11-15-2019, 03:57 PM | #1 |
3532
Rep 6,752
APEX Wheels | Classic Forged Line
Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST ARC-8R & EC-7R Everything you love about the original, now enhanced with all the added benefits of forged manufacturing. ➡︎ Significantly increased strength ➡︎ Improved brake clearance ➡︎ Paintless knurled beads ➡︎ New premium finishes Order Now ARC-8R / EC-7R Available Finishes Even More Strength “Forged” doesn’t mean strong. Many forged wheels focus on weight reduction so much that they end up with the same load rating as cast wheels. Think all forged wheels are stronger than cast or flow formed? Think again. We've added up to 1,000 pounds of extra load capacity per vehicle compared to our flow formed line. Learn more about why not all 'forged' wheels are strong. The flow formed ARC-8 was our first design, so it features our older barrel profile with compromised brake clearance. Typical blank forgings (the starting point many other manufacturers use) can have even worse clearance than our original flow formed wheel. By developing our own proprietary new profiles and new dies, the 18" ARC-8R and EC-7R can clear Brembo 380mm kits and the 19" version can clear BMW 410mm carbon ceramics. Learn more about why we had to create our own new forging dies to clear big brakes. Not all knurling is created equal. To reduce unwanted tire spin as much as we could, we protected our knurling from paint to keep them sharp. We didn’t take the cheaper shortcut of painting over the bead area, which makes the knurling smoother and rounder. See and feel the difference. Learn more about why our forged wheels have unpainted knurled beads. Our forged wheel line enabled us to release premium finishes we’ve always hoped for. Fully polished aluminum and hand brushed with tinted clear now join a wide range of painted finishes, with more to come. Our forged wheels not only deliver performance, but also provide distinctive new styling as well. APEX is known for stocking a wide variety of chassis specific fitments to meet the needs of a very diverse enthusiast community. We’re releasing those same street, track and race proven fitments and more in our new forged line. New lower production requirements allow us to cater to even the most niche segments of the BMW market that may have previously been off limits. We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a fully forged wheel with an ideal balance of strength and weight. Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX Classic Line forged wheels are tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our forged wheels exceed those ratings by almost 20%. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy. Additional Features Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required. Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps. Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly. TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes. All our forged wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable. Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively. All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. Order Now ARC-8R / EC-7R Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 11-12-2021 at 05:25 PM.. |
11-15-2019, 03:57 PM | #2 |
3532
Rep 6,752
Introducing the ARC-8R Race Silver Anthracite Satin Black Brushed Clear Polished Introducing the EC-7R Race Silver Anthracite Satin Black Brushed Clear Polished
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-16-2020 at 02:53 PM.. |
12-19-2019, 05:57 PM | #3 |
mg340ac
9
Rep 22
12-23-2019, 04:58 PM | #4 | |
3532
Rep 6,752
-Tom
03-09-2020, 06:30 PM | #6 |
3532
Rep 6,752
Thanks for your question! We are absolutely planning on 19" ARC-8Rs and EC-7Rs for the future and are working hard on making sure these new forged wheels will be up to our standards. We hope to have more information available late in the 2nd quarter!
Thanks -Tom
Stlblues68.50 |
03-26-2020, 06:41 PM | #7 |
3532
Rep 6,752
09-02-2020, 09:01 AM | #8 | |
Rep 68
09-02-2020, 12:20 PM | #9 |
3532
Rep 6,752
Unfortunately, we have encountered a few production delays with these wheels. It's looking like we will have forged 19" BMW wheels available next year, but we will release more information as we draw closer to the release date.
-Tom
09-10-2020, 05:42 PM | #10 |
3532
Rep 6,752
APEX Forged: Stronger than ever and ready to ship. Our new forged offerings have significantly higher load ratings with over 1000 LBS of additional capacity for 4 wheels in an 18" diameter compared to our already strong flow-formed wheels! The increase in load rating allows these new wheels to better cope with the demands that sticky tires, heavy cars, and high downforce present. Check out this F30 on our ARC-8Rs: Specs: ARC-8R Brushed clear Front: 17x9" ET42 with 12mm spacers to clear coilovers Rear: 17x9" ET42 with no spacers 255/40-17 tires all around Rear camber was maxed out to fit the owner's other setup which uses a 18x9.5" ET35 ARC-8 on the rear with 275/35-18 tires.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-16-2020 at 04:08 PM.. |
10-16-2020, 06:20 PM | #11 |
3532
Rep 6,752
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-16-2020 at 03:55 PM.. |
11-06-2020, 02:47 PM | #12 |
3532
Rep 6,752
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-16-2020 at 04:02 PM.. |
12-07-2020, 03:55 PM | #13 |
3532
Rep 6,752
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 12-16-2020 at 04:05 PM.. |
01-04-2021, 06:55 PM | #14 |
3532
Rep 6,752
01-22-2021, 04:21 PM | #15 |
3532
Rep 6,752
The fully Forged ARC-8R Unlike our Flow Formed wheels, the Fully Forged APEX ARC-8R and EC-7R are offered with a profile 2 medium concave design even in the higher offset sizes. This allows all chassis to experience the awesome look of concave wheels.
02-05-2021, 04:23 PM | #16 |
3532
Rep 6,752
The Fully Forged EC-7R: More Brake Clearance Thank Any Other APEX Wheel The APEX EC-7R improves brake clearance over the impressive amount offered by the Flow Formed EC-7. Forging allows us to reduce spoke thickness without compromising strength. As a result, the EC-7R has more brake clearance than any wheel we've ever made.
03-11-2021, 07:07 PM | #17 |
3532
Rep 6,752
04-06-2021, 05:20 PM | #18 |
3532
Rep 6,752
04-20-2021, 06:33 PM | #19 |
3532
Rep 6,752
Bigger, Tougher Inner Lip The inner lip is the most vulnerable part of a wheel, because it has no spokes for support. By using forged 6061-T6 aluminum, and reinforcing this high-impact area with more material, we provide an extra layer of protection against track berms, potholes, and whatever else the road may throw at you.
05-18-2021, 06:50 PM | #20 |
3532
Rep 6,752
06-25-2021, 06:00 PM | #21 |
3532
Rep 6,752
09-01-2021, 05:11 PM | #22 |
3532
Rep 6,752
