 03:16 PM   #100
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
Just dropped off my stock E90 ZCP and I'm eating lunch while Speedware Motorsports gets to work. Sounds like with pins out they're getting -1.2 to -1.6 front typically. I'll update when done.
      03-11-2013, 03:44 PM   #101
urBan_dK
urBan_dK's Avatar
Drives: 2008 E90 M3
Doing that after your track day? I bet your fronts look like hell. I know mine did and I had Speedware do this before, LOL.
      03-11-2013, 06:28 PM   #102
Transfer
Transfer's Avatar
5254
Well as you know I'm the second owner and it turns out the prior owner already had pins pulled and camber maxed. Speedware cleaned up my toe but really they didn't have to do much to the camber.
Front
Camber -1.5 L/R
Toe 0 L/R
Caster 7.17/7.31 L/R
Rear
Camber -1.8 L/R
Toe 0.09 L/R
I was wondering how my outside shoulders didn't get destroyed at my first track day at that explains it. That and I'm just so smooth . I'll be at Pacific Raceways this sunday if you want to come out!
      03-28-2013, 09:11 PM   #103
C-N-M3
C-N-M3's Avatar
Drives: AW2012 M3 E92 &2010 911 GT2 RS
I had a Ohlins TTX on my set up right now.
Here is a alignment
      03-29-2013, 05:08 PM   #104
grussell
grussell's Avatar
Drives: 2012 SG E92 M3
Went from
Front
Camber -2.2
Toe 0
Rear
Camber -1.8
Toe in .20
To the following. It drives much better on the freeway but it took a lot life out of the cornering.
      03-31-2013, 09:59 PM   #105
MikeBlaszczak
Drives: 2010 BMW M3 Coupe
Originally Posted by grussell View Post
Went from
Front
Camber -2.2
Toe 0
Rear
Camber -1.8
Toe in .20
Nothing matches.
      06-26-2013, 07:36 PM   #106
Dub A
Dub A
Drives: e92 IB
KW sleeve POST alignment
Just got my KW sleeves put on - im at 3/4's of the way down, believe that equates to 1.5" drop in the front and 1" in the rear.
Here are my post alignment specs - what do you guys think?
2009 e92 m3 IB - Matte Grills/Gills, Lux v3, KW Sleeve, Akra
      06-26-2013, 08:53 PM   #107
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Stock ZCP Suspension with CG Camber Plates:
Camber, Front Left, Front Right: -2.3
Toe, Front Left, Front Right: 0
Camber, Rear Left, Rear Right: -1.6
Toe, Rear Left, Rear Right: 3/32 in
I also have stock ZCP wheels with 255 35 19 F and 275 35 19 R Michelin PSS with MS 15mm spacers F and 10mm spacers R.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      06-28-2013, 10:48 AM   #108
meko
meko's Avatar
179
Drives: E92 M3 - 535i Sport
^ What are your thoughts on that setup?
      07-04-2013, 07:27 PM   #109
MaxL
69
Drives: E90 M3, Cayenne T, 991 GT3
Guys, when comparing set ups it makes sense to specify if you are running stock or staggered tire set up, what tires, and how much street driving the car sees.
Case in point - I switched from AD08 to PSS, PSS need more camber front and rear. Also, square set up would warrant closer front and rear camber settings, while stagger similar to factory seems to work better with close to 1' of difference (e.g, -2.6' and -1.6' worked well for me on staggered AD08, but if I were not doing as much street driving, I'd add another -.1' or -.2' to both)
      07-04-2013, 07:46 PM   #110
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
im -3.5 front and -2.75 rear now on my e46 with square set of nt01s, 273-35. neutral front toe and slight in on rear.
m3post
