01-30-2021, 06:40 PM | #23 |
Rep 4,175
E46 M3 uses the same mounts and comes with a heatshield from factory.
https://www.ecstuning.com/b-genuine-...t/22111094624/ I'll probably install these with the new Powerflex mounts too since they are cheap. E36 M3 has similar heat shields too but they are 3x the price. Wrapping the headers is just way too much work/cost to fix VT's design problems. |
MilehighM3915.00 |
01-31-2021, 12:17 AM | #24 | |
Rep 988
Wonder why BMW only made that for the e46 and not the e90 from the factory. |
01-31-2021, 12:59 AM | #25 |
Rep 4,175
This pic of the S65 getting dyno-ed shows a heat shield around the engine mount. Not sure why it isn't in the production car as it clearly needs it.
I've ordered the shields and Powerflex mounts. Let you know how they fit. I may also heat wrap the mounts, let's see how paranoid I wanna be. |
01-31-2021, 10:02 AM | #26 | |
Rep 4,445
02-01-2021, 10:17 AM | #27 |
65
Rep 78
As Redd noted above, it's the same heat shield that is used on the E36 and E46. It is captured between the engine mount bushing and engine mount arm, with a pin that keeps it from rotating. The body of it then hangs over the engine mount bushing about 1/2" away. Nothing to cause vibration there unless you didn't clock the pin correctly and it is touching the mount, frame rail or header:
Heat Shield: 22111094624 As for the physical motor mount bushing, it's the same part number that the E36 uses, which makes it significantly less surprising that they break under an E9X M3: E36: 11812283798 E46: 11812283798 E90: 11812283798 |
02-01-2021, 07:25 PM | #28 | |
Rep 4,445
02-16-2021, 03:49 PM | #29 | |
Rep 4,445
My pics of new and current state.
02-18-2021, 03:04 PM | #30 |
Rep 4,445
Pulled the mounts out and replaced with Corteco mounts. Significant reduction in NVH. Not in a hurry to put the vibra-techics back in.
02-18-2021, 05:22 PM | #31 |
Rep 4,175
Bubbles, your mounts appear to be in good shape tho? What's the mileage on them?
VT customer service has been disappointing. After one email saying "we'll get back to you today" 2 weeks ago, they have gone silent. Repeated reminder emails from me have gone unanswered. Definitely not gonna recommend their products again. |
02-18-2021, 10:02 PM | #32 | |
Rep 4,445
Approximately, 7k with several ambient temperature days of 30C (90F). My guess is the mounts have heat cycled beyond the useful life. The exposed part of the rubber is sticky and looked to be cooked. Check out the difference between the inner and outer rubber. I suspect our cars are in similar weather environments - hot and humid and if you add some oil from a slightly leaky valve gasket the mounts are cooked. I wouldn’t reinstall the mounts without proper heat shields. Too bad the M4 mounts don’t fit.
DrFerry6730.00 |
02-18-2021, 11:18 PM | #33 |
Rep 4,175
Yeah the M4 mounts look much better designed. At this stage I just want to repair the VT mounts and sell them off to someone living in colder climates. I'm in hot humid weather as well and it's definitely not for our temperatures.
02-19-2021, 01:46 PM | #35 |
1478
Rep 2,672
Years ago I replaced my engine mounts with Vibratechnics when I replaced my rod bearings. One of the mounts failed on me after one track day. I was lucky and the vendor who sold me the mounts gave me a full refund. They weren't sure if VT would refund them but they did it anyway.
Photo of the mounts after failing - http://www.m3post.com/forums/showthr...41147&page=136
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
DrFerry6730.00 |
02-19-2021, 03:44 PM | #36 |
Save the manuals!
6026
Rep 6,753
Damn, I thought these were the best option for street cars. Looks like it's better to stick with OEM Corteco or the Gruppe N ones ($$$).
Anyone have experience with the Bimmerworld mounts?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
02-20-2021, 05:43 AM | #38 |
mTekMods
2157
Rep 2,909
I had bimmerworld, im going back to stock. The slight increase in Nvh is too much for me, I dont drive the car enough to live with a slight rumble all the time. OEM or nothing, I rather replace them every two years because it really isnt that hard.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
02-20-2021, 11:23 AM | #40 | |
Rep 3,412
Not a Doctor, those are just my initials.
6ixSpd6026.00 |
02-23-2021, 02:31 PM | #42 |
Rep 485
Just picked up my car with the BW performance mounts installed. There is barely any NVH difference, IMO. Can feel a bit more vibration at idle and when initially accelerating, but it's hardly bad. And it shifts way better under load. The 2 to 3 shift used to feel a little iffy, now it feels way more precise.
DRLane3991.50 |
02-24-2021, 08:03 AM | #44 |
Rep 1,001
I was about to order VT mounts then I saw this post. Decided to go with BW instead since I'll be getting my rod bearings done next week.
| 2008 E90 M3 | Alpine White | 6MT |
