2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Car won't start
      01-08-2024, 01:55 PM   #1
swquat
swquat's Avatar
13
Drives: 2016 f22 m235i, 1996 e36 328i
2016 bmw m235i  [5.75]
Car won't start
Went to breakfast this morning car started fine so issues what so ever. Finished breakfast went to start the car, it will turn on but no crank starter clicks once. chasis stabilization warning,starter/ignition,and fuel system warning all came on. Chalked it up to the clutch safety switch/ starter. went to read codes on bm3 nothing. went to flash car to stock to bring it to the shop flash fails everytime no matter what I try. Is this just because of the no start issue or is it a dme issue. Gonna try an actual code reader later today and see if no codes again
Dom14790.50
      01-09-2024, 10:59 PM   #2
Kernel Kurtz
Kernel Kurtz's Avatar
347
Drives: 2020 M240i xDrive
How old is your battery? Bad battery will cause all sorts of strange and unpredictable things, I'd check that first.
      01-10-2024, 06:35 PM   #3
swquat
swquat's Avatar
13
Battery’s new from the beginning of last year code from reader is a zgm fault code 801c20
      01-10-2024, 08:05 PM   #4
Kernel Kurtz
347
After a quick Google on that, I'd still check the battery voltage first thing.
      01-10-2024, 08:05 PM   #5
JDM240
JDM240's Avatar
Drives: BMW M240i(F22) BMW 335xi (E90)
Clear all your codes and try (both to start and scan) again
      01-10-2024, 09:00 PM   #6
swquat
swquat's Avatar
13
It’s reading just below 12v so we’re gonna throw it on a battery tender let it charge for a day and try starting it again
      01-11-2024, 12:17 PM   #7
Kernel Kurtz
347
Below 12 is not really good.
https://x3.xbimmers.com/forums/showp...91&postcount=2
When you replaced the battery last year did you register it to the car?
      01-11-2024, 12:56 PM   #8
swquat
swquat's Avatar
13
I believe so I’d have to actually double check our system to see if the battery is new but I’m fairly certain it is
      01-14-2024, 08:41 PM   #9
swquat
swquat's Avatar
13
Here’s 12 pages of codes SMH
      02-07-2024, 08:14 AM   #10
nikijack
37
Drives: 2016 M235i, Grey, manual
I had the ground strap fail, causing those symptoms.
      02-10-2024, 07:14 AM   #11
swquat
swquat's Avatar
13
I’ll keep that in mind it’s at the dealership currently so we’ll see if they can figure it out.
2addicts
